Change Page:
< 12345678 > | Showing page 4 of 8, messages 91 to 120 of 216
tanner
Total Posts
3
Reward points
RE: update on $30 nitrous setup, RESULTS!!
Monday, September 04, 2006 6:56 PM
( #91 )
thats ok but this has got me thinking and im trying something that if it works would change nitrous oxide forever
trx250ex with pro circuit full system uni filter rejeted carb nitrous oxide injection and it will never be enough
HReconRider0909
Total Posts
58
Reward points
Tuesday, September 12, 2006 3:52 PM
( #92 )
Alright Ive got a theory but correct me if im wrong because i haven't had the chance to test it out yet Since this setup will cause the bike to run lean a little bit wouldnt putting the choke on kind of balance out the effect by letting in more gas with about the same amount of air that way you dont have to completly rejet it just for a few seconds of nitrous.
fiffer000
Total Posts
194
Reward points
Tuesday, September 12, 2006 7:24 PM
( #93 )
Good point!! Now if someone with a vast amount of knowledge about this stuff will chime in!!
backinblack700
Total Posts
2539
Reward points
Sunday, September 24, 2006 9:42 AM
( #94 )
[;)]i wanna know how it worked on your big machine silverback!
CHASE '09 Polaris Sportsman 800- Sitting on seven inches. '96 Polaris Sportsman 400- Not done with the motor. TEAM ROCKY CREEK- http://rockycreekatv.com/
06silverback
Total Posts
1302
Reward points
Monday, September 25, 2006 8:59 PM
( #95 )
I never put it on there. I bought a big kit
4 wheels comfy seat big motor nice handle bars
YAMAFORD
Total Posts
2540
Reward points
Saturday, September 30, 2006 6:16 PM
( #96 )
ORIGINAL: HReconRider0909 Alright Ive got a theory but correct me if im wrong because i haven't had the chance to test it out yet Since this setup will cause the bike to run lean a little bit wouldnt putting the choke on kind of balance out the effect by letting in more gas with about the same amount of air that way you dont have to completly rejet it just for a few seconds of nitrous. I would think that would be overkill and run to rich, thuss lowering HP and stalling in the mud. maybe if you had a lever like a hot start to control the choke while steering and throttling and pushing the button. (sounds like the starting sequince on an older seadoo)[:-]
BigBearMN
Total Posts
432
Reward points
Tuesday, October 10, 2006 4:39 PM
( #97 )
The choke DOESN'T allow more fuel in it restricts the amount of air, there for making it richer. In essence if you put the choke and give it nitrous you just wasted that shot and lost HP not gained.
06 AC 500LE 27 Bi-Tri's Heated Grips, Dyno Jet, Snorkled
YAMAFORD
Total Posts
2540
Reward points
Sunday, October 15, 2006 12:16 PM
( #98 )
A choke PLATE ristricts air but a choke plunger adds fuel. it has its own circuit and jet in most cases. most of us have the latter. Jet skis still use a plate as do most automotive carbs.
shnort33
Total Posts
82
Reward points
Tuesday, October 24, 2006 7:06 PM
( #99 )
i heard that you could use freon like nos what do yall think
ozark820
Total Posts
133
Reward points
Tuesday, November 07, 2006 6:24 AM
( #100 )
Has any one else tried this idea? im pretty sure it will work but im not 2 sure if i want 2 risk it yet any ways i dont really need the power yet either i think id rather wait till i get my 24"-25" gators.
tubbylunchbox
Total Posts
94
Reward points
Saturday, November 11, 2006 2:54 PM
( #101 )
I'm gonna try it. I got the componants on the way. Gonna try this setup to see if it is worth the gain.
2006 Rancher 350 ES 4x4 27" Mudbugs ITP Type 5 Warn 4-2-4 Venom 2500xt Winch 1.5" Homemade Snorkel 1" Wheel Spacers Progressive 512 Shocks HMF Penland Pro Pipe K&N DGL If it ain't broke, fix it till it is.
Luckiduc13
Total Posts
159
Reward points
Saturday, November 11, 2006 9:29 PM
( #102 )
I wanna do it so bad!
2007 Yamaha Grizzly 700 2006 Suzuki LTR-450 ***FORSALE*** 1998 Yamaha Warrior (that needs some attention)
tubbylunchbox
Total Posts
94
Reward points
Sunday, November 12, 2006 12:24 AM
( #103 )
Worst that could happen is burning a hole through a piston.
mudbug660
Total Posts
815
Reward points
Monday, November 13, 2006 8:10 PM
( #104 )
I need a high comp piston anyways.
mach101
Total Posts
126
Reward points
Sunday, November 19, 2006 5:19 PM
( #105 )
i have a honda foreman 500 06 model and when i'am in 4x4 the left makes a noise if i put it in a bind when turning. could any one help me[&o]
swamprider
Total Posts
123
Reward points
Wednesday, November 22, 2006 1:50 PM
( #106 )
ORIGINAL: wass1967 I dump it into the air box before the filter, it mixes with the regular air and does great. Not as big of boost of N2o. Oxygen is not flamable, it just males what ever is burning, burn better. Yah it is... like with an aecitalin (spelling) torch its the oxygen that burns so hot the aceitalin just helps it burn
|^^^^^^^^^^^^| | Budwizer | '|""";.., ___. |_..._...______===|= _|__|..., ] | "(@ )'(@ )""""*|(@ )(@ )*****(@
jurmy2
Total Posts
13
Reward points
Sunday, December 10, 2006 1:07 AM
( #107 )
I agree and disagree. I'm not good at science studies...but...I thought burning was a oxidizer (spell. check) mixing with a fuel and creating a product.(fire etc.) People say oxygen isn't flamable because it is already your oxidizer, if you input it as your fuel too it does nothing. On the other hand, as it has been stated, if pure oxygen touches something it dosen't like...It is highly flamable. No starter is required. Where i disagree is that i do not believe oxygen burns. (there is a difference between flamable and burning...i think) I beleive that the fuel burns and oxygen just completes the reaction to form the product. Having the potential to cause that reaction without an outside energy source(a spark or w/e) gives it both characteristics at once.... I have no idea what i just said. [sm=lol.gif] Any comments?
06 Rincon 26" Mudlights, Custom intake and exhaust snorkle, Stick Stoppers, Reverse override.
hondarider05
Total Posts
2528
Reward points
Sunday, December 10, 2006 11:23 AM
( #108 )
ORIGINAL: jurmy2 I have no idea what i just said. [sm=lol.gif] Any comments? i agree !
02 450 foreman 3 inch cwc lift cwc intake and vent line snorkel ss rims,back seat,2 dry boxes,warn winch,custom brush guard,custom exhaust pipe. gear reduction ,new paint,oil cooler relocated 29.5's locked front chunk. blinky lights. 84 chevy 4x4-10 inches,40's,big block and big bumper!!!
hondarider05
Total Posts
2528
Reward points
Sunday, December 10, 2006 11:28 AM
( #109 )
ORIGINAL: mach101 i have a honda foreman 500 06 model and when i'am in 4x4 the left makes a noise if i put it in a bind when turning. could any one help me[&o]
thats gunna be a outer cv joint there bud.
ragtagranchers
Total Posts
2092
Reward points
Friday, December 29, 2006 6:42 PM
( #110 )
Has anyone tried it yet
85 honda big red build in progress... will be bringing the POW-AHHH
Edog
Total Posts
5
Reward points
Thursday, January 25, 2007 9:38 PM
( #111 )
ORIGINAL: mossy600sport i think ya sell alot of them for 45 dollars what ya got to loose Rings and a Pistion[:D]
<message edited by Edog on Thursday, January 25, 2007 9:41 PM>
DANGER1049
Total Posts
98
Reward points
Friday, January 26, 2007 11:00 AM
( #112 )
If your going to spray do it right the first time. ON fuel injected machines you could put a dry shot of nitrous on it.If it was me I would go woth the wet!!
06 YAMAHA KODIAK 450 Cheap snorkels 25inch Mudlites EPI comp. stall kit Power tip Skull shifter Other toys 02 yamaha R6, 01 Yamaha yz250F PRECISION CYCLES 910-791-6111 FORTY EAST SILKSCREEN 1-866-691-3104
foresnork03
Total Posts
255
Reward points
Sunday, January 28, 2007 1:12 AM
( #113 )
i do air conditioner work and that inflator gun is the exact same thing that we use to unclog drain lines the name on them is gallo gun right i may have to pick up an extra one at teh supply house for that !!!!!!ur a redneck genious!!!!!
91CavGT
Total Posts
401
Reward points
Sunday, January 28, 2007 10:47 AM
( #114 )
ORIGINAL: Edog ORIGINAL: mossy600sport i think ya sell alot of them for 45 dollars what ya got to loose Rings and a Pistion[:D] As long as you are jetted properly, run premium gas (if you usually run 87 octane in your quad), and keep the shot small then you'll have no problems. I have personally ran 10 cartridges through my Ozark. It is only about a 2 hp shot, and as it is right now my Ozark only has about 15 hp so if anything, my little 250 cc motor should have problems before the larger bore machines.
2005 Suzuki Ozark, modded SOLD 1991 Honda Fourtrax 300 4X4 - mine Dirt Cheap Fourtrax Build 1982 Suzuki LT125 - one of my son's 1983 Suzuki LT125 - my other son's 198X Suzuki LT185 - The wife's
91CavGT
Total Posts
401
Reward points
Sunday, January 28, 2007 10:49 AM
( #115 )
ORIGINAL: foresnork03 ur a redneck genious!!!!! This is not the first time someone has called me a redneck genious!! [:D] Thanx!!
jones8615
Total Posts
750
Reward points
Monday, February 05, 2007 11:25 AM
( #116 )
I'm very curious about this but I'm no crash test dummy has anyone tried this on a large bike I have a 680 sounds like it make me the ticket I need some time in the heavy stuff
farmboy 300
Total Posts
34
Reward points
Friday, February 09, 2007 11:55 AM
( #117 )
SOLD TO WOLVY 92 300 fourtrax with 28 inch mud bugs mostly stock its his problom now! wire ties hold it together
1muddyvinson
Total Posts
621
Reward points
Friday, February 09, 2007 7:42 PM
( #118 )
ive tried it on my vinson it made a difference but not a huge gain.
2006 Vinson Auto on mudbugs 1998 polaris sportsman 500 on outlaws
Rafy0202
Total Posts
3604
Reward points
Sunday, February 25, 2007 9:36 PM
( #119 )
Ok guys I wanna try this on my 700! I think I know how to make it......so you think If I run 93 octaine fuel and I have a dynojet jetkit.......so you think ill ba alright??
TEAM GREEN MACHINE #93 08 Renegade X
Rafy0202
Total Posts
3604
Reward points
Monday, February 26, 2007 5:07 AM
( #120 )
and where can I find the pump thing?? walmart only has a hand pump.....anyone know where I can buy one???
