Lockedyamaha viking
Page: 1234 > Showing page 1 of 4
catislandmud
2013/06/11 20:04:04 (permalink)
yamaha viking
utv underground has a write up of the new Yamaha sxs...... the yamaha viking
Gone but not forgotten:
'99 Honda 300 4x426" ITP 589'slift kit and lift springs
100 Replies Related Threads
    catislandmud
    Re:yamaha viking 2013/06/11 20:11:01 (permalink)
    And it appears that they will be discontinuing production of the Rhino all together. I guess dinosaurs are extinct......
    Ole Nasty
    Re:yamaha viking 2013/06/11 20:11:58 (permalink)
    Way to go Yamaflop.
    2011 Grizzly 700 EPS
    29.5" Highlifter Outlaws
    2mm Shim Mod
    EPI White Spring
    Snorkeled
    Wild Boar Radiator Re-locate
    2" Highlifter Lift
    Yamaha HD front bumper
    2014 Polaris Ranger XP 800
    All Stock
    Gone
    2005 Yamaha Rhino 660
    2009 Polaris Sportsman 500HO
       http://www.youtube.com/OleNasty79
    zillad3004x4
    Re:yamaha viking 2013/06/11 20:14:20 (permalink)
    Wow. Not a total disappointment, but definitely a let down...
    14 ranger 900: backwoods forward arms, roof,29.5 swamplites, little LED lighting, viper 5k, custom bumper
    japickar
    Re:yamaha viking 2013/06/11 20:14:52 (permalink)
    Looks like yamaha pulled a honda on us
    98' Foreman 400
    450 shocks and front suspension
    HL lift springs
    Xtreme disc brake conversion
    28/10/12 and 28/12/12 Zillas
    SS112's
    HL leak shield
    14.5% gear reduction
     Warn 4-2-4
    HL bash plate
    Bulldog66
    Re:yamaha viking 2013/06/11 20:21:10 (permalink)
    07 H1 With a few mods.
    12' Wildcat. Stuff to come.
    Jdavid1
    Re:yamaha viking 2013/06/11 20:21:30 (permalink)
    FAIL
    2013 Polaris RZR S
    34" Terminators
    15" MSA Diesels
    Highlifter Arched Arms
    2" Highlifter Lift Kit
    ProShopCustoms
    Re:yamaha viking 2013/06/11 20:22:59 (permalink)
    ewwwwww that things fugly!
    1994 Honda TreeHunnit 2 wheel pull
    Swamp Starz✯
    Past Rides: 99 Honda 300 4x4, 08 Sportsman 800, 08 RZR 800, 07 Can-Am 400ish, 07 Ranger 700xp, 2001 Quadrunner 500 4x4, 2010 Sportsman 550xp
    Bulldog66
    Re:yamaha viking 2013/06/11 20:23:46 (permalink)
    Mud lawdawg
    Re:yamaha viking 2013/06/11 20:25:10 (permalink)
    It’s been a long time coming, but Yamaha has finally pulled the wraps on its new side-by-side, the 2014 Yamaha Viking. This three-seat UTV will replace the Rhino as the Tuning Fork Company’s stand-alone offering in the segment. Recently the press was introduced to the Viking at a small press conference ahead of the Yamaha dealer meeting that took place today in Las Vegas. Now that the big news is out we can give you all the details.
    Like many UTV connoisseurs out there, we were expecting to see a sport side-by-side so the announcement of the Viking caught us completely by surprise. Yamaha knew the question of “why?” would be first on most people’s lips and they were locked and loaded with the answers.
    Through its research, Yamaha has found that even though sport models get a massive amount of attention, 66% of the side-by-side market is utility (farming and hunting) based. Of the machines sold that run under 30 mph, two-thirds of the units are utility while in the above 30 mph world a little less than half are. That’s a huge slice of the pie any way you cut it, and it makes complete sense to go after what people are actually buying the most of. So with that, the Viking was conceived with its sights set squarely on the leader of the three-passenger side-by-side market, the Polaris Ranger XP.
    Yamaha touts the Viking as having the only “true” three-person seating on the market. Instead of a bench seat, three individual bucket seats are placed in the cab with the center seat’s backrest offset slightly at the rear of the vehicle. This is to allow for more shoulder room for all occupants. The seat height is low for easy in-and-out as well as for a lower center of gravity. All three seats have a comfortable reclined seating position for more comfort in rough terrain. Three-point seatbelts are fitted for each person and secure areas are molded into the floorboards for each pair of feet. Additionally, a one-piece handhold for both passengers is adjustable fore and aft.
    As the Viking is a machine capable of work and play, the steel dumping cargo bed boasts a 600-pound capacity. Inside, integrated tie-down points allow for various sized loads to be secured. A single gas strut assists in lifting the front of the bed up.
    The Viking’s suspension consists of fully independent dual a-arm suspension at all four corners. Nitrogen charged gas coil over struts handle the damping duties. Up-front the suspension strokes through 8 inches while at the back the travel is slightly less with 7.9 inches.
    Braking duties are performed by disc brakes at all four corners with an additional disc on the rear output shaft for the parking brake. Dual piston calipers squeeze solid rotors for excellent power and feel.
    Yamaha claims the 2014 Viking has the best off-road capability in the class thanks to its 11.8 inches of ground clearance at the lowest point of the frame. The smooth underbody protection, consisting of a large steel plate at the center and plastic skids protecting the front and rear differentials, keeps the machine from hanging up on trail obstacles. The sides of the frame sweep up from the center section 60mm to further decrease the chances of becoming stuck. Traction is provided by Maxxis Big Horn tires built exclusively for the Viking.
    The Viking continues the lineage of the single cylinder, liquid-cooled 686cc engine configuration; however this mill is the most powerful to date, delivering strong low-end acceleration and a robust pull throughout the rev range. The single overhead camshaft is fuel injected and has gained up to 30% in fuel efficiency. Featuring a high capacity cooling system and a liquid cooled oil cooler, the rear-facing engine reduces heat on the occupants. The high volume air intake system also improves the overall engine performance and features an oversized dual-foam air filter. Access for air filter service is under the center seat and requires no tools.
    The Viking’s Ultramatic Transmission has a dual-range drive (Hi/Lo) and reverse powered though the most durable CVT system on the market. An automatic centrifugal clutch maintains constant belt tension on the drive and driven sheaves for reduced belt wear and reliability. For all-wheel engine braking, a one-way sprag clutch is utilized. An integrated cooling fan manages the CVT temps by pulling cool air through an inlet duct behind the seats that sits 36.4 inches above the ground and pushing warm air through an outlet at 31.6 inches above the soil.
    Yamaha carries over its three-position On-Command 4WD system that lets you choose between 2WD, limited-slip 4WD and a fully locked 4WD drive mode. A dash mounted gate shift lever is used for selecting gear ranges. Also on the dash is an LCD multifunction digital instrumentation panel that displays a speedometer, odometer, dual trip meters, hour meter, 4WD status, gear position clock and fuel level.
    Steering is available in a precise standard rack and pinion set-up or an optional Electric Power Steering system. The EPS system lightens the steering effort for comfort as well as less bump steer.
    MSRP for the standard 2014 Viking is $11,499 while the EPS model brings a $1000 premium at $12,499. Prices do increase for units with and optional suntop with the most expensive unit coming in at $13,249. Available colors are Hunter Green, Red, Steel Blue and Realtree AP HD. The Viking will arrive in dealerships later this summer.
    Mine
    08  700 DU,
    29.5, 12" lift, HMF, ///, pc3, snork'd
    Wife's
    07 700 SE
    29.5 ,snork's, 2" lift,HMF, TMHP "Girl Power" Rad relocate, Clutch kit, Led's, Custom Radio
    TMHP
    big tony
    Re:yamaha viking 2013/06/11 20:25:42 (permalink)
    added a seat in the middle and changed the name.....watch out
    joshshoots01
    Re:yamaha viking 2013/06/11 20:27:26 (permalink)
    Gayyy
    15 rzr 1000/33 terms/5"lift/adrenaline snorkels/
    2010 outty 400/ crushed sycotrax/ little motor work/cv tech/stm/adrenaline snorkels/
    2009 renegade 800/ motor work/ crushed 32's/clutches/
    cams/adrenaline snorkels/
    2015 xmr 1000/crushed 32's/cv tech/stm/
    #84 adrenaline racing
    Bulldog66
    Re:yamaha viking 2013/06/11 20:28:05 (permalink)
    Front drive shaft is 4' long?!
    Glad I got an old school Rhino.
    Texas Chaos
    Re:yamaha viking 2013/06/11 20:29:30 (permalink)
    Lol the fenders can fit 35s!
    2013 Ranger 900
    Backwoods Armor Adjustable Lift
    Backwoods Armor Forward Arms
    29.5 Terms on HD3s
    Cobra Axles
    a little zoom-zoom in her boom-boom
    NO BOOST, NO BOTTLE, JUST BALLS AND THROTTLE.
    BamaRider
    Re:yamaha viking 2013/06/11 20:30:41 (permalink)
    Well it's good they finally came out with something new....(i think)... Definitely not what I was expecting and is a disappointment. First thing I thought when I saw it was looks like yamaha played it safe and went the route Honda did.
    It's a good concept but not very attractive and not what I expected from yamaha... Maybe just maybe they have something else up their sleeves.....
    2014 Polaris Ranger 900 XP White Lightning
    Backwoods Armor Red Forward/Arched Front and Rear Arms & 3" Lift
    Backwoods Front Bumper
    30" Zillas on 14" Black Kores
    Audioformz Roof with Front and Rear Lighting, Interior Lighting, 4 6x9's Rockford Fosgates, and Radio
    Back-Up Lighting wired to reverse
    Fan Switch
    Triangle ATV Snorkels
    2011 Can am Commander 1000 XT (SOLD
    CATVOS  lift and tie rods
    30 law Rads on 14" ITP's
    Audioformz roof
    2010 ThunderCat MUDPRO 1000  (SOLD
    06 Arctic Cat 650 H1 4x4 (SOLD)
    29.5 laws
    HMF
    Snorkeled
    G Axles
    Radiator Relocated
    20" of ground clearance
    [link
    Ragin Cajun
    Re:yamaha viking 2013/06/11 20:31:23 (permalink)
    Huge FAIL.
    2slow
    Re:yamaha viking 2013/06/11 20:33:17 (permalink)
    wow cant believe it... it resembles the ranger alot, i kind of figgured they were going to stay in the utility market
    Texasmudslinger
    Re:yamaha viking 2013/06/11 20:37:00 (permalink)
    Well at least it has dual cupholders up front
    Lol
    BamaRider
    Re:yamaha viking 2013/06/11 20:38:07 (permalink)
    Yea doesn't look like a lift will be necessary to fit some bigger tires!!! I'm interested in seeing it modded with tires and all, maybe that will make it more appealing.
    I'm all about looking at the more utility side of the market just not sure if that's what they really was going for or not...
    post edited by BamaRider - 2013/06/11 20:41:24
    Fan Switch
    Audioformz roof
    29.5 laws
    HMF
    Snorkeled
    G Axles
    Radiator Relocated
    [link
    #19
    Jdavid1
    Re:yamaha viking 2013/06/11 20:38:45 (permalink)
    I believe it has QUAD cupholders up front.
    2013 Polaris RZR S
    34" Terminators
    15" MSA Diesels
    #20
    Bills660Grizzly
    Re:yamaha viking 2013/06/11 20:56:49 (permalink)
    It should have at least 3 since its the industry's first true 3 seater lmfao
    RZR 800
    GRIZZLY 660
    FOREMAN 450
    #21
    localfiremedic
    Re:yamaha viking 2013/06/11 21:19:00 (permalink)
    If they actually put some low gearing in it, it may be decent
    The Pride AKA Team Carnage
    '12 Arctic Cat Wildcat 1000
    sold
     '08 650 H1 TRV
    Reconstructed....
    700H1 fuel injected, 3.6s (braced, greased, and beefed mounts), shimmed primary, reclocked secondary, 16.5/21gram rollers, #54lb stall, MP axles, MTI arched lowers, single seater uppers, all single seater front shocks, bracket lift, 31wides on XL2s, HIDs, poly bushings, anti-kick back starter gears, straight cuts
    #22
    Solitude
    Re:yamaha viking 2013/06/11 21:20:38 (permalink)
    Pretty sure I will never own another Yamaha and proud to say it.
    Built RZR 800
    #23
    localfiremedic
    Re:yamaha viking 2013/06/11 21:21:04 (permalink)
    It has the same wheelbase as a teryx 4 and is only 3in shorter in total length than a t4
    sold
     '08 650 H1 TRV
    Reconstructed....
    #24
    mud PRO 700
    Re:yamaha viking 2013/06/11 21:29:11 (permalink)
    It's not terrible. Like they said, they didn't go after our sport when they built it, they made it to get the most profit out of it possible. It looks as wide as f150 but not half bad! Hope its geared Low!!
    2009 Can-am outlander XT
    #25
    Honda Dad
    Re:yamaha viking 2013/06/11 21:30:47 (permalink)
    Bills660Grizzly
    LOL  Yeah I got a kick out of that part too!
    2012 Kawasaki Teryx4 LE
    Kawi Half Windshield
    Warn Vantage 4K
    2004 Honda Rancher AT
    Highlifter Skid/bash plates/brush guard/CV Guards
    ITP Wheels/Mudlites
    #26
    Silveradols
    Re:yamaha viking 2013/06/11 21:37:49 (permalink)
    Looks like Yamaha played it safe and made upgrades to the Rhino to prevent the lawsuits.  Longer, wider and longer wheelbase.  I like some of the upgrades....ie.  The drinkholders, the 2wd/4wd/Diff-Lock turn knob, the rear-view mirror and moving the parking braked and shifter to the dashboard.  no middle floor hump either.  I don't particularly like the looks of the front end though.  I wonder if the higher compression will give it more power?
    post edited by Silveradols - 2013/06/11 21:38:58
    #27
    Greasy Stacey
    Re:yamaha viking 2013/06/11 21:42:09 (permalink)
    Well...at least they didn't name it Big Blue...
    #28
    Coreyflipp
    Re:yamaha viking 2013/06/11 21:42:40 (permalink)
    Here's to another 10 years.
    #29
    GatorBoi
    Re:yamaha viking 2013/06/11 21:45:05 (permalink)
    It's not a fail as some of you are saying.  They didn't make what you wanted but they made what is going to sell products.  It is a fairly nice UTV overall.  I would say it's an upgrade to the rhino and even has a bright future for the mud.  Look at the tire clearance.
    2010 Honda Rancher 420
    Axle Paddle
    2" HL Lift
    ITP SS312 Wheels
    28" Outlaws
    Big Gun Exhaust
    Uni Filter
    Wild Boar Radiator Relocation
    Snorkle
    Greased Diff
    #30
