Lockedneed help! how to remove rear wheel bearings?
outlander800josh
2010/05/04 16:44:42 (permalink)
i have my hub off and i dont know where to go from there. i am trying to check the bearing to see what it looks like because i have a bobble in my rear wheel. and are there 2 bearings on each side or just one?
2006 can am outlander 800xt
dalton clutch kit
uni air filter
hmf utility pipe
dobeck power programmer chip
stealth snorkle, soon to be full snorkled this winter
29.5 outlaws itp ss212 black rims
rad kit this winter
1" custom pipe lift
20 Replies Related Threads
    gunmetalbluecat
    Re:need help! how to remove rear wheel bearings? 2010/05/04 16:57:16 (permalink)
    if you are trying to check the bearings the easiest way is to have the hub and tire on, lift the rear off the ground and see if you can move the tire back and forth.  there is only 1 bearing on each side.
    outlander800josh
    Re:need help! how to remove rear wheel bearings? 2010/05/04 17:15:34 (permalink)
    yeah i did that. the wheel seems to be moving back and forth when i get to a higher speed and the tire is hitting the fender and it never did that before. how do you remove the bearing from the point i am at now?
    dalton clutch kit
    uni air filter
    hmf utility pipe
    rad kit this winter
    1" custom pipe lift
    gunmetalbluecat
    Re:need help! how to remove rear wheel bearings? 2010/05/04 17:50:45 (permalink)
    you have to remove the entire trailing arm and press the bearings out.  you remove them by taking the black rubber cap off the top part of the trailing arm by the gas tank. behind that cover you will find a large snap ring and a nut that holds the trailing arms to the frame (you do need a special tool to remove this nut just fyi) with the trailing arms off you can press the bearings out and press the new ones in.
    outlander800josh
    Re:need help! how to remove rear wheel bearings? 2010/05/04 18:03:24 (permalink)
    what is special tool needed to take the nut off?
    dalton clutch kit
    uni air filter
    hmf utility pipe
    rad kit this winter
    1" custom pipe lift
    BigRob21
    Dirt Monster
    Re:need help! how to remove rear wheel bearings? 2010/05/04 18:14:11 (permalink)
    you broke the cast iron iron piece on the trailing arm torsion bar. take the rubber boot off and you will see it. I think its a 1 1/16 nut to get it out. get me a second i show you a pic of it.
    08 Outlander 800 xt
    Snorkeled  & Rad Relocated
    Bracket lift/pipe lift
    3GX Belt
    Mod factory exhaust & K&N air filter
    Ricochet skid plates
    31"Laws
    Wife's
    07 Grizzly 700Fi With Power steering
    29.5 Laws
    3GX belt
    BigRob21
    Dirt Monster
    Re:need help! how to remove rear wheel bearings? 2010/05/04 18:17:09 (permalink)
    08 Outlander 800 xt
    3GX Belt
    31"Laws
    Wife's
    29.5 Laws
    3GX belt
    gunmetalbluecat
    Re:need help! how to remove rear wheel bearings? 2010/05/04 18:20:07 (permalink)
    i dont have a picture but the part number is 529035925.  also i forgot to mention when you pull the black rubber cap off the trailing arm you will first need to remove the torsion bar. not a huge deal just remove the nut from one side a persuade it out with a rubber hammer or a block of wood and larger hammer.
    outlander800josh
    Re:need help! how to remove rear wheel bearings? 2010/05/04 22:53:00 (permalink)
    so that picture posted is the tool needed?
    dalton clutch kit
    uni air filter
    hmf utility pipe
    rad kit this winter
    1" custom pipe lift
    gunmetalbluecat
    Re:need help! how to remove rear wheel bearings? 2010/05/04 22:59:59 (permalink)
    no that is the piece that holds the torsion bar inline with the trailing arms, well that is a broken one anyway hopefully yours is not broken.
    outlander800josh
    Re:need help! how to remove rear wheel bearings? 2010/05/05 22:11:34 (permalink)
    i sure hope not but thanks for the info ill be back to let you know how it goes
    dalton clutch kit
    uni air filter
    hmf utility pipe
    rad kit this winter
    1" custom pipe lift
    NWT420
    Re:need help! how to remove rear wheel bearings? 2010/05/06 09:29:37 (permalink)
    hheres a pic of the spanner socket i made.....not pretty,but works!!!
    http://forum.highlifter.c...oad.axd?file=0;3632202
    post edited by NWT420 - 2010/05/06 09:32:01
    '09 800R outty XT 27" MudLite XTR
    '08 outy 650 XT stock,
    '06 banshee,trinity racing stroked 421,HORNY lil bas+erd!!
    -project bombi!1960 bombardier custom nodwell,ongoing!
    -1968 bombardier J5,265 chrysler flathead,
    ridinred9106
    Re:need help! how to remove rear wheel bearings? 2010/06/07 09:44:40 (permalink)
    Has anyone replaced the bearing without pulling the trailing arm? Can some one PM me a link to where i can get the socket to pull them?
    Mine- 14 Polaris RZR 800 S LE
    Hers- 03 Yamaha Warrior 350
    10 Polaris RZR 800 LE EPS
    05 Honda Foreman 500
    LouisianaMudPlaya
    Re:need help! how to remove rear wheel bearings? 2013/03/12 17:40:38 (permalink)
    In stead of making a new tread ill bring this on back to life. Is there any way to get the bearings out with out a press?
    30" Moto Monsters
    MSA Black Diesels
    Snorkles
    HMF
    Gorilla Rad Relocated
    Dynojet Power Commander
    Dayco XTX Belt
    2011 Teryx Special Edition (silver)
    29.5 Terms
    Snorkles
    GYPSY400
    Re:need help! how to remove rear wheel bearings? 2013/03/15 04:51:49 (permalink)
    No, you will need a special socket to remove the arm.. And a press to get the bearing out.. There is also a snap ring holding the bearing in which needs a flat screwdriver to get out.
    If you have the right tools it's a pretty easy job.
    post edited by GYPSY400 - 2013/03/15 04:53:40
    2003 BRP Outlander 400
    26" XTR's on Stock Wheels
    cuz Chrome don't get ya Home!!
    My Can-Am 400 Website
    Give 'er all she can suffer!!!
    sevenmag
    Re:need help! how to remove rear wheel bearings? 2013/03/15 05:07:35 (permalink)
    Where do you get the special socket to take the nut off?
    2013 1000 outlander max xt
    JPs300
    Re:need help! how to remove rear wheel bearings? 2013/03/15 10:25:29 (permalink)
    Definitely need to pull the arm & put them in a press.
    The bearings are a single "unit bearing" type design with two sets of ball bearings & self-sealing with tandem double lip seals. Nice design, as all wear surfaces including the seal surfaces are on/in the races themselves, thus all fresh when replaced.
    "In2Deep - our drinking crew has a mudding problem"
    '11 Max Limited -
    JPs Customs 4" lift, rad relocate, snorks, & audio tubes, 29.5 law2s on Pilots
    '08 Teryx -
    new build coming...
    http://s455.photobucket.com/user/JPShawgo/library/riding%20pics
    Dezz
    Re:need help! how to remove rear wheel bearings? 2013/03/15 10:38:23 (permalink)
    The only place I know of to get the special tool required to remove the trailing arm is frm the brp dealer. It seems its a different size than any other spanner socket I have ever used. I could not a match for it. Try ebay though...u may get lucky.
    2003 Yamaha Grizzly 660
    Dalton Clutch Kit
    2500 lbs. WARN
    High Strength Axles
    - SOLD - But not Forgotten
    1998 Grizzly 600
    ITP Delta Black Chrome Rims
    4 - Kodiak 450 Clutch weights
    Uni Air Filter
    Warn A2000 Winch
    Oxlite CV joint protectors
    THEmisfit
    Re:need help! how to remove rear wheel bearings? 2013/03/16 21:55:52 (permalink)
    I did mine with the trailing arm still on the bike... Slid my diff back to drop my axles... The bearings came apart so I packed the outter race with dry ice to try to shrink it some... Then took an air hammer and it came right out... Took a socket tht is the same size as the outter race and knocked te new ones in... After it was all said and done I had some dry ice left so I made a few bombs with water bottles and had a field day
    Balls Deep
    *** Renegade- Race Ready
    Clutch'd and Motorwork'd
    PC3
    HMF
    Crushed 29.5 OL2's
    #19
    imback10
    Re:need help! how to remove rear wheel bearings? 2013/03/16 22:51:41 (permalink)
    THEmisfit
    LMFAO!! ^^, sounds like a good time!
     2012 Can Am 1000 XT - Camo
    32.5" OL2's
    14" MSA Pillot Wheels
    HMF XL Series Exhaust
    Airdam /// Primary, STM Secondary
    Mr. Rpm Drop in Cams
    Stateline Customs Arched A-Arms
    Stateline Customs Bracket Lift
    Snorkeled
    Dobeck Fuel Programmer
    K&N Airfilter
    10" Safeglo Light Bar
    Dalton Clutch Kit w/ Black Secondary Spring
    Custom ODI Handgrips
    1994 Honda 300- Blue
    2006 Yamaha Kodiak-(Trail Riding Bike)
    07 Can Am Renegade  ( SOLD)
    Big BLACK, Honda 420 (SOLD)
    #20
    Speedyws6
    Re:need help! how to remove rear wheel bearings? 2013/03/21 13:34:33 (permalink)
    I have changed my rear bearings about 4 times and I never pull the trailing arms off.  I pop the bearings out leaving the race that presses into the arm.  Then I wash out a section of the race with a torch, and it will come right out with a hammer and chisel.   I use a ball joint press to install the new bearings.
    2011 Renegade 800: 6" CATVOS & 29.5" OUTLAWS
    #21
