High Lifter Forum
Forum Navigation
 update on $30 nitrous setup, RESULTS!!
Change Page: < 12345678 > | Showing page 6 of 8, messages 151 to 180 of 216
Author Message
YAMAFORD
  • Reward points : 0
RE: update on $30 nitrous setup, RESULTS!! - Saturday, March 17, 2007 9:33 AM ( #151 )
"adult" stores have them. slang term is whipetts just don't ask for that when you go in ask for whip cream chargers.
East Coast Mud Nationals
http://www.creekbottomtrailrides.com/
DRIVEN BY
CREEK BOTTOM TRAIL RIDES
OFFROAD POWERSPORTS OF TIFTON
MOREMUDD
STATELINE CUSTOMS
TIFTON CYCLE
Lake Blackshear Powersports Tuning Division
jones8615
  • Reward points : 0
RE: update on $30 nitrous setup, RESULTS!! - Saturday, March 17, 2007 9:35 AM ( #152 )
people get high off these things all the time put them into a ballon and blow out all air and take the n2o in take you off to dream land for about thirty seconds
jones8615
  • Reward points : 0
RE: update on $30 nitrous setup, RESULTS!! - Saturday, March 17, 2007 7:43 PM ( #153 )
I finally got my inflator and 16 gram n2o in today by fedex. Went to the local Napa and got the parts. I did not put the air needle on the pump. I hooked the pump strait to the hose. This is on my artic cat prowler it has the 650 H1 engine in it. I need some speed test with it and rpm test stock.
Since I put the 30" mudlight on it, it took some top end power away and thats what I was hoping to get back. I was topping out around 48 mph with the setup at 3/4 mile, I then ran the n2o and tap the trigger every two secs for 2 sec burst and at 1/2 mile I was at 53 so a pretty big gain out of this little setup. I ran a max of 62 at 1 mile, which is 9 miles an hour over stock with one charger of n2o. It definatly woke this machine up. My brother and I went riding at our little **** whole we call it. I ran the hole which is about two feet deep with water and some deeper spots close to three feet. The run is about 40 or so yards. i ran the hole twice without the n2o and the first run was 38 sec and the sec 41 sec. Then now with the n2o at same distance was 32 sec, I could diffenatly tell when I hit the trigger the tires span alot faster, nothing like the fast and furious but it was very noticable. We ran it on own by brothers 650 rincon and was about the same reasults. I just ordered him the same set up for his bike.
mud baron
  • Reward points : 0
RE: update on $30 nitrous setup, RESULTS!! - Sunday, March 18, 2007 6:02 PM ( #154 )
so let me get this straight....you hooked the 'pump/trigger' to the hose and ran it into the air box......my question is what are you useing to 'atomize' the n2o.......?......i think i came up with a soloution...but want to here what you did....how long did each cartridge last....
91CavGT
  • Reward points : 0
RE: update on $30 nitrous setup, RESULTS!! - Monday, March 19, 2007 6:18 AM ( #155 )
You don't have to atomize the nitrous.  It comes out as a gas, not a liquid so there's really nothing to atomize.  Just spray it into the air box or your snorkel and that's all you have to do.
2005 Suzuki Ozark, modded SOLD
1991 Honda Fourtrax 300 4X4  - mine
Dirt Cheap Fourtrax Build
1982 Suzuki LT125  - one of my son's
1983 Suzuki LT125  - my other son's
198X Suzuki LT185  - The wife's
mud baron
  • Reward points : 0
RE: update on $30 nitrous setup, RESULTS!! - Monday, March 19, 2007 7:37 AM ( #156 )
up till this point i was agreeing....but n2o needs to be atomized to spray correctly......I am getting an 'adjustable' n2o nozzle that will bolt right in my air intake and 'mist' straight down into carb.....will be much better burn....i have been checking on n2o sites and the experts seem to agree......
G H O S T
  • Reward points : 0
RE: update on $30 nitrous setup, RESULTS!! - Monday, March 19, 2007 12:05 PM ( #157 )
'90 TRX300 6x4
Thumper 376, 35mm carb, webcam, CWR head, supertrap, dial'a'jet, uni, Nology, mojave headpipe, trx450 gears, 250x discs, nerfbars, winch, 300ex shocks, 1.5"lift, Maxxis Lynx up front, dual mudlites on back
GPS @ 59mph, can your 300 do that?
'02 BigBear 400 4x4
uni , 26" SwampFox on red grizz wheels, warn2500,
2" lift, hotcam, uni, '07 BB footwells
Ever seen a yellow Bear?
jones8615
  • Reward points : 0
RE: update on $30 nitrous setup, RESULTS!! - Monday, March 19, 2007 12:54 PM ( #158 )
Thats almost exactly the way mine is
arkredneck
  • Reward points : 0
RE: update on $30 nitrous setup, RESULTS!! - Monday, March 19, 2007 6:37 PM ( #159 )
you could probably use the 8 gram cartitages if you were to put some kind of spacer in there so the inflator would peirce it
G H O S T
  • Reward points : 0
RE: update on $30 nitrous setup, RESULTS!! - Tuesday, March 20, 2007 12:05 AM ( #160 )
ORIGINAL: arkredneck
As cheap as the 16s are.....why use 8s??
'90 TRX300 6x4
'02 BigBear 400 4x4
bigpopo2792
  • Reward points : 0
RE: update on $30 nitrous setup, RESULTS!! - Tuesday, March 20, 2007 1:28 PM ( #161 )
8 gram cartridges are a little to small. they would be great on an atv 50cc-250cc though[;)]
bigpopo2792
  • Reward points : 0
RE: update on $30 nitrous setup, RESULTS!! - Tuesday, March 20, 2007 1:31 PM ( #162 )
maybe the 8 grams would be best used for longer shots since there would be a less chance of harm to the engine than 16g
01 Polaris Magnum 325:
05 Polaris 800:
ragtagranchers
  • Reward points : 0
RE: update on $30 nitrous setup, RESULTS!! - Wednesday, March 21, 2007 2:21 PM ( #163 )
ORIGINAL: bigpopo2792
they arent more powerful than the 16s
85 honda big red
build in progress...
will be bringing the POW-AHHH
arkredneck
  • Reward points : 0
RE: update on $30 nitrous setup, RESULTS!! - Thursday, March 22, 2007 7:27 PM ( #164 )
if you didn't want to order the 16 gram one most head shops carry the 8
G H O S T
  • Reward points : 0
RE: update on $30 nitrous setup, RESULTS!! - Thursday, April 05, 2007 11:35 AM ( #165 )
i ordered one...it will be here next week
'90 TRX300 6x4
'02 BigBear 400 4x4
mud baron
  • Reward points : 0
RE: update on $30 nitrous setup, RESULTS!! - Thursday, April 05, 2007 1:34 PM ( #166 )
ORIGINAL: G H O S T
ordered what...the kit off ebay...?...
G H O S T
  • Reward points : 0
RE: update on $30 nitrous setup, RESULTS!! - Friday, April 06, 2007 12:11 AM ( #167 )
ORIGINAL: mud baron
ORIGINAL: G H O S T
yes
'90 TRX300 6x4
'02 BigBear 400 4x4
G H O S T
  • Reward points : 0
RE: update on $30 nitrous setup, RESULTS!! - Tuesday, April 10, 2007 11:31 AM ( #168 )
put the ebay kit on the lt185 to test it out....wide open in 3rd gear one quick pull of the trigger and it was wheelie time.....
...best $44 i ever spent
'90 TRX300 6x4
'02 BigBear 400 4x4
mud baron
  • Reward points : 0
RE: update on $30 nitrous setup, RESULTS!! - Tuesday, April 10, 2007 11:46 AM ( #169 )
so how amny times you hit it...?...see any speed/pulling increase..?...how long did you keep it 'on'....?...
G H O S T
  • Reward points : 0
RE: update on $30 nitrous setup, RESULTS!! - Tuesday, April 10, 2007 12:15 PM ( #170 )
ORIGINAL: mud baron
maybe a sec or 2....one pull...just stuck the end of the hose in the stock snorkle....hit 3rd reved out and wham!! the frunt end came up and had to shut her down befor hitting the pool....pulled sideways when it pulled up......more testing tomorrow...
'90 TRX300 6x4
'02 BigBear 400 4x4
skyscraper38
  • Reward points : 0
RE: update on $30 nitrous setup, RESULTS!! - Wednesday, April 11, 2007 8:55 PM ( #171 )
im thinkin bout buying the kit off ebay.. will this tear up my motor.? cause if so i dont want to go get it. cause i just spent most of my money rebuilding my motor. thanks yall
let me know.
2007 Yamaha Rhino
28" Outlaws
MSA Patriots
3in Lift
Audiopipe
2008 Thundercat
Supertrapp Mudslinger exhaust
Lift
Lo-Pro Snorks
30" XXL's
Radiator Relocated
G H O S T
  • Reward points : 0
RE: update on $30 nitrous setup, RESULTS!! - Thursday, April 12, 2007 7:15 AM ( #172 )
ok after a few test runs here we go.....2 to 3 shots out of one 16oz bottle....makes a noticable increase....nothing OMG big....but very noticable.....and this was on a motor with 6800 miles bone stock.....going to pipe the hose straight into the the tube between the filter and the carb with a 122 instead of the stock 118 jet....
'90 TRX300 6x4
'02 BigBear 400 4x4
JollyGreen700
  • Reward points : 0
RE: update on $30 nitrous setup, RESULTS!! - Thursday, April 12, 2007 12:43 PM ( #173 )
I am thinking about putting this setup on my prairie 700 and i was wondering if you could use the Co2 cartriges for like those BB hand guns or will that not work? and are there any long term effects of putting this on your bike? any information will be greatly appreciated. Thank you
ragtagranchers
  • Reward points : 0
RE: update on $30 nitrous setup, RESULTS!! - Thursday, April 12, 2007 8:54 PM ( #174 )
co2 will not work
85 honda big red
Mikeb
  • Reward points : 0
RE: update on $30 nitrous setup, RESULTS!! - Monday, April 16, 2007 10:43 AM ( #175 )
man i just got done testing out this $30 nitrous setup yall have been talking about on my 680 rincon and it is pretty kick ****, i puched the throttle at about 20 mph then tapped the spray and it took off, i wasnt expecting it to work so well. i am going to upgrade the setup though whenever i have time to get it all hooked up. im going to put a zip tie around the trigger of the inflater to keep the trigger pulled and i got i solinoid valve that im going to put in the line so i can have the inflator hidden  somewhere and have a button mounted on my handle bars to control the valve
2010 800r gade, 2" lift, 30" backs, 312's, hmf, dalton, snorkels, 650 helix
2007 outy 800, 7" lift, hmf, 29.5 laws. K&N, center snorkels, radiator up top, custom seat
2007 rincon (sold)
skyscraper38
  • Reward points : 0
RE: update on $30 nitrous setup, RESULTS!! - Monday, April 16, 2007 3:04 PM ( #176 )
would this tear up up motor?cause if so i dont want to get it. cause i just spent most of my money rebuilding my motor
2007 Yamaha Rhino
28" Outlaws
MSA Patriots
3in Lift
Audiopipe
2008 Thundercat
Lift
Lo-Pro Snorks
30" XXL's
Radiator Relocated
creep
  • Reward points : 0
RE: update on $30 nitrous setup, RESULTS!! - Thursday, April 26, 2007 3:17 AM ( #177 )
im thinking of doing this to my little cousings jr dragster.  13 year old able to do 80 in the 1/8th right now i wonder how that little alcohol engine would react to it hmmmm. give her a upper hand.
ragtagranchers
  • Reward points : 0
RE: update on $30 nitrous setup, RESULTS!! - Thursday, April 26, 2007 2:44 PM ( #178 )
ORIGINAL: skyscraper38
well it depends on how u use it
85 honda big red
wolverine01
  • Reward points : 0
RE: update on $30 nitrous setup, RESULTS!! - Thursday, April 26, 2007 2:54 PM ( #179 )
on trucks some use nitrous and propane. could you use just propane and get the same affect. the small propane bottles are avabile everywhere.
2008 GRIZZLY 700
28" SILVERBACKS
ITP 212 WHEELS
SNORKELD
RADITOR RELOCATED
TWIN AIR FILTER
EPI MUDDER CLUTCH KIT
HANGER MOD
DYNATECH BOX
creep
  • Reward points : 0
RE: update on $30 nitrous setup, RESULTS!! - Friday, April 27, 2007 5:28 AM ( #180 )
propane is used on diasel engines as a power adder, this is a minin alcohol engine just like a go cart motor.
Current active users
Icon Legend and Permission
  • New Messages
  • No New Messages
  • Hot Topic w/ New Messages
  • Hot Topic w/o New Messages
  • Locked w/ New Messages
  • Locked w/o New Messages
  • Read Message
  • Post New Thread
  • Reply to message
  • Post New Poll
  • Submit Vote
  • Post reward post
  • Delete my own posts
  • Delete my own threads
  • Rate post
