Change Page:
< 1234 > | Showing page 2 of 4, messages 61 to 120 of 220
Crazy Louie
Total Posts
10
Reward points
RE: Re: Make a list of common numbers we need
Wednesday, September 06, 2006 12:00 PM
Thanks for the reply. I will check on my buddies 800. Or I mite find a pure polaris header and pipe and put that on. Thanks and have fun!!!
jimmypsp700
Total Posts
33
Reward points
Monday, September 11, 2006 10:38 PM
2002 Sportsman 700 -800 mods -PP/White Bros. silencer -DU Wetlands on Vison 160 2000 Scrambler 400 2x4 -Trail ported & modded -Wiseco .040 over -RcR /HPD Pipe etc...
Crazy Louie
Total Posts
10
Reward points
Thursday, September 14, 2006 8:10 PM
Did the 700 get more power with the 800 snokle and the 800 head pipe? Does the efi require a different map setting? Thanks for the pics to they are a lot of help!!
jimmypsp700
Total Posts
33
Reward points
Friday, September 15, 2006 12:32 AM
Not a lot IMO but it helps. Others have claimed a much noticable difference. You will need to rejet for optimal performace & Re mapp for the EFI units. Jim
SLEDHEAD
Total Posts
1
Reward points
Wednesday, October 04, 2006 5:47 PM
hello. my fan was noisey so i removed the blade and everything under it.i then carefully pryed the case appart. make sure the magnets do not get mixed up as the fan may spin backwards if you do. the bearing is a common bearing used in many roller blade wheels. my local hardware store had a box in the bolt aisle with only 4 different sizes. one of the 4 was the same size, and even had heavy duty seals. the other end of the shaft is a bushing and was in great shape. i then packed the bushing with some good synthetic grease,and now the fan motor is smooth as silk. also the fan blade fit loose over the drive pin. i coated the notch in the blade, and the shaft with heavy duty black gasket maker. installed the fan and clip and coated the end of the shaft and fan with the same sealer. let it set up over night. the fan was never as quiet as it is now, and the gasket maker acts as a shock absorber between the steel drive pin and the plastic blade. the sealer i used should allow the blade to come free if it should ever need to come appart again. the best part was the bearing was only 2.85 and the sealer i had kicking around the garage. sure beats 250.00 from polaris.
mandylink
Total Posts
2
Reward points
RE: Make a list of common numbers we need
Wednesday, October 11, 2006 4:35 PM
I dont know about the 700 sportsman but the 400 sportsman hub bearing race number is made buy timken L44610 The bearing is L44649 And the Strut bearing is L44643. If anyone knows the Timken number for the strut race it would be greatly appreciated.
mandylink
Total Posts
2
Reward points
Wednesday, October 11, 2006 4:50 PM
I need the number for a 400 sportsman strut bearing race from Timken. The bearing number is L44643 Also the hub bearing is L44649 and the hub race is L44610. But i dont know the strut bearing race number need help on that one
THE maniac mechanic425
Total Posts
1575
Reward points
- Location: MINNESOTA,But Currently Stationed in San Diego, CA
Thursday, October 12, 2006 8:06 PM
for those that do not want to pay 20 bucks a gasket, there is a NAPA gasket from idk what that fits your exhaust gaskets. (those donut things) it is NAPA part # 31360
PROUD RIDER OF THE DARKSIDE 2004.5 SPORTSMAN 600 TWIN hunter edition (LIMITED EDITION)heated hand and thumb grips, hand guards, 2.5ci winch, OUTLAW MST's :), brush guard, double tube bumper, K&N filterS, HL temp gauge, semi lifted ... for now... big ole lifted F-150 03 Ninja ZX-6R www.myspace.com/navykid627 LOUD PIPES SAVE LIVES FREEDOM ISN'T FREE, BUT IT'S WORTH FIGHTING FOR PROUD TO BE A U.S. NAVY ENGINEMAN
chvylac
Total Posts
263
Reward points
Sunday, October 29, 2006 5:46 PM
anybody have a part number for ball joint for the front struts??
roade
Total Posts
101
Reward points
Sunday, December 10, 2006 5:37 PM
Dayco HPX Extreme Duty belt for 05 700 efi is part number hpx2204 oem belt is 3211091
pimp800
Total Posts
3530
Reward points
Friday, January 05, 2007 11:41 AM
i know that a 700 belt part #3211091, will work in the 800's, polaris dealer said the 700 belt would not work, but i tried it anyway and no problems, actually i think it pops out of the hole a little better.. the 700 belt is $49 dollars and the belt for the 800 is $90.. so u do the math[:D][:D][:D]
Wobble
Total Posts
53
Reward points
Saturday, January 06, 2007 10:53 PM
Great thread guys, helped me find front and rear drive shaft UJ's for a buddies SP 600 on a saturday night, just got done putting them in. Polaris price $45 each, O'reilly #12 for their precision brand part number 338. It was a PIA job, but what are you going to do when a buddies bike is down?
Mark Killed - 2002 Grizzly, DIY Fully Snorkeled, K&N, Gorrila axles, 28x12.5x12 Outlaws, Dynojet with 165main jet. Kimpex Type 3 bumpers, Warn winch in the trash, 3000lb Harbour freight atv winch , Dual Batteries. 2009 Can-am Outlander xt 800R Camo, Running strong
prairedogg650
Total Posts
2720
Reward points
Monday, January 08, 2007 7:36 AM
any numbers on rear diff bearings on the 04 700's? i saw someone posted axle bearings but those where wheel bearing #'s
SemperVigilo
Total Posts
117
Reward points
RE: Re: Polaris, Super Strength Tie Rod Ends report
Monday, January 08, 2007 8:19 PM
ORIGINAL: Godfather This is the parts I just used in order to rebuild a rear end on a 2003 Sportsman 600. Jew your parts dealers for the best prices. I rebuit this one for less than $90. Beware that if you Penion and Ring gear is bad the best deal I found is $250.00 from Polaris. (Just in case) 2) Bearings - 6010-2RSC3 SRI-2 The brand is KYK 1) Bearing - 6306-2RSC3 SRI-2 The brand is KYK 2) Seals - Polaris PN 3233878 1) Seal - Polaris PN 3233785 1) Bushing - Polaris PN 3233577 1) Qt 90w Gear Oil Praire ^^ should be the same for yours
Mud Mafia We're in tha trash talkin business...... and business is good "DaButcher" 06 800 Sportsman a few goodies Pics
redrockmudder
Total Posts
349
Reward points
Monday, January 15, 2007 6:35 PM
ORIGINAL: SLEDHEAD hello. my fan was noisey so i removed the blade and everything under it.i then carefully pryed the case appart. make sure the magnets do not get mixed up as the fan may spin backwards if you do. the bearing is a common bearing used in many roller blade wheels. my local hardware store had a box in the bolt aisle with only 4 different sizes. one of the 4 was the same size, and even had heavy duty seals. the other end of the shaft is a bushing and was in great shape. i then packed the bushing with some good synthetic grease,and now the fan motor is smooth as silk. also the fan blade fit loose over the drive pin. i coated the notch in the blade, and the shaft with heavy duty black gasket maker. installed the fan and clip and coated the end of the shaft and fan with the same sealer. let it set up over night. the fan was never as quiet as it is now, and the gasket maker acts as a shock absorber between the steel drive pin and the plastic blade. the sealer i used should allow the blade to come free if it should ever need to come appart again. the best part was the bearing was only 2.85 and the sealer i had kicking around the garage. sure beats 250.00 from polaris. i have an 06 sportsman 700 and my fan is also very loud. is this something covered under warranty or not?
WINDROCK ATV CLUB MEMBER ROYAL BLUE RANGER MEMBER 07 Red Yamaha Grizzly 700 FI with Power Steering, Warn 2500, Ricochet skids, Blinkys, UNI, exaust tip, ITP SS 108 and 26" Swamplites, Kimpex rear box with top rails, Kimpex front box, Truck Nutz http://community.webshots.com/user/redrockmudder
xpldavid
Total Posts
110
Reward points
Tuesday, January 16, 2007 1:05 PM
Will the Napa #338 U-Joint fit the front prop shaft? If not, Does anyone have a part # for it?
08 Polaris RZR Snorkel, 3" Lift Polaris 700 28" Outlaws, Home made lift kit, rejet carb, modified airbox, K&N, front & rear steel bumpers, 3000 Ramsey Winch, Rack mount radiator/fan, rear light etc. (The official get everyone out of trouble vehicle)
Hrdrck12
Total Posts
24
Reward points
Sunday, January 21, 2007 3:28 PM
What is the part number for a front wheel bearing in a 06 sp 500 H.O.?
06 sportsman 800EFI warn 2.5, K&N, front brushguard, rear bumper, front & rear rack extenders, handguards, & oury grips,3-way headlight kit, & 26in 589's .06 sportsman 500HO warn 2.5, K&N, front brushguard, rear bumper, front & rear rack extenders, handguards, longer wheelstuds, 800 rims, & 3-way headlight kit.
redrockmudder
Total Posts
349
Reward points
Friday, January 26, 2007 1:43 PM
well the dealer is replacing my radiator fan
gotmuddy
Total Posts
20285
Reward points
Friday, January 26, 2007 9:47 PM
ORIGINAL: xpldavid Will the Napa #338 U-Joint fit the front prop shaft? If not, Does anyone have a part # for it? Yes. However I suggest the neapco version. I went to a driveline shop and asked for a spicer version but he told me the neapco is better because the spicer has fewer needle bearings, and they are bigger. The neapco has more of them, and they are smaller, so the trunion is larger. I believe the part number is 5-170x for the neapco.
My name is Gotmuddy and I have a 300trx obsession. wtb: stock sized tires(25x8x12 and 25x10x12)
bookum
Total Posts
149
Reward points
Wednesday, February 07, 2007 8:12 PM
Just to confirm an earlier post. The exhaust seal from NAPA #31360 Fit my 02, 700 sp. I was $6.90+tax from NAPA. $18.00 from the dealer
Mad Mike
Total Posts
461
Reward points
Sunday, February 25, 2007 7:23 AM
any 1 have a # for the front strut for a 97 500 after market that is
DaButcher
Total Posts
307
Reward points
Thursday, March 01, 2007 5:40 AM
06 800 Sportsman G O R I L L A lift 29.5 Outlaws
holdenfrickenon
Total Posts
20
Reward points
Sunday, March 11, 2007 11:21 PM
Mobil One has a filter for the twins. M1-110 One of there best oil filters. i run one on my 800. I have a filter cutter and I cut all filters apart after an oil change to look inside. Also I determine how well the filter has been made. This is the first Mobil filter I hae run on the 800 and will let everyone know what I think of it after I cut it apart. The stock Polaris filters are made quite well.
05 Sportsman 800, Mudlites, ITP Rims 06 Outlaw 500
MRMARIO2U
Total Posts
4156
Reward points
Sunday, April 08, 2007 6:35 PM
PolarisTodd
Total Posts
838
Reward points
Monday, April 16, 2007 11:42 AM
Sportsman Fan Replacement.. Polaris Part # 2410383 230.00 from Dealer made by SPAL fans. at 1-800-345-0327 their part # is 30100411 for 79.95 Fits the following Applications: 2004 Sportsman 400 2004 Sportsman 500 2005 ATP 500 4X4 2005 Sportsman 400 2006-07 Sportsman 450 2005-07 Sportsman 500 H.O. and EFI 2006-07 Sportsman X2 500 You will have to use your existing shroud.
Polaris 500H.O. Heel Clicker Supertrapp IDSX Full System DynoJet Kit K&N Warn 2.5ci Synthetic Rope Highlifter Lift Springs Swamp Witch 28's Vision Wheels with 1.5" spacers all around. Lot's of MONEY on Polaris required maintenance
MRMARIO2U
Total Posts
4156
Reward points
Wednesday, May 02, 2007 5:22 PM
Mexican Mudder
Total Posts
1624
Reward points
Thursday, May 03, 2007 9:22 AM
Anyone know of a belt for a 600??
PolarisTodd
Total Posts
838
Reward points
Thursday, May 03, 2007 3:13 PM
use the polaris belt
Mexican Mudder
Total Posts
1624
Reward points
Thursday, May 03, 2007 3:37 PM
ORIGINAL: PolarisTodd use the polaris belt Yeah I just won't have much money right now to get one. I was looking for a cheap replacment for now..
gotmuddy
Total Posts
20285
Reward points
Monday, May 14, 2007 1:54 PM
The cheap replacements aren't but about $10 cheaper. I have found that OEM belts are the best to buy.
alwaysbroke
Total Posts
1085
Reward points
Wednesday, May 30, 2007 9:36 AM
Two things I've recently replaced in my 2005 500H.O. Spal fan #3 0100597. You will have to use your shroud and blade. The plug and motor are exactly the same as what comes with the bike. $74.96 plus shipping. Only took 10 minutes to swap the blade and shroud over to the new motor. No cutting or splicing any wires. Spal Phone # 1-800-345-0327 Spal Website: http://www.spalusa.com/ The people at Spal are great. Easy to talk to and soooooooooooo helpful. [:)] Rear Wheel Bearings: Federal-Mogul Bearings 510013 Thanks to polaristodd for the help and info. [;)]
mud baron
Total Posts
90
Reward points
Friday, June 08, 2007 2:44 PM
anyone come up with a thermo-stat for a 05 400........mine keeps getting hung up (i think its warped)....$57from polaris...thats a ripoff....
yellow06700
Total Posts
28
Reward points
Tuesday, June 19, 2007 9:39 AM
in case you need anything to do with boots or CV joints or anything of that nature American CV has all of it the # is 1-866-288-3003
2006 Polaris 700 Twin (Yellow) 2" Highlifter Lift Kit AAEN Mega Power Exhaust K&N Air Filter 27" Mud Bugs on ITP 7 Series Chrome
DaGrizz
Total Posts
20
Reward points
Monday, June 25, 2007 9:44 AM
ANYONE have a number for a fuel filter for 05-700 Polaris EFI. Local dealer wants $40
If your goon be a bear, be a GRIZZLY!
DOZER77
Total Posts
447
Reward points
Thursday, July 26, 2007 10:11 AM
2009 Rhino S/E Black Tunes on TOP Laws on Bottom Piped and cooled high and Blink Blink 2005 Sportsman 800 SOLD a couple of bumpers a pull you out thang Bling Bling wheels and mud slinging tires
bamakc
Total Posts
2
Reward points
Monday, August 13, 2007 5:02 PM
guyroy
Total Posts
1
Reward points
Monday, August 13, 2007 8:00 PM
what about oils? should i keep buying the expensive polaris oils for difs, tranny and engine or is regular oil OK?
PolarisTodd
Total Posts
838
Reward points
Monday, August 13, 2007 8:13 PM
For front diff...YES. On all other as long as it meets minimum requirements you are OK.
KSCFIRE
Total Posts
33
Reward points
Wednesday, August 15, 2007 12:50 PM
It was time for me to replace my front and rear diff seals for my axles. I bit the bullet and purchased Polaris ones. I then took them down to my local seal and bearing shop, Miller Bearing. The guy at the counter measured them and found matches for the front and rear axle seals and the front shaft seal. I didn't have a rear shaft seal with me. The seals are Chicago Rawhide and the part #'s are: Rear axle- 19630 @ $7.14, Front axle- 692461 @ $4.53 and Front shaft- 692321 @ $ 4.04. I forgot to ask if they were single, double or triple lip seal. As for the flat lipped o-rings for the front that were in the seal kit from polaris, I was refered to a local hydralic shop. I was told there they could probably match up those, but would have better luck if I were to bring in the case so they could get a more accurate measurement off the groove in the case. I haven't got a chance to place these next to the Polaris seals yet to compare, but I hope to soon. If they are the same, what a savings. I should also mention this is for my 04' SP700.
<message edited by KSCFIRE on Wednesday, August 15, 2007 12:56 PM>
2004 Polaris Sportsman 700 3.0 Warn 26" MudLites My other ATV is a tank.
KSCFIRE
Total Posts
33
Reward points
Friday, August 17, 2007 6:12 PM
I got the seals today, matched them up at the counter with the parts guy. They're a match. Only one difference is they are single lip not triple. I ask him straight up "Will this make a difference"? He stated that the specs from Chicago Rawhide say the single one is equal. I asked him why the Polaris ones are triple, and he said he believes it's just an extra dust seal. If I get time next week I'm going to tear into my diffs and replace the seals. I'm going to go with the Chicago ones first to give them a try. If them don't work out I'll still have the Polaris ones in reserve. Cross you fingers we might have another $$$ saver.
Dirtbmw20
Total Posts
3893
Reward points
Saturday, August 18, 2007 10:16 PM
ORIGINAL: chvylac anybody have a part number for ball joint for the front struts?? Anybody ever get any info on this ???? I too would love some aftermarket part numbers on some ball joints.
05' Sportsman 500 H.O. Rubber Down 3" Lift Lots of "goodies" I couldn't afford Dirtbmw20's Pics
ouch1175
Total Posts
124
Reward points
Monday, August 20, 2007 8:03 PM
Not likely to find one but what about the coil/plug wire assembly for an 06 500 EFI? Gonna go check the parts store tomorrow.. There has to be a replacement for something (I hope) OEM is 150 bucks?
green700efi
Total Posts
131
Reward points
Tuesday, August 21, 2007 9:16 PM
oil filter for the 06 700 popo wix 51356 but if you get in a bind its the same filter that the 02-06 grizz uses its just a little longer the number on the grizz is 51358 but they are interchangeable
The Bourbon Legends 07 800 sportsman 6" modified monkey lift 25% gear reduction 1.5" pucks on all 4 h.o. headers heelclicker clutch kit jams snorkeled through the box HL temp guage 29.5x12's on visions 1.5" spacers on all 4 hid lights blinky blinky lights powered by jack daniels Snappin' necks and cashin checks
BigAl
Total Posts
398
Reward points
Tuesday, August 21, 2007 9:23 PM
The output seals measure 40X52X8, A 7 WILL WORK TOO. The input seal measures 25X47X8, A 7 WILL WORK TOO. The output bearings are 6008-2RS, ORS brand and the input bearing is 6306-2RS, ORS brand. 2005 and up front diff's
2005 500 POPO Relocated Radiator 28 Laws, spacers 06 EFI Drive Clutch
PolarisTodd
Total Posts
838
Reward points
Wednesday, August 22, 2007 5:51 AM
ORIGINAL: Dirtbmw20 ORIGINAL: chvylac anybody have a part number for ball joint for the front struts?? Anybody ever get any info on this ???? I too would love some aftermarket part numbers on some ball joints. Anybody on Tie Rod ends??
old ranger
Total Posts
102
Reward points
Thursday, August 30, 2007 11:34 AM
Any numbers for water pump seals for a 500?
DOZER77
Total Posts
447
Reward points
Thursday, August 30, 2007 10:01 PM
Newfie Polaris
Total Posts
31
Reward points
Monday, September 03, 2007 7:04 PM
Has any one found a part replacment for the front bearings yet???
PolarisTodd
Total Posts
838
Reward points
Monday, September 03, 2007 7:13 PM
ORIGINAL: Newfie Polaris Has any one found a part replacment for the front bearings yet??? Search this post. there is plenty of info.
223s
Total Posts
91
Reward points
Friday, September 14, 2007 6:57 PM
Has anyone find a source for the Tranmission Switch. Mine is showing a E show I guess it a Error. I can pull the plug out and put it back in and it works for a while but starts messing up when I start shifting again.
ouch1175
Total Posts
124
Reward points
Saturday, September 29, 2007 7:16 AM
Need a starter replacement and avoid that 300$ OEM? I got a starter for my 06 500 EFI with a one year warranty for like 80 bucks shipping and all and it is a 100% match to the OEM one. Apparently this model starter has been used on hundreds of applications. Anyways if you need a starter search for DB Electrical on google and you should find the place no problems or you can call 800-753-2242.. You can also get rebuild kits and all that but just buying the starter was like 15 bucks more.[;)]
polarisgirl400
Total Posts
4
Reward points
Monday, October 01, 2007 12:50 PM
What are the tie rod ends that I would get for an 2000 -500?
Rebel64
Total Posts
2924
Reward points
Saturday, October 06, 2007 8:52 AM
Ring, spring (for front half shaft assembly) # 7710581 Anybody know of an exact match to this? Neither popo dealer around me has this in stock, and that's all I need to get my bike running.
07 800 Stealth Lifted, Lawed, Turners, Triangle snorked, Dirts Rad Bracket, OffRoadSoundSystems split jams...and other stuff.
mud_duck
Total Posts
3457
Reward points
Monday, October 08, 2007 9:59 AM
Sportsman 700 2004.5 fan from Spal, $127.95 You will use only the motor and have to use your original waterproof plug.
Randy Miller Racing R&R Performance ATV Texas Mud Hole Patrol 2010 Mud Nationals: ProA Mud Bog.........3rd 2009 Renegade '04.5 Polaris CLICK My Pics ______________________________________________ I may be old, but I'm not boring
DaButcher
Total Posts
307
Reward points
EFI fuel filter
Wednesday, October 10, 2007 5:23 PM
EFI fuel filter NAPA #3199 will work, but is some smaller.
223s
Total Posts
91
Reward points
Monday, November 05, 2007 12:05 PM
I need fan motor or fan for a 2003 Sportsman 700. Anybody know a # for it. Thanks
popotoys
Total Posts
129
Reward points
Monday, November 05, 2007 12:22 PM
GARYK2303
Total Posts
38
Reward points
Thursday, November 15, 2007 7:19 AM
Hi everyone can anybody tell me where i can get a coil for an SP800. My coil wore through and started shorting out on the frame where it is mounted. In my opinion this part is very poor, i sealed it up with silicone and am currently using it. Prior to sealing it up when it got wet my bike would run terribly without any power. I am thinking about buying a new coil and the spacer that they now are using. Thank you.
2005 Polaris Sportsman 800 , Warn winch , 28" ITP 589's
Crash99
Total Posts
1
Reward points
Thursday, November 15, 2007 4:41 PM
I`m looking for a fan/motor for a 500 HO 2005. Do you have any number to help. The number I saw in the common list was non water proof. Thanks!
PolarisTodd
Total Posts
838
Reward points
Thursday, November 15, 2007 4:51 PM
ORIGINAL: Crash99 I`m looking for a fan/motor for a 500 HO 2005. Do you have any number to help. The number I saw in the common list was non water proof. Thanks! Spal fan #3 0100597. You will have to use your shroud and blade. The plug and motor are exactly the same as what comes with the bike. $74.96 plus shipping. Only took 10 minutes to swap the blade and shroud over to the new motor. No cutting or splicing any wires. Spal Phone # 1-800-345-0327 Spal Website: http://www.spalusa.com/ The people at Spal are great. Easy to talk to and soooooooooooo helpful. [:)] Rear Wheel Bearings: Federal-Mogul Bearings 510013 Thanks to polaristodd for the help and info. [;)]
