question about outlander lift kit and how to fix my snow plow sagging problem
bluegrizzly
2018/01/09 20:57:52 (permalink)
Hello,
I have a 2013 Outlander 1000. I have a moose 60" plow with the center mount under the machine. Every time i am plowing and i put the machine in reverse my plow bangs off the ground because the front suspension is so soft. I even tried cranking the shocks up to the stiffest setting it still didn't help. I was wonder what everyone has been doing to fix this issue? I have been thinking about going with a small lift kit, but i don't know if i should go with a bracket style lift kit or just a puck style lift kit that goes under the shock. I don't want it to ride terrible, but a little stiff won't bother me.
The reason's i want to do this.
#1 to fix this snow plow issue
#2 to get the front end to stop hitting on every single rock
#3 So my plow mount quit's hitting when i am crossing logs or rail road tracks
#4 to try to clear 30" tires because i have an extra set for my Maverick. If i can't clear 30's whats the biggest size i can clear?
Thank you for any help.
AkA 4x4quad joined in 02
2012 Outlander 1000 XT 27" Zillas, ITP SS 108's, UNI
10 Replies Related Threads
    doveman1
    Re: question about outlander lift kit and how to fix my snow plow sagging problem 2018/01/10 02:21:23 (permalink)
    A lift kit isn't going to do much as far as carrying that much weight. You could dump a load of money and find some aftermarket shocks but I would try a set of Highlifter Lift springs for a fraction of the cost. They are stiffer than stock, increases carrying capacity, and give some where around an inch of lift.
    I'm no expert on the Outlander, but you shouldn't have trouble clearing 30in tires, might have to do some fender trimming.
    Green 2015 Grizzly 700
    2in HL lift
    N2deep battery relocation
    Wild boar radiator relocation
    BUSHHOG
    Employee
    Re: question about outlander lift kit and how to fix my snow plow sagging problem 2018/01/10 11:29:45 (permalink)
    I suggest you buy our overload lift springs at $139.95. Part number SPRCFOL-S. They should do the job. In stock.
    Dan Doughty
    bluegrizzly
    Re: question about outlander lift kit and how to fix my snow plow sagging problem 2018/01/10 18:44:44 (permalink)
    Can i combine those lift springs with a bracket lift kit?
    I was also thinking about buying these, but they are a little more money than i want to get into.
    https://www.amazon.com/Can-Am-715001471-ATV-Fox-Shocks/dp/B00BDJ7KSM
    Next question can i run these Renegade shocks with a bracket lift on my Outlander 1000?
    BUSHHOG
    Employee
    Re: question about outlander lift kit and how to fix my snow plow sagging problem 2018/01/11 08:20:32 (permalink)
    Yes, you can run the springs and lift together with no issues. I do not know the answer to your shock question.
    Dan Doughty
    bluegrizzly
    Re: question about outlander lift kit and how to fix my snow plow sagging problem 2018/01/11 22:01:04 (permalink)
    Bushhog running them together won't cause axle issues?
    BUSHHOG
    Employee
    Re: question about outlander lift kit and how to fix my snow plow sagging problem 2018/01/12 09:32:13 (permalink)
    No. What causes axles issues most of the time is oversize super aggressive mud tires, poor driving decisions, heavy thumbs and of course two six-packs of beer. The springs by themselves cause zero axle problems. Lift kits increase the opportunity of breakage over a stock bike, but certainly that does not mean your axles will break with a lift. Drive smart and more than likely you will be fine.
    Dan Doughty
    Re: question about outlander lift kit and how to fix my snow plow sagging problem 2018/01/13 09:08:25 (permalink)
    Well said Bushhog.
    bluegrizzly
    Re: question about outlander lift kit and how to fix my snow plow sagging problem 2018/01/17 21:25:49 (permalink)
    Does anyone know if i can run the fox shock with a bracket lift? I just don't want my axle angles to be terrible and be breaking axles all the time. I don't do a lot of mudding i have 27" zillas.
    Re: question about outlander lift kit and how to fix my snow plow sagging problem 2018/01/17 22:28:02 (permalink)
    You need to just gets the measurements of the shock eye to eye. If they the same length then yes. If longer than an 1" max maybe even 1/2" I'd say no. Now if the fox shock is the same as the lift plus factory shock then just run the shock by itself. I'm sure the HL lift is designed to run with the stock length shock and axles be safe as long as you have good thumb control.
    85o h0 SporTsMan
    Re: question about outlander lift kit and how to fix my snow plow sagging problem 2018/01/29 11:00:33 (permalink)
    I had a modded 50" moose country plow that sagged my old 2000 Polaris 425 Xpedition pretty badly. To overcome this issue I bought a set of the EPI heavy duty suspension springs which did take quite a bit of sag out, but it still sagged 2-1/2" or so when I lifted the 100lb+ plow. What I ended up making some 3/4" UHMW spacers to go onto the tops of the springs to pre-load the springs some. This took the sag to a little under an inch and really made a big difference. I slotted the spacer to slip around the shock rod so i just had to use a spring compressor to remove them in the spring when i was finished plowing. It did ride a bit rough in the winter, but the shocks were not adjustable.
