Lockedhow hard is it to change rear axle bearings? on a recon?
hondarider94
2009/09/12 09:44:21 (permalink)
my dad thinks that the oil got drained from the rear axle from a bad seal, which caused the brake pads to come unglued and stack up.
how hard is it to replace the bearings on the left side of the bike?
3 Replies Related Threads
    gmcz71
    Re:how hard is it to change rear axle bearings? on a recon? 2009/09/12 09:51:30 (permalink)
    probably not bad.  Id stary by looking at the axle/diff and see which way it slides out.  then take the hub off the opposite side and slide it out.  unbolt the axle tube from the diff and the bearing should be in the end of it.  use a pipe or something to tap it out.  (not sure exactly how the rear end on a recon looks)
    Deeperthanu_29.5
    Re:how hard is it to change rear axle bearings? on a recon? 2009/09/12 11:57:55 (permalink)
    Naw that isn't hard pretty much common sense will get it done
    2009 POLARIS SPORTSMAN 800
    14IN CRUSHER WHEELS
    26IN MAXXIS BIG HORNS
    FOR SALE:
    2003 Yellow Foreman Rubicon
    29.5x12 Outlaws on rear rims
    Dyno jet kit
    EPI clutch kit
    HMF exhaust
    K&N air filter
    Highlifter coolant temp. gauge
    2 inch highlifter lift
    Highlifter lift springs
    custom 2.5 lift
    custom painted a-arms
    2 Gorilla Axles
    7 inches of spacers on back
    Extreme Products disk brake conversion on front
    Custom smoked headlights and taillights
    Custom Snorkel
    2001 Honda Recon
    2 in lift
    24 in gators
    Thelittlebrutethatcould
    Re:how hard is it to change rear axle bearings? on a recon? 2009/09/12 13:56:53 (permalink)
    Dude that is the easiest bearing seal/bearing I have ever replaced...Like they said, just $35 should get it, but it was $60 for me cause i have a rancher....But I used a 38mm impact socket to knock the bearing back in and it has been flawless, any questions, just pm me, I can walk you through it if you like.
    08 Midnight Blue Brute 750
    All Skinny 28" laws
    MSA Nukes
    Snorks
    Custom Front
    09  AMR Camo Brute 840
    Big Gun
    snorks
    2" lift
    27" swamp lites
    ITP 212's
    3000 lb. Warn winch
    ***STOLEN***
    07 Green Rancher 2x4
