Lockedrzr vent lines
wvMOUNTAINMAN750
  • Location: the hills of west by god virginia(morgantown)
2010/03/09 07:10:44 (permalink)
rzr vent lines
I heard there is 8 but all I can find is 7. I got the 4 behind the seats, the crank case vent(the one with the slit) front diff, and rad over flow. What am I missing? Thanks guys!!!
Montani Semper Liberi
rzr
brute
big red
13 Replies Related Threads
    floridacrakr
    Re:rzr vent lines 2010/03/09 08:29:01 (permalink)
    wow! if thats true i missed a bunch of em. i got the two tranny lines, and front and rear diff. ill be watching this thread for sure.
    07 GRIZZLY 660- SOLD!!
    28" silverbacks (skinnies)
    Custom Snorkel  x3
    HL springs
    HL Super Duty Clutch Kit
    HMF Swamp Series
    Radiator racked
    2011 Polaris Ranger 800
    "Rack Deep Red"
    All Jacked Up ATV snorkels
    5000# viper winch
    31 skinny laws wrapped on MSA diesels
    SouthBossierGrizz
    Re:rzr vent lines 2010/03/09 08:43:07 (permalink)
    Front diff, rear diff, gas tank, two transmission vents, slit in crankcase breather, radiator overflow, that's it.
    superbrute
    Re:rzr vent lines 2010/03/09 09:29:30 (permalink)
    SouthBossierGrizz
    This is it. The only other thing I did was drill and tap the weep hole for the water pump and ran a line up. This wasn't to vent the weep hole, only to stop dirt from getting in it. I installed a clear tube with a slight sweep in it to see if any coolant develops. The water pump seals are really prone to leaking when mud riding. Oh, I also installed a drain plug in the belt housing and the air filter box. Grizzly drain plugs work great.
    DSB
    2012 RZR 900xp, 31's, Yeti
    08 Canam Outlander, 29.5's
    wvMOUNTAINMAN750
    Re:rzr vent lines 2010/03/09 09:30:31 (permalink)
    ok that helps, I was going crazy lookin for the 8th!!!!!! the rear diff, gas tank, tras vents those are the 4 behind the seats in the frame correct? thanks for clearin that up southbossiergrizz!! lol floridacrakr I would be checkin on that
    rzr
    brute
    big red
    wvMOUNTAINMAN750
    Re:rzr vent lines 2010/03/09 09:32:49 (permalink)
    superbrute you talkin bout the hole in the jug?
    rzr
    brute
    big red
    SouthBossierGrizz
    Re:rzr vent lines 2010/03/09 10:11:11 (permalink)
    Didn't think about the weep hole in the water pump seal, however, I never bother with it, just change it out once it starts leaking.
    Silveradols
    Re:rzr vent lines 2010/03/09 10:47:52 (permalink)
    what r the 4 vent lines that go in to the frame behind the seats?
    superbrute
    Re:rzr vent lines 2010/03/09 11:03:12 (permalink)
    The weep hole is on the passenger side of the engine behind the oil filter. You will see where the radiator hose goes in. There is a hole on the side of the casing below that. I think the 4 vents in the frame are the gas tank, transmission, transfer case and rear diff. The front diff is tucked up under the hood area.
    DSB
    floridacrakr
    Re:rzr vent lines 2010/03/09 11:24:42 (permalink)
    wvMOUNTAINMAN750
    yeah, no kidding. so much for a complete kit!
    Custom Snorkel  x3
    HL springs
    HMF Swamp Series
    Radiator racked
    "Rack Deep Red"
    5000# viper winch
    floridacrakr
    Re:rzr vent lines 2010/03/10 09:04:57 (permalink)
    the one hose with the slit in it, what are you supposed to do with it? just extend it as well.  i thought i read somewhere it needed a t fitting or something? i gotta take a look this rzr and see whats going on with these other lines!
    Custom Snorkel  x3
    HL springs
    HMF Swamp Series
    Radiator racked
    "Rack Deep Red"
    5000# viper winch
    3012red
    Re:rzr vent lines 2010/03/10 16:01:49 (permalink)
    My gas tank vent ran up beside the tranny shifter.
    Silveradols
    Re:rzr vent lines 2010/03/10 19:14:22 (permalink)
    my gas tank vent runs towards the front of my rzr.  I haven't followed it yet 2 see where it goes.
    wvMOUNTAINMAN750
    Re:rzr vent lines 2010/03/12 10:46:00 (permalink)
    cut the slit out and put a fitting or just run a new hose
    rzr
    brute
    big red
