Lockedhonda rancher 350 will not shift
MUD STUD
2012/06/25 21:46:36 (permalink)
i am working on a honda rancher 350 for someone and it will not shift it is stuck in 5th gear and will not down shift.....it is an es but even when you try to shift it with the tool t will not shift.....when you try to shift you can push the lever down like it is going to shift but it will not.....it feels like when you down shift or up shift when an atv is off and you have to rock it a lil to get it to click in gear but rocking does not help it....i adjusted the clutches with no luck.....any ideah of what the problem could be?????
thanks for any input
1993 red honda 300 4x4
.40 wiesco high compression piston
port and polished head
88 cam big red timing chain
HMF jet kit
K&N snorkle
greased diff's and t-case
27" outlaws
8 Replies Related Threads
    Outlaw400
    Re:honda rancher 350 will not shift 2012/06/25 22:08:40 (permalink)
    Could have possibly bent the shift forks. Did u have the front case off of the motor. If so when u put it back together u could have put the forks in the wrong spot.
    07 bigg badd bear
    29.5 outlaws wides
    gk snorkle
    gk 6 inch lift
    a lil motor work
    hl springs
    TEAM GUMBO KUSTOMS
    "HITTING EVERY HOLE......CUZ THATS
    HOW WE ROLL"
    MUD STUD
    Re:honda rancher 350 will not shift 2012/06/26 08:54:21 (permalink)
    i have not even taken it apart yet just truing to get some ideahs on what it might be and trying to find a starting point.
    thanks for the help
    HMF jet kit
    K&N snorkle
    27" outlaws
    teamrpr
    Re:honda rancher 350 will not shift 2012/10/31 17:43:19 (permalink)
    I have got this same exact problem right now. Did you get it fixed and if so what was the problem?
    Thanks
    gotmuddy
    Re:honda rancher 350 will not shift 2012/10/31 22:20:57 (permalink)
    broke shift drum is the most likely problem.
    Heftysmurf
    teamrpr
    Re:honda rancher 350 will not shift 2012/11/01 12:49:03 (permalink)
    I have been researching this since you replied. Is that something that I will have to pull the engine to check or can I fix it by pulling the front cover?
    gotmuddy
    Re:honda rancher 350 will not shift 2012/11/01 15:07:58 (permalink)
    split cases
    Heftysmurf
    Jake450s
    Re:honda rancher 350 will not shift 2012/11/01 17:44:22 (permalink)
    The first thing to cross my mind was the shift plate.  They had some weak ones back about 00, 02 ish.  Any of them can break though.  What happens there is it'll shift up or down (usually up) but will not shift the other way, so the transmission gets messed with until it can't shift any further (usually fifth gear).  Any time I've seen the shift drum broken it messes up the ES because the sensor is disconnected, but the manual shifter has worked.
    That's right under the front cover, and that's the first step to (almost) any possibility, so you wouldn't be out anything for checking that first.  Might get lucky, they're not bad to change,
    toodeep
    Re:honda rancher 350 will not shift 2012/11/02 09:04:10 (permalink)
    A visual of the shift plate. If you have an ES model first make sure it won't shift manually.
    07 TRX475FM                     09 TRX420FA
                  95 TRX300FW                          88 TRX300
