High Lifter Forum
Forum Navigation
 please help!
Author Message
BASTROPBRUTE
  • Reward points : 0
please help! - Tuesday, March 09, 2010 2:34 PM ( #1 )
I have a 07 brute 750. I went riding this weekend and when I am crusing with the bike in two wheel drive it is going into 4 wheel drive. I got stuck in a mud hole and four wheel drive would not stay engauged!!!  I this it is my controller or the electric motor on the diff. any one had this problem???  How can i run some test to find out what it is. I did the relay mod 6 months ago I dont think that is the problem.
Resquedude
  • Reward points : 0
Re:please help! - Tuesday, March 09, 2010 2:36 PM ( #2 )
Maybe the acuator .. check it for corrosion etc..
phreebsd
  • Reward points : 0
Re:please help! - Tuesday, March 09, 2010 3:02 PM ( #3 )
check under your fusebox. 2 connectors. check wires for corrosion
2008 Brute 750
31" Laws
Black ITP SS212's
Relocated Radiator
TwinAir Filter
PC III
HL ICM
HL Lift Springs
HL 7" Lift
HL 3GX Belt
Pink Primary
Yellow Secondary
MIMB Snorkles
Temp Gauge
HMF Swamp Series Exhaust with Snorkel
Viper Max 4000 with Amsteel Blue
Visit the New! MudInMyBlood Forums!
 TEAM ROLLIN' DEEP 2010
BASTROPBRUTE
  • Reward points : 0
Re:please help! - Thursday, March 11, 2010 6:51 AM ( #4 )
No corrosion! This brute has only been wet a few times. I dont think corrosion would make it kick into 4wd when the switch is in 2wd. Is there a way test the controller??? If i take the acuator of and switch the switch what is the delay time??? does the bike have to be moving for it to go into 4wd???
Masher
  • Reward points : 0
Re:please help! - Thursday, March 11, 2010 9:18 AM ( #5 )
You should be stopped then select 4wd then slowly roll forward and it will engage.  Don't jump in a hole a bind the system then put it in 4wd and slam the throttle if you like your front diff.  It is probably an actuator problem but check under the selector switch and clean that area out real good.  Mud will pack in underneath it and cause problems.
2008 Brute Force 750 FI
Full Muzzy
31" Outlaws 9.5 Front 11 Rear
14" ITP SS112s
2" Xtreme Lift
HL 1.5" Wheel Spacers Front
EPI Red Secondary
2500 Warn Winch
PCIII
Diarrhea Slingers ATV Club!
Let Her Eat!
BASTROPBRUTE
  • Reward points : 0
Re:please help! - Thursday, March 11, 2010 12:06 PM ( #6 )
THANKS MASHER!!!  You sure know how to make someone feel stupid!!  All this info of what i dont need to do and no help on fixing the problem!
ThaMule
  • Reward points : 0
Re:please help! - Thursday, March 11, 2010 1:01 PM ( #7 )
he wasnt being a rude.  So many people get on here and commit the same things over and over again and dont know that they are doing something wrong.
The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants - Thomas Jefferson
07 Brute Force
10" CATVOS LIFT
29.5" LAWS
DYNATEK CDI
V-FORCE JOHN STAGE 3 CLUTCH
SNORKED
K&N AIRFILTER
ITP SS112
GORILLA AXLES
ODI GRIPS
840BBK
MUZZY PRO EXHAUST
Masher
  • Reward points : 0
Re:please help! - Thursday, March 11, 2010 1:17 PM ( #8 )
You asked does the bike have to be moving to go into 4wd.  You got an answer and that would be considered pretty much a noob question.  I figured that out after being on my bike for 20 minutes.  If I wanted to be rude I would have told you to use the search function because there are probably no less than 250 threads on this issue.
Full Muzzy
14" ITP SS112s
2" Xtreme Lift
EPI Red Secondary
2500 Warn Winch
PCIII
Let Her Eat!
GABoy08
  • Reward points : 0
Re:please help! - Thursday, March 11, 2010 3:25 PM ( #9 )
hey man, i just rebuilt my front end and when i plugged my wire going to the actuator back up, mine was switching from 2 to 4 wheel drive all day. i think we have the same problem and its just a bad connecting in the plug or a wire possibly broke at the actuator.
'08 Brute Force, 30 in Silverbacks, Mud Slinger Exhaust, 2 in lift, 3000 pound Ramsey winch, EPI Mudders Edition Clutch Kit, K&N Air Filter, Extreme Snorkels,
      TEAM DEEPWOODS
SSTOGI
  • Reward points : 0
Re:please help! - Thursday, March 11, 2010 3:39 PM ( #10 )
Your selector switch on the handle bars could be full of mud. The little rubber boot on the switch doesn't last long.
BF750 BUILT FOR BUSINESS
Stock is for pansies
TFFTR1
  • Reward points : 0
Re:please help! - Thursday, March 11, 2010 3:40 PM ( #11 )
My problem was a seized cross pin for the spiders. just my  .02
http://www.quadsforchrist.net/index.php
**THE ESSENCE OF DESTINY**
Watch your thoughts,for they become words. Choose your words, for they become actions. Understand your actions, for they become habits. Study your habits, for they become character. D
Masher
  • Reward points : 0
Re:please help! - Thursday, March 11, 2010 6:19 PM ( #12 )
SSTOGI
Yep, I told him that as well.
Full Muzzy
14" ITP SS112s
2" Xtreme Lift
EPI Red Secondary
2500 Warn Winch
PCIII
Let Her Eat!
Current active users
Icon Legend and Permission
  • New Messages
  • No New Messages
  • Hot Topic w/ New Messages
  • Hot Topic w/o New Messages
  • Locked w/ New Messages
  • Locked w/o New Messages
  • Read Message
  • Post New Thread
  • Reply to message
  • Post New Poll
  • Submit Vote
  • Post reward post
  • Delete my own posts
  • Delete my own threads
  • Rate post
