Hot!need some honda info
newfieguytony
2018/06/12 11:13:49 (permalink)
hello all new here quick question will  stator from 1991 honda fortrax 300 4x4 work on 1991 honda fortrax 300 2x4 thanks for any help
6 Replies Related Threads
    Re: need some honda info 2018/06/12 12:16:44 (permalink)
    Do the stators have the same poles?
    Re: need some honda info 2018/06/12 12:20:48 (permalink)
    And to answer your question yes 88-95 should cross. Count the poles to make sure.
    newfieguytony
    Re: need some honda info 2018/06/12 13:12:03 (permalink)
    i have no clue i live in middle of nowhere lol and closest i can find is whole motor but its 4x4 and its hr and half away was hoping someone whould know before i took the drive
    Re: need some honda info 2018/06/12 13:43:05 (permalink)
    Hey I was driving when I read your message. For some reason I thought you said you had a 90 and was looking at a 91. Yes definitely a stator from a 4x4 will fit on a 2x4. My apologies for any confusion.
    newfieguytony
    Re: need some honda info 1991 honda fortrax 300 2x4 2018/06/16 09:45:45 (permalink)
    hello all new here needing some help i have 1991 honda fortrax 300 with no spark ive replaced cdi voltage regulator and yesterday recieved pick up coiland stator got it put on got case put back on when i turn key reverse light comes on and its stuck in reverse tried everything to get it in neutral no luck nothing appears to be broken any ideas as to why its stuck or what i can try toresolve this issue many thanks to all
    Re: need some honda info 1991 honda fortrax 300 2x4 2018/06/16 09:53:15 (permalink)
    Ok when you say stuck in reverse do you mean on the lights or in the transmission?
