Lockedfuel-air mixture screw
farmboyrich
2011/03/22 23:12:11 (permalink)
just got a dynojet kit, and installed everything as instructed in the kit. no matter how i tweak it, it runs too lean. mainly what i need to know is if tightening the fuel air screw leans it out, or makes it richer. im running a dj170 main jet if that helps. thanks
02 red foreman 450s
-2" lift
-full 2" pvc snorkel
-28" GBC's and sra offset wagon wheels
-GR, 475 bbk, and some other goodies before too long
Past Toys:
06 Foreman 500 ES
03 Prairie 650
07 Built 400 EX
04 Crf 450r
07 Crf250r
03 KX250
12 Replies Related Threads
    spartanhonda300
    Re:fuel-air mixture screw 2011/03/22 23:17:47 (permalink)
    go both ways i believe if you go all the way to the left with it then come back out 2.5 turns that is the stock setting go from there
    98 bb 350
    25 inch mud lites and a lot of work that needs to be done.....
    MCKOIN STARTER AND ALTERNATOR
    108 Olive St. Monroe LA 71201
    If you need a starter PM me or call at (318) 381-7991
    300 4x4
    Re:fuel-air mixture screw 2011/03/22 23:48:28 (permalink)
    i also have a dyno jet kit on my 300 and needs adjusting would someone mind telling me the location of hte fuel/air screw?
    1998 Polaris Magnum 425 4x4
    spartanhonda300
    Re:fuel-air mixture screw 2011/03/22 23:50:40 (permalink)
    its on the right hand side of your bike if you are sitting on it also the screw on a 300 just looks like a little black knob down there not like a screw at least on my 300 thats how it looks
    98 bb 350
    300 4x4
    Re:fuel-air mixture screw 2011/03/22 23:55:35 (permalink)
    theres a couple down there, is it by the carb or what?
    spartanhonda300
    Re:fuel-air mixture screw 2011/03/23 00:01:57 (permalink)
    its on the carb...what do you mean a couple?? you have a Chinese 300 or something lol jk man its the one on the carb
    98 bb 350
    300 4x4
    Re:fuel-air mixture screw 2011/03/23 00:06:11 (permalink)
    lol ok then u shoulda said that haha and theres that and plus the idle screw
    spartanhonda300
    Re:fuel-air mixture screw 2011/03/23 00:09:44 (permalink)
    youll instantly know which one you hit cause the idle screw will put the bike at a high idol or kill it if you go the wrong way to fast just adjust the screw and then ride around and see which way you need to adjust by checking your plug after that
    98 bb 350
    300 4x4
    Re:fuel-air mixture screw 2011/03/23 00:11:47 (permalink)
    oh ok thanks man
    texashorn21
    Re:fuel-air mixture screw 2011/03/23 01:36:57 (permalink)
    all the way to the right and back it out 2.5 turns, go from there by turning it a quarter turn at a time.
    07 honda 420
    28 laws
    2" lift
    1" spacers
    stealth/ submarine snorkle
    hmf
    custom back rest
    JPs300
    Re:fuel-air mixture screw 2011/03/23 10:15:39 (permalink)
    The black knob is the idle adjustment screw.
    The pilot screw is a flat-head, it sits in a recessed spot pointing straight up at the front of the carb near the intake boot. - The tighter you go, the leaner it is.
    2.5 turns is the stock reference point. Anything over 3.5 does nothing; meaning if you need the screw out that much you need a larger pilot jet.
    "In2Deep - our drinking crew has a mudding problem"
    '11 Max Limited -
    JPs Customs 4" lift, rad relocate, snorks, & audio tubes, 29.5 law2s on Pilots
    '08 Teryx -
    new build coming...
    http://s455.photobucket.com/user/JPShawgo/library/riding%20pics
    fenderdeep300
    Re:fuel-air mixture screw 2011/03/23 10:52:26 (permalink)
    ^^^ indeed... and a word to the wise... DONT START MESSING WITH THE IDLE AND A/F SCREWS IF YOU DONT KNOW WHAT YOUR DOING! Believe me, you will just mess it up more. I had to learn that lesson the hard way. Get someone to physically show you what to do. Good luck.
    Honda 300 4x4
    HC Piston / HL Springs / Lift / Harley Pipe / Snork / 88 cam / 3" Body Lift
    Under Construction
    Looking for a 54% gear reduction. PM me if ya got one.
    Bump530
    Re:fuel-air mixture screw 2011/03/23 11:33:56 (permalink)
    spartanhonda300
    thats the idle adjustment, not the a/f screw.
    Team BS - Bayou Slingers
    '05 Rhino 660 "Riverhino"
    30" Zillas / Black SS212 /  Stereo / Dipped Plastics / 3" Snork / FO-4 / Jetted / ViperMax 5000 / 8000K HIDs / XR Clutchin' / White Spring / Gorillas
