Lockedhow to change foreman 500's oil?
dmanMus
2011/02/10 19:31:14 (permalink)
how do i change my 500's oil. how do i drain it and change oil filter if need be. it says oil change so do i have to get a whole new oil filter and also does the 500 use the same oil as my 420 cause i bought some oil from autozone for my rancher but i still havent used it
2012 Honda Foreman 500 (SOLD)
2007 Honda Rancher 420 (SOLD)
2005 Honda Recon 250 (SOLD)
8 Replies Related Threads
    wes ranch 4x4
    Re:how to change foreman 500's oil? 2011/02/10 19:39:21 (permalink)
    just pull the oil plug to drain it and there is a lil plate on the side of the motor with three 8mm bolts that is covering the oil filter be sure to put the oil filter in the right direction or it will fry the motor and yes the oil is the same.
    2009 Grizzly 700 Wild Boar relocated Rad, SYATV snorkles, HMF optimizer, Wiseco 11.5:1 piston, power tip, 1.5" wheel spacers, ss rims, 30x9 backs, Highlifter signature series lift, Superatv axles, ODI grips, strobe lights, and EPI clutch kit.
    RANCHERBOY102
    Re:how to change foreman 500's oil? 2011/02/10 19:43:02 (permalink)
    UNDER it right n the dead middle theres a bolt bigger hole than all the other jus unscrew it and oil comes flyn ya you can use the same oil four wheller oil is oil and the oil filter on the right side of the machine engine theres this cirle thick spot in the motor lower left corner on right side 3 mabey 4 bolts pull it out after unscrewn if ya think ya need a filter and jus swap for a new one then your set i would change filters every 3 oil changes but if you mud alot i would say every change and to turn the oil light off jus hold all the buttons for a few seconds than it goes bye bye that should be it any more questions jus shoot me a pm
    2012 Rancher 4x4 power steering
    -moose back seat
    -camo saddle bags
    1998 300 4x4 (pink panther)
    -grips
    -saddle bags
    -2 inch lift
    -25 inch mudlights
    -tow hook
    -rebel flag licence plate
    -f0-4
    -6000 k HID's
    past rides....
    honda 90
    pw 80 dirtbike
    04 660 rhino
    07 420 rancher
    07 green 500 foreman
    07 black 500 foreman
    04 400 rancher
    03 ttr 225
    11 rzr 800
    RANCHERBOY102
    Re:how to change foreman 500's oil? 2011/02/10 19:44:14 (permalink)
    dang it he jus barely beat me but mines more in depth lol
    -moose back seat
    -camo saddle bags
    -grips
    -saddle bags
    -2 inch lift
    -25 inch mudlights
    -tow hook
    -f0-4
    -6000 k HID's
    past rides....
    honda 90
    pw 80 dirtbike
    04 660 rhino
    07 420 rancher
    04 400 rancher
    03 ttr 225
    11 rzr 800
    KaJunBoy
    Re:how to change foreman 500's oil? 2011/02/10 20:14:40 (permalink)
    i think they can use the same filter, my 350 and my dads 500 uses the same one.
    ~2013 Honda 420 Rancher~
    ~2003 Honda 350 Rancher~
    ~2008 Dodge Cummins 4x4~
    dmanMus
    Re:how to change foreman 500's oil? 2011/02/10 22:56:50 (permalink)
    thankyall so much, im gonna have my parents bring it home from my camp this weekend and then im gonna go to the honda shop by my house and pickup a filter and change the oil, how much do i put in?
    trx300
    Re:how to change foreman 500's oil? 2011/02/10 23:08:37 (permalink)
    go to advance auto parts and tell them you need a filter and just buy some valvoline atv oil it will be cheaper than going to the honda dealer.
    2015 420 rancher 4x4
    Stock except 28"zillas on ss212 wheels
    91 honda 300 4x4 (sold)
    uni filter
    snorkeled both ends
    hl clutch kit
    27 swampers
    chrome dg exhaust
    300ex front shocks
    front hl lift kit
    lt400 rear shock
    .50 bore
    cv guards
    custom bash plate
    custom black paint
    wheel spacers f&b
    99 400 foreman (sold)
    snorkel
    hmf pipe and snorkel
    uni filter
    27 super swampers
    hl lift kit
    gear reduction
    .50 BORE
    relocated oil cooler +factory oil cooler
    cv guards
    bash plate
    dmanMus
    Re:how to change foreman 500's oil? 2011/02/10 23:12:48 (permalink)
    are all filters the same or ask for a 500 filter
    trx300
    Re:how to change foreman 500's oil? 2011/02/11 13:02:39 (permalink)
    tell them the year,make and model and they will hook u up
    uni filter
    snorkeled both ends
    hl clutch kit
    27 swampers
    chrome dg exhaust
    300ex front shocks
    front hl lift kit
    lt400 rear shock
    .50 bore
    cv guards
    custom bash plate
    custom black paint
    wheel spacers f&b
    snorkel
    uni filter
    27 super swampers
    hl lift kit
    gear reduction
    .50 BORE
    cv guards
    bash plate
