Lockedqucik question guys...scrambler 850 bolt pattern/backspacing
sawhead
2012/11/22 09:21:47 (permalink)
i did come across the bolt pattern being 4x156 so we are good there,how bout the backspacing though...do the sportsman 850 xp and the scrambler 850 utilize the same wheels?
WOODS RIDING WHEELIE MONSTER
SC850XP...bright white/26.5" growlers on black sportsman xp oem wheels/steering stabilizer
BF650...camo/26.5" growlers on black diablos/vfj stage 2/vfj1 primary/vfj4 secondary/pro circuit t4 full exhaust/dyna/steering stabilizer
Grizzly 450...blue/27" black diamond xtr
Kymco MXU 150...green/cdi/2000 rpm clutch work/kenda klaws/douglas blue label wheels
15 Replies Related Threads
    sawhead
    Re:qucik question guys...scrambler 850 bolt pattern/backspacing 2012/11/25 10:37:05 (permalink)
    anyone know yet
    qdw2008
    Re:qucik question guys...scrambler 850 bolt pattern/backspacing 2012/11/25 10:42:17 (permalink)
    I would assume so they are the same frame
    ITS JUST MONEY
      09 sportsman 800
    29.5" laws on SS 212/2" lift (made by idk)/wild boar racked rad/moose racing filter/champion 2k/front an rear SATV bumpers/snya snorks modifieD
    Just ordered a wiesco programmer a KFI 3500lb stealth winch and building CUSTOM DUALLS >=)
    sawhead
    Re:qucik question guys...scrambler 850 bolt pattern/backspacing 2012/11/25 14:17:50 (permalink)
    i would also assume so,but it'd be nice to know for sure
    BUSHHOG
    Employee
    Re:qucik question guys...scrambler 850 bolt pattern/backspacing 2012/11/27 12:52:20 (permalink)
    yes, same wheels.
    Dan Doughty
    Torque37
    Re:qucik question guys...scrambler 850 bolt pattern/backspacing 2012/11/28 06:06:36 (permalink)
    It would be nice if somone would make a wheel with the correct backspacing for the XP's.
    bobx2
    Re:qucik question guys...scrambler 850 bolt pattern/backspacing 2012/11/28 17:49:46 (permalink)
    Torque37
    STI makes one with the correct 6+1 offset. It's the HD2 wheel. It is advertised for the RZR's so you won't find it listed for an XP. I have them on my 850 and I'm right at 50" wide with the Rockers mounted. The wheels are 14 x 7    4/156 bolt pattern.
    2011 XP 850 EPS
    26.5 Pitbull Rockers, STI HD2 wheels, Warn XT25, Ricochet Skids and A-arm Guards, Elka Stage 1 Shocks, QSC kit
    2009 Sportsman 500 EFI HO (wifes)
    26" Bighorns, ITP Delta Steel wheels,
    Polaris 2500 lb winch
    canuk
    Dirt Monster
    Re:qucik question guys...scrambler 850 bolt pattern/backspacing 2012/11/28 19:01:48 (permalink)
    I was told the rzr rims won't fit on the xp, diff bolt pattern
    2012 Polaris 850xp
    Polaris winch
    Custom rear Polaris bumper
    Moose front bumper
    28" Mega Meyhams
    Rhino front axles
    Polaris hand guards and hand warmers
    hbchad
    Re:qucik question guys...scrambler 850 bolt pattern/backspacing 2012/11/28 19:28:36 (permalink)
    canuk, it's the same bolt pattern - but the stock rzr rims are 12" and they won't clear the calipers on the XP...gotta have a 14" to get around the brakes...
    2012 rzr-s
    31" outlaws
    bunch of other stuff...
    2012 Ranger Crew
    6" Outkast
    34" Terms
    even more other stuff...
    Going deep on TheNattyBoys youtube channel
    sawhead
    Re:qucik question guys...scrambler 850 bolt pattern/backspacing 2012/11/28 20:40:06 (permalink)
    thanks dan...so if a guy doesn't wanna go wider in width on an xp or the scrambler,they basically got oem wheels or these hd2 huh....pretty much anything else is gonna make it 2" wider correct?
    this also scratches my idea of being able to use my 26.5 growlers on the popo due to them being 12"...dang it
    post edited by sawhead - 2012/11/28 20:44:10
    canuk
    Dirt Monster
    Re:qucik question guys...scrambler 850 bolt pattern/backspacing 2012/11/29 07:16:17 (permalink)
    Thanks, my dealer did not tell me that just said they were different, good to know
    2012 Polaris 850xp
    Polaris winch
    Moose front bumper
    28" Mega Meyhams
    Rhino front axles
    sawhead
    Re:qucik question guys...scrambler 850 bolt pattern/backspacing 2012/11/29 22:35:22 (permalink)
    ok,so on an 850 xp/scrambler with oem wheels,do you think some 26.5 or 27.5 growlers will fit with no rubbing?
    i know it will clear the footrests,but will they clear the sway bars/mounts and ball joints and such?
    bobx2
    Re:qucik question guys...scrambler 850 bolt pattern/backspacing 2012/11/30 13:28:40 (permalink)
    sawhead
    If you are asking if 26.5 will fit an XP with OEM wheels, the answer is yes. If you are wondering about the Scrambler, sorry, I have no idea. I had my 26.5 Rockers mounted on my OEM aluminum wheels before buying the HD2's.
    2011 XP 850 EPS
    sawhead
    Re:qucik question guys...scrambler 850 bolt pattern/backspacing 2012/12/02 18:25:07 (permalink)
    nice...thanks bobx2
    i will most likely get the oem wheels you have as i don't wanna go wider or run the oem scrammy wheels...they are ugly
    LawsUP
    Re:qucik question guys...scrambler 850 bolt pattern/backspacing 2012/12/02 18:46:36 (permalink)
    So your gonna buy a 13 k machine and you are worried about running the same wheels and tires... Na bra if you got the money to spen on a machine like that don't worry bout that.. Just judging by the amount of bs post you have made lately on the forum about them your gonna get one? Terrible choice!!!!
     Boozin and boggn....
    Team Viagra...We play hard all day!
    sawhead
    Re:qucik question guys...scrambler 850 bolt pattern/backspacing 2012/12/03 21:44:15 (permalink)
    it isnt 13k around here either...same price as the xp which is cheaper than a gade...sorry you don't like the scrammy,i don't like the gade...such is life
    i also see pros and cons in a number of quads and lots of different riding styles
    post edited by sawhead - 2012/12/03 21:46:54
