Lockedhonda 2000 fourtrax 300 problem
fourtrax 300
2008/09/10 19:40:14 (permalink)
I need to no where the drain plug is for my t case, front end and rear end…and can some one tell me how to take off my t case….
[8|]
1999 Polaris Scrambler 400
hot seat power pack
pipe,clutch,reeds, jets,
22in kenda bear claws
2000 Honda Fourtrax 300 4x4
HL lift. HL lift springs
spool locker, 26 in vamps
fully snorkeled
atv sound system
1997 chevy 1500 z71
6in lift, 35 in bfg
the tow rig
1994 jeep yj
sra 8 in lift, 38in super swampers
ox lockers, snorkel
my mud truck
10 Replies Related Threads
    gmcz71
    RE: honda 2000 fourtrax 300 problem 2008/09/10 19:52:34 (permalink)
    look on the front of your t-case... there are labeled bolts.  kinda tricky at first though.
    diff drains are the 10MM bolt at the bottom of them.  easier and less messy if you take off the rear skid plate.  not hard.
    Ill see if I can find a link...
    gmcz71
    pineymudder
    RE: honda 2000 fourtrax 300 problem 2008/09/10 22:22:13 (permalink)
    the transfer drain can be easily reached from the passenger side (right) of the quad. you'll know you have the right one cause its 12mm. and its at the lowest point of the case in the front. to make it even easier use a ratchet wrench.
    92 honda 300 4x4 26 laws
    88 honda 300 31 tsl swampers
    87 honda 350 foreman 26 executioners
    2000 300 ex
    oldtrx
    RE: honda 2000 fourtrax 300 problem 2008/09/10 22:32:49 (permalink)
    why do you need the transfercase removed?
    - www.gaorc.com
    ORIGINAL: ydopen
    "its not pretty, but its good enough for the girls we know."
    fourtrax 300
    RE: honda 2000 fourtrax 300 problem 2008/09/11 08:46:04 (permalink)
    the t case is leakig gear lube and u whant to seal it all up
    hot seat power pack
    fully snorkeled
    atv sound system
    1997 chevy 1500 z71
    6in lift, 35 in bfg
    the tow rig
    1994 jeep yj
    ox lockers, snorkel
    my mud truck
    oldtrx
    RE: honda 2000 fourtrax 300 problem 2008/09/11 15:56:21 (permalink)
    si it leaking from around the front drive shaft seal, rear shaft seal or around the case where the 2 pieces actually meet?
    you will need to remove front diff and shaft then the 4x4 cover on the side of the motor and there are 3 i believe bolts holding it on there and maybe one of two on the other side, then it just pulls out forewards
    i will try to find out wher my papers went from when i rebuilt mine. i had a seal leaking but i put in all new seals/bearings/gaskets/pins while i had it out.
    - www.gaorc.com
    ORIGINAL: ydopen
    fourtrax 300
    RE: honda 2000 fourtrax 300 problem 2008/09/11 16:48:56 (permalink)
    the rear seal
    toodeep
    RE: honda 2000 fourtrax 300 problem 2008/09/11 17:06:29 (permalink)
    The rear seal can be replaced without removing the gear box, take out the 4 bolts holding the 4x4 cover on. Then use a pair of snap ring pliers to remove the snap rings on the drive shaft (1 one the front and 1 on the back) use a hammer and punch and tap the couplers towards the mid of the drive shaft. Use a screw driver and remove the seal and install the new one (be careful and use a socket as a driver). Reinstall everything (jack the front end off the ground to make it easier to line up the drive shaft) and good to go.
    07 TRX475FM                     09 TRX420FA
                  95 TRX300FW                          88 TRX300
    oldtrx
    RE: honda 2000 fourtrax 300 problem 2008/09/11 18:36:34 (permalink)
    you lucked out [;)]
    thats an easy fix, mine was the outputshaft seal. no fun.
    - www.gaorc.com
    ORIGINAL: ydopen
    fourtrax 300
    RE: honda 2000 fourtrax 300 problem 2008/09/11 19:19:49 (permalink)
    [:D] thanks
    hot seat power pack
    fully snorkeled
    atv sound system
    1997 chevy 1500 z71
    6in lift, 35 in bfg
    the tow rig
    1994 jeep yj
    ox lockers, snorkel
    my mud truck
