Lockedhooptie 3
Page: 123 > Showing page 1 of 3
BridelessRacing
2013/06/17 09:24:56 (permalink)
hooptie 3
goofing off on face book last tuesday
a guy posts a tan 300 4x4 for $600 says wont run needs carb cleaned
bike is in stfrancisville im thinking that's only 3.5 hours away
there were 4 people who responded that they wanted it I was the fith
the owner texts me that night
I get vin no and run it
wednesday at 1 its in back of truck
post edited by BridelessRacing - 2013/06/17 09:26:04
Don Oglesby on facebook
usefull
420 gr
64 Replies Related Threads
    wes ranch 4x4
    Re:hooptie 3 2013/06/17 09:27:34 (permalink)
    whats the plan Don? lol
    2009 Grizzly 700 Wild Boar relocated Rad, SYATV snorkles, HMF optimizer, Wiseco 11.5:1 piston, power tip, 1.5" wheel spacers, ss rims, 30x9 backs, Highlifter signature series lift, Superatv axles, ODI grips, strobe lights, and EPI clutch kit.
    BridelessRacing
    Re:hooptie 3 2013/06/17 09:31:46 (permalink)
    Wednesday evening I could tell engine had no compression
    and right side cover had been removed and put back on
    figured id start there
    removed side cover
    lots of chain slack
    removed top of head
    timing chain had jumped
    turning motor by hand I felt no compression still
    removed head
    valve hit piston
    usefull
    420 gr
    BridelessRacing
    Re:hooptie 3 2013/06/17 09:36:50 (permalink)
    after new
    valve
    gaskets
    seals
    timing chain
    top end is complete
    waiting on 54%
    barnet springs
    dimpled plates and new fibers
    usefull
    420 gr
    BridelessRacing
    Re:hooptie 3 2013/06/17 09:39:01 (permalink)
    wes ranch 4x4
    im thinking 2 inch lift
    brute force rear rims on front
    with 27s
    and 28 and my old paddle setup on back
    but really I don't know yet
    usefull
    420 gr
    wes ranch 4x4
    Re:hooptie 3 2013/06/17 09:46:49 (permalink)
    put those 30" silverbacks on it you have for sale!!!
    BridelessRacing
    Re:hooptie 3 2013/06/17 10:33:53 (permalink)
    I thought about running these
    but I need easy stearing
    with a weak left arm
    brute rims have more inset and lighten the stearing up
    14 inch aftermarket rims have
    90% outset
    ball joint isn't near center of tire
    usefull
    420 gr
    TOOLOUD
    Re:hooptie 3 2013/06/17 17:16:19 (permalink)
    Not too bad Don
    2016 Honda Pioneer 1kd5 dark metallic ON ORDER !
    2015 Honda Foreman 500 SRA 69% GR / 29.5 wide laws and a big center paddle
    2011 FX4 EcoBoost Super Crew  w/ a crazy tune !
    GOT SOME REALLY LOUD HORNS TOO....NATHAN P5'S.....BTW YES THEY ARE TOOLOUD !!!!!
    http://s200.photobucket.com/albums/aa251/MPTOOLOUD/
    BAMA MUDIGGER
    Re:hooptie 3 2013/06/17 17:36:31 (permalink)
    Looks Good! I just picked one up same price. I got wheel bearings ordered. trying to decide if I want a gear reduction or just put 27's or 28's  and a paddle
    BridelessRacing
    Re:hooptie 3 2013/06/17 21:51:43 (permalink)
    Bama
    Any more than mild 26s and a paddle
    Will make a stock motor struggle
    In thick stuff
    usefull
    420 gr
    BAMA MUDIGGER
    Re:hooptie 3 2013/06/17 22:23:22 (permalink)
    So I guess I will have to put a GR in it. Guess I need to start reading see if I cant get one and install it. It has 25" swampwitch's on back and vampires in front. Witch GR do you recommend for 28 laws or backs?
    doubleduecez
    Re:hooptie 3 2013/06/17 22:47:54 (permalink)
    Check out my sig thats what I have and it does good but you can tell the big tires are on there in real thick stuff about alfway up all 4 but in watery stuff and stuff thats not pb your good
    '96 Honda 300 4x4 "Ol Blue"
    Snorkled, 4-2-4, 2.5 inch lift, 28x10 S-backs, SS212s, 18% gr, HC Wiesco,40b webcam, FO-14 with snorkel, extra lights, jetted, locked, Rear brake delete, and a paddle.
    '92 Red 300 2x4 "Beauty Queen"
    Snorkels, 25in Vampires.
    2003 Kawasaki KX125
    Renthal bars and renthal sprockets
    1953 Ford Tractor - Straight Tank
    georgiaboyskingquad
    Re:hooptie 3 2013/06/18 01:27:13 (permalink)
    do something wild, do IRS with some lower geared diffs like brute force diffs or cat 4.0's... that isht would be boss
    2013 Outlander 1000xt
    Camouflage w/DPS
    Swamp series exhaust. K&N air fliter, HID hi/low. 14" SS wheels. 31" OG laws. HL 2" max clearance rear trailing arms
    [style="color:
    BAMA MUDIGGER
    Re:hooptie 3 2013/06/18 09:20:53 (permalink)
    what is all the different GR. I see most people have either the 18 or the 54 in the 300's
    outlawed300
    Re:hooptie 3 2013/06/18 09:32:58 (permalink)
    yea thats all they have........as of right now.......nice 300 brideless. planning on keeping the tan plastics? i think they would look good cleaned up. is that all dirt and crude or is the paint coming off some? couldnt really tell in the pics.
    300 with some stuff
    420 with allot of stuff
    BridelessRacing
    Re:hooptie 3 2013/06/18 10:50:13 (permalink)
    Bama the 18 and the 54 are the easiest to build
    I'm having my machinest
    Cut my little gear to ride directly on crank
    Steel on steel no bronze bushing
    I'm thinking with engine tuneup in oil
    It won't sieze
    If this works
    I have a bigger reduction figured out
    usefull
    420 gr
    BridelessRacing
    Re:hooptie 3 2013/06/18 10:58:36 (permalink)
    Outlawed the plastic was painted silver at some point
    Looks bad
    I'm tryin to buy a red 2 wheel drive for the plastic now
    usefull
    420 gr
    BridelessRacing
    Re:hooptie 3 2013/06/18 11:03:40 (permalink)
    Georgia boy this is my hooptie bike
    The point is to not have a ton of time or money in it
    So when I roll it upside down in a hole
    I don't loose much
    usefull
    420 gr
    HondaBoyBlue
    Re:hooptie 3 2013/06/19 11:26:42 (permalink)
    Alot of the time WD 40 will help get spray paint off. It has worked for me a lot of times. Might be worth a try for ya.
    2014 Polaris Ranger 800 EPS LE
    SSV Audio Soundbar
    22in LED Light Bar
    Moose Windshield
    Moose Roof
    2008 Red Honda 420
    27 Mudlite xtrs on 14in ss 112 wheels
    snorkeled
    HMF exhaust
    Audio tube
    UNI air filter
    lift kit
    #19
    Honda380
    Re:hooptie 3 2013/06/19 11:30:25 (permalink)
    graphitti remover from home depot, pressure washer, and bout an hour and I had ever bit of the paint off my plastics, old black paint and the yellow paint the guy painted over it with.
    #20
    wes ranch 4x4
    Re:hooptie 3 2013/06/19 15:00:50 (permalink)
    ive also used a rag and brake fluid to get paint off before
    #21
    Machinist
    Re:hooptie 3 2013/06/19 21:39:01 (permalink)
    Looks like you'll have her up and running soon bud.
    I agree, brake fluid would prolly strip the paint too.
    08' Rincon~Rubber Down Customs Lift~HL Lift Springs Pc'd Black~HL Fender Kit~HL Skid Package~29.5x10 Laws~SS 112 Chrome~Big Red Gear Reduction ~UNI~Warn 2500LB~HL Gel Grips~2'' I.D. Snorkel~Custom Shift Handle~Atv-Guru Bumper~NGK Plug Boot~10K Hid's~
    Past Rides:
    1979 & 1980 ATC 70
    1980 ATC 110
    2001 Honda 450ES
    2000 Bayou 220
    1994 Honda 300 4x4
    #22
    lsujunkie
    Re:hooptie 3 2013/06/19 21:58:18 (permalink)
    Looks good for 600 bucks
    2002 Polaris 500 H.O.
    26" Vamps
    Stick Stoppers
    Sold:
    1999 Honda 300 26" Vamps
    #23
    BridelessRacing
    Re:hooptie 3 2013/06/19 22:07:48 (permalink)
    Machinist
    not worried about paint right now
    trying to get it to canal road on 29th
    if I can get one of my buddies to split diesel and a hotel room
    wife has plans for that weekend
    usefull
    420 gr
    #24
    BridelessRacing
    Re:hooptie 3 2013/06/19 22:11:39 (permalink)
    got a rear rack
    need to cut nuts out of the end of rear support for front rack
    and weld new nuts in.
    pondering
    disc brakes
    led light bar
    or
    hero3 camera
    usefull
    420 gr
    #25
    crazybear
    Re:hooptie 3 2013/06/20 09:17:26 (permalink)
    Easy light bar!
    Brute 650i
    29.5 swamp lites
    itp rims and warn 2.5
    extreme snorks
    pipe lift
    custom cooler mount
    HL 2in lift
    Back rest
    HMF utility slip on
    #26
    doubleduecez
    Re:hooptie 3 2013/06/20 09:23:41 (permalink)
    Lights are nice.... Brakes are nice but overrated lol. Go with the go pro well worth the money
    Especially if you have kids cause you can get everuy thing they do in video
    2003 Kawasaki KX125
    #27
    Machinist
    Re:hooptie 3 2013/06/20 09:48:55 (permalink)
    I vote brakes... Helps in stop and go traffic, hills, when loading, etc etc.
    Past Rides:
    1979 & 1980 ATC 70
    1980 ATC 110
    2001 Honda 450ES
    2000 Bayou 220
    1994 Honda 300 4x4
    #28
    outlawed300
    Re:hooptie 3 2013/06/20 09:55:02 (permalink)
    What are these "brakes" you all speak of?
    300 with some stuff
    #29
    doubleduecez
    Re:hooptie 3 2013/06/20 09:57:33 (permalink)
    ^^^ not sure.... ive heard hondas have great brakes though!!
    Lol
    2003 Kawasaki KX125
    #30
