Lockedmy honda rancher 350 dies when it hit water
bigt5498
Mud Slinger
2010/09/29 09:01:08 (permalink)
why does my fouwheeler die when it hits water i already put die elactirc grease in the spark plug boot and there is no wires showing anywhere what else could it be please help
2005 kawasaki brute force 750 camo
  • 2 inch lift
  • 32 inch silverbacks
  • highlifter rims
  • warn winch
  • snorkels
  • black hmf
  • clutch kit
  • dyno jet kits
  • uni filter
10 Replies Related Threads
    HondaRancherman
    Re:my honda rancher 350 dies when it hit water 2010/09/29 09:51:51 (permalink)
    put dielectric grease on all your electrical connections, plug up the drain plug on the bottom of your carb, make sure ur not running on water instead of gas thats wat i did mine runs fine now
    03 Rancher 350
    27 in Vampires
    12 in ITP rims
    Snake Snorkel
    Dyno Jet
    1.5 Wheel spacers
     FO-4
     audio tube
    FREE STATE BOGGERS
    [link=http://s843.photobucket.com/albums/zz357/cobaltdude8807/?action=view&current=VID0.mp4]http://s843.photobucket.c...w&current=VID0.mp4[/link]
    bigt5498
    Mud Slinger
    Re:my honda rancher 350 dies when it hit water 2010/09/29 13:32:52 (permalink)
    ok ill defently try that and c how it works and body else have any sugestions
    • 2 inch lift
    • highlifter rims
    • warn winch
    • snorkels
    • black hmf
    • clutch kit
    • dyno jet kits
    • uni filter
    camoman33935
    Re:my honda rancher 350 dies when it hit water 2010/09/29 14:00:09 (permalink)
    I see it says you have a snorkel. Did you run your carb vent lines up high too? That could also be it. My buddy has a Polaris and the spark plug boot is screwed up on it and when you hit water with it and it splashes up on the spark plug it shuts off. I would double check and make sure you got a good connection between your spark plug and plug boot and make sure there's still a good bit of dielectric grease in there.
    2006 Honda Foreman 4X4
    29.5 Skinny Laws
    Xtreme Gear Reduction
    Triangle ATV Snorkel
    HMF Utility Series
    K&N Airfilter w/ prefilter
    Dynojet
    bigt5498
    Mud Slinger
    Re:my honda rancher 350 dies when it hit water 2010/09/29 15:46:51 (permalink)
    camoman i filled my boot up yesterday until it was over flowing and i smashed the **** out of it putting it back down on the spark plug and i rode through my pond yesterday when i finished and i went slow as heck that way it would not spash and the water did not ever get up to my spark plug and my bike still cute off
    • 2 inch lift
    • highlifter rims
    • warn winch
    • snorkels
    • black hmf
    • clutch kit
    • dyno jet kits
    • uni filter
    hopeulikit mudder
    Re:my honda rancher 350 dies when it hit water 2010/09/29 16:44:19 (permalink)
    yeah id check all the lines on the carb, thats wat it sounds like to me!
    I may not have the biggest or baddest but, i wont stay on the hill!
    97 Green 300 Honda 4X4 "lil gator"
    350 Rancher shocks
    27"  mud hawgs
    FO-14 tractor pipe
    Highlifter disc brake kit
    Installed a fan
    EPI Clutch Kit
    2000 red 300 Honda 4x4
    cobra exhuast, 2" lift, 26" wide vamps, snorkle, jet kit
    green 300 4x4 in the makings!! "BIG GATOR"
    red 01 foreman 450 es w 27" exicutioners
    89 350 foreman stock
    lawrence red
    Re:my honda rancher 350 dies when it hit water 2010/09/29 17:23:10 (permalink)
    the CDI box may be getting wet
    ga300
    Re:my honda rancher 350 dies when it hit water 2010/09/29 19:41:55 (permalink)
    sounds like the drain line on the bottom of the carb.did u plug it or does it still have the crappy one way valve in it?
                      the pride
      rzr 570-msa wheels,28 mudlights,wake board speakers,snorkeled.
    sold.09 t-cat.2 pc680 batterys,29.5 laws,black xl2s,b&j rad relocate,snorkeled,green grips,hl temp gauge,sld mod,split audio tube.
    plmcrze
    Re:my honda rancher 350 dies when it hit water 2010/09/29 21:38:36 (permalink)
    It could be the carb vent line or even the tank breather hose. My foreman shut off in the water & I found it was the tank hose that was getting in the water. No vent=no gas. Just my 0.02...
    '04 350 Rancher ES
    26" ITP 589's
    HL 2" lift
    HL Springs
    Custom Jet Kit
    HMF Pipe
    '03 450 Foreman ES
    29.5 Highlifter Outlaws
    14% GR
    HL Springs
    HL 2" Lift
    Dual 50 Ammo Cans
    Viper 3500 Winch
    HC Piston
    Snorkeled
    Custom Jet Kit
    HMF Pipe
    http://i1218.photobucket.com/albums/dd419/plmcrze/450ForemanESProject.jpg
    '08 420 Rancher Project...
    bigt5498
    Mud Slinger
    Re:my honda rancher 350 dies when it hit water 2010/10/01 09:27:41 (permalink)
    ok ill deffently plug my drain hose on the bottom of my carb and c if that helps. thanks for all the help guys i realy appreciate it alot
    • 2 inch lift
    • highlifter rims
    • warn winch
    • snorkels
    • black hmf
    • clutch kit
    • dyno jet kits
    • uni filter
    first one in
    Re:my honda rancher 350 dies when it hit water 2010/10/01 10:38:23 (permalink)
    I'll bet 100 dollars your main vent line on the carb is stopped up with dirt or dirt dobber or is two small.either way the carb isn't getting atmospheric pressure through it so it is venting out the drain on the bottom of bowl.as soon as this drain is covered in water the carb can't vent so it shuts off the fuel. To test this pull the main vent line off at carb and get in the water up to tires but not above carb and it will run. to fix blow out vent line from carb out or make sure it not kinked if you have to small a line when u snorkeled it that will cause this too...
