Lockedhow to reset belt light bruteforce 750?
edmudforce
2005/11/20 08:55:11 (permalink)
does anyone knwos how to reset belt light on brute force 750 i can go over 3600 rpm if light is on i hve replace the belt allready help
2 Replies Related Threads
    Water_Gremlin
    Re: how to reset belt light bruteforce 750? 2005/11/20 13:20:04 (permalink)
    You will not get much responses in the bugs and glitches section since it really have nothing do to with atv's, but more so the forum itself. Repost your question in the kawi section and you will recieve more replies.
    bubsbf750i
    Re: how to reset belt light bruteforce 750? 2006/01/01 21:50:53 (permalink)
    unplug the plug on the right side of the motor it runs to the relay for the tranny then take the seat off and and unplug the black connector right behinde the cdi box and plug the gray connector (right next to black plug) into it turn the key on for 30 seconds then turn off key switch and replace the connectors back it will give u 100 more hours
