vinny04
Total Posts
355
Reward points
grip ends
Monday, November 02, 2009 9:59 AM
( #1 )
I installed grip heaters under my stock grips on saturday using compressed air to blow off the grips as suggested on the fourms. They work fine but the poroblem is the metal "knob" on the bar end will not go tight on the right bar the philips screw that secures it just spins. The left side went back tight no problem. Any suggestions as to how i can get it to tighten?
2004 Suzuki Vinson Camo (Stock except bolt ons) 26" Mud Bugs 2500Lb Warn Winch replaced with 1500lb Champion VIP Fairing Kimpex Deluxe "no passanger seat" Kimpe Rear Bumper,Fender Guards, and Foot Pegs Mini Reverse Lights Horn Heated Grips Aluminum Skid Plate 45w Xenon Fender Headlight Swap http://www.flickr.com/people/suzvinny2004/
back2XR
Total Posts
516
Reward points
Re:grip ends
Wednesday, November 04, 2009 2:10 PM
( #2 )
There is a wedge type thing on the bar end, uses a nut/ The nut is probably just spinnings. Take it off and look at it. Good luck with those warmers and keeping your grips from spinning. I've battled this for a while. I just put new grips on without glue, and used 5 stainless wire ties on each grip. So far so good.
-07 Kawasaki Brute Force 750i, Dynatec CDI, two needle shims, 26x9-12 Big Horns front/rear, ITP C-7 Rims, Hand/ thumb warmers, Tusk atv handgaurds, Black Viper 2500 Max(aka classic) w/ amsteel, yukon backrest, Black and Decker tool box
Gr8white
Total Posts
582
Reward points
Re:grip ends
Wednesday, November 04, 2009 3:22 PM
( #3 )
I used hairspray to keep my grips from moving, and I have heated grips also. No probs to date with my grips
09 Mud Pro 29.5's 2.5" B&J Lift ~ HD Tierods ///Airdam 08 366 (the little kymco that could) Snorkled 28"MST's ///Airdam
