Lockedlil 300 build for neighbors kid
Page: 1234 > Showing page 1 of 4
BridelessRacing
2011/12/09 08:40:22 (permalink)
we start dec 5 with a 300 that has the motor removed and the rearend is locked up.
drag a old 90 model 300 out of the back yard for a good motor
cut the frame in half. motor removal 15 minutes.
motor ready to be installed.
Don Oglesby on facebook
usefull
420 gr
117 Replies Related Threads
    BridelessRacing
    Re:lil 300 build for neighbors kid 2011/12/09 08:57:26 (permalink)
    motor is running in this pic
    notice not even a front drive shaft yet and the rearend is still locked up.
    do some maintance to ensure a good engine. new uni air filter. new oil and filter with 5 oz of engine tune up in oil. install front drive shaft and service trans and front diff
    go ahead and tear rearend down. rebuild and reinstall. easy enough. Ride bike around for a little while neighbor decides he wants big tires and a gear reduction. He already knows a stock rearend wont handle the pressure.
    use the tan 300 to drag this foreman around in the front yard because we need the rearend.
    now remove the stock 300 rearend and give it a 2 inch streach.
    then adapt it to tote a foreman rearend [much stronger]
    usefull
    420 gr
    BridelessRacing
    Re:lil 300 build for neighbors kid 2011/12/09 09:05:09 (permalink)
    reinstall every thing. and set height to match 2 inch highlifter lift on front.
    same 26 inch swampers in both pics. Notice fender clerance right behind drivers foot. This bike will now tote wide 28s with no rubbing
    usefull
    420 gr
    BodySnatcher
    Re:lil 300 build for neighbors kid 2011/12/09 09:08:41 (permalink)
    Looks like somebody's been busy
    Don't laugh, its paid for.
    gotmuddy
    Re:lil 300 build for neighbors kid 2011/12/09 12:29:05 (permalink)
    what size gr you going to run?
    Heftysmurf
    BridelessRacing
    Re:lil 300 build for neighbors kid 2011/12/09 17:00:09 (permalink)
    this one
    and i decided since im going to be in the motor any way.
    post edited by BridelessRacing - 2011/12/09 17:05:00
    usefull
    420 gr
    gotmuddy
    Re:lil 300 build for neighbors kid 2011/12/09 17:05:00 (permalink)
    that should be plenty.
    Heftysmurf
    BridelessRacing
    Re:lil 300 build for neighbors kid 2011/12/09 17:11:55 (permalink)
    I would just add a little more
    78.5 mm bore from a 74mm
    usefull
    420 gr
    BridelessRacing
    Re:lil 300 build for neighbors kid 2011/12/09 17:15:32 (permalink)
    whats the stock stroke on a 300?
    usefull
    420 gr
    zedlep
    Re:lil 300 build for neighbors kid 2011/12/09 17:17:45 (permalink)
    Is that just an 18% reduction??
    GatorBoi
    Re:lil 300 build for neighbors kid 2011/12/09 17:19:18 (permalink)
    nice work
    2010 Honda Rancher 420
    Axle Paddle
    2" HL Lift
    ITP SS312 Wheels
    28" Outlaws
    Big Gun Exhaust
    Uni Filter
    Wild Boar Radiator Relocation
    Snorkle
    Greased Diff
    BridelessRacing
    Re:lil 300 build for neighbors kid 2011/12/09 17:28:32 (permalink)
    I dont know the reduction amount. but i do know its enough to pull 27/28 stager in all wides with a stock motor.
    we are kicking around 29.5 laws or 30 backs for this bike.
    but for now it is fixing to go to 25 inch WMA legal gators most likely.
    usefull
    420 gr
    PRESIDENTAIL GRIZZ
    Re:lil 300 build for neighbors kid 2011/12/09 18:02:14 (permalink)
    SWEET
    2014 RZR1000 Nuclear orange (his)
    33 Terms  on 15" MSA 21
    5" lift
    Lights
    Radio
    08 RZR sold
    09 MUD PRO (HERS)
    2.5 RDC LIFT
    32 BACKS
    TUNES
    BLACK & PINK
    PINK LEDS
    ~BIONIC REDNECKS~
    gotmuddy
    Re:lil 300 build for neighbors kid 2011/12/09 18:22:24 (permalink)
    BridelessRacing
    those are 300ex gears so 18%.  If you want 29.5s or 30s with that gr you will need a bbk.
    Heftysmurf
    zedlep
    Re:lil 300 build for neighbors kid 2011/12/09 18:58:08 (permalink)
    Im just not seeing any welding or anything on them are they no usually welded.. Im not sure i dont have one i guess but i hope to soon
    gotmuddy
    Re:lil 300 build for neighbors kid 2011/12/09 19:10:35 (permalink)
    likely it hasnt been welded yet.
    stock stroke is 65.5mm
    Heftysmurf
    zedlep
    Re:lil 300 build for neighbors kid 2011/12/09 19:15:03 (permalink)
    Knew i shouldnt of said anything hahah dummy dummy haha
    BridelessRacing
    Re:lil 300 build for neighbors kid 2011/12/09 21:02:20 (permalink)
    it has been welded then re machined for a smooth look.
    78.5 mm bore x65.5 mm stroke =
    I know this is right at 310 cc but i cant get my math right.
    usefull
    420 gr
    stomper
    Re:lil 300 build for neighbors kid 2011/12/10 07:05:48 (permalink)
    Cylinder volume is bore x bore x stroke x 0.7854
    comes out to 317cc
    Stomper Motorsports
    MMI Grad
    Certified Tech
    #19
    DryCreekBoy
    Re:lil 300 build for neighbors kid 2011/12/10 07:50:16 (permalink)
    thats gonna be an awesome 300 man great work
    #20
    Bump530
    Re:lil 300 build for neighbors kid 2011/12/12 15:01:20 (permalink)
    just a note, which im sure you already know, but dont reinstall the washer behind the primary if that gr is finished.  it APPEARS that the welding was done on the back side and then machined down and the groove (for a lack of a better word) was not left for the washer to ride in.
    ive thought hard bout doing the rancher 350 piston/sleeve in my bike, but just havent brought myself to do it yet.
    Team BS - Bayou Slingers
    '05 Rhino 660 "Riverhino"
    30" Zillas / Black SS212 /  Stereo / Dipped Plastics / 3" Snork / FO-4 / Jetted / ViperMax 5000 / 8000K HIDs / XR Clutchin' / White Spring / Gorillas
    #21
    BridelessRacing
    Re:lil 300 build for neighbors kid 2011/12/18 08:36:09 (permalink)
    yes i cant leave room for the washer when welding in the v grove in the back.
    I tgot around to finally changing the bad front bearing and cv boot last night.
    usefull
    420 gr
    #22
    DryCreekBoy
    Re:lil 300 build for neighbors kid 2011/12/18 08:45:53 (permalink)
    when they gettin bigger tires?
    #23
    Honda420 Rider
    Re:lil 300 build for neighbors kid 2011/12/18 09:39:56 (permalink)
    Hey gotmuddy now that ur talking about gr does this look right u see anything that don't look ok ? Had to take out the washer n get one custom made by turner n all.
    It's a 35 on my 420 any help would be nice
    2012 outty 1000 xt magnesium!
    Gorrila Spacer Lift
    MSA Elixers Wrapped in Outlaw 2s!
    QSC primary/Stm secondary, LTE slip on, Fuel monster, The bom go fast parts (;
    SOLD!
    Ph Customz 12 inch Custom IRS Lift
    m12 Diesels on 30 backs
    Hmf penland
    Wild boar rad relocation
    EPI clutch kit
    Fuel Optimizer
    69% extremes gr!
    K&N
    8K hid's
    #24
    Honda420 Rider
    Re:lil 300 build for neighbors kid 2011/12/18 09:44:37 (permalink)
    Nice build 2 bridelessracing dont wanna steal ur thread but I wanted to ask
    Gorrila Spacer Lift
    SOLD!
    Hmf penland
    EPI clutch kit
    Fuel Optimizer
    69% extremes gr!
    K&N
    8K hid's
    #25
    Expat_Dude
    Re:lil 300 build for neighbors kid 2011/12/18 10:11:26 (permalink)
    That is a great project! Nice work!
    Lifetime Pro Staff Member
    2013 Ranger 900 Sunset red LE
    Summer tires - 30" sand vipers on 15" diesels
    Winter tires - 28" Radial Laws on chrome Kores
    4500# winch
    Polaris roof
    Lock and ride windshield, hardcoat
    Highlifter arched A arms
    Diver down snorkels
    Highlifter steering stop
    Rear DHT axles, 2" lift
    32" Cree front light bar
    12" Cree rear light bar
    Tow Rig- 2015 High Country Dmax
    Toys- 1970 Chevy SWB aka "Ughhh"
    1987 Grand National
    My Pics
    #26
    BridelessRacing
    Re:lil 300 build for neighbors kid 2011/12/18 14:10:01 (permalink)
    Got the 25 inch mud bugs on the back.
    Fixed the vent lines
    Rode it around the yard for a few minutes everything works right except brakes (on a honda what's that)
    In the next few days will build engine. So I can just pull the good running one out and put the big bore gear reduction engine in.
    As for big tires not till hunting season is over unless We can sneak it down to canal road on the 14
    usefull
    420 gr
    #27
    DryCreekBoy
    Re:lil 300 build for neighbors kid 2011/12/18 14:47:07 (permalink)
    awesome great build
    #28
    the300_outlaw
    Re:lil 300 build for neighbors kid 2012/01/05 08:33:00 (permalink)
    with that motor work and if you as a 88 cam with a p&p head you could turn 29.5 in everthing but the gumbo stuff. the i built a motor just like that for a buddy and it did great. better put a oil cooler on it. with that bigger piston it does try to run hot in the summer.
    1993 300 honda, gr, big rims and 32 backs. aka(brute getter)
    green 420( all stock)
    black 420 28s and snorkly for now.
    1996 300 honda. lift and tires
    crf 450 supermoto
    #29
    ol blue 300
    Re:lil 300 build for neighbors kid 2012/01/07 10:54:55 (permalink)
    ya my 300 is bored so and it runs how too i put a fan in front of my head but it still runs hot
    #30
