Lockedfront diff removal
Eagle_On
2011/03/05 14:11:41 (permalink)
front diff removal
how in the heck do you guys get these axles out ive pulled for two days. any tips/tools to use
16 Replies Related Threads
    Waterboy4690
    Re:front diff removal 2011/03/05 14:14:33 (permalink)
    The CV shafts?  Did you make sure you have the retaining clips off the diff side?  Also, it helps to know what kind of wheeler it is.  And welcome to HL!
    Loud pipes save lives
    Eagle_On
    Re:front diff removal 2011/03/05 14:23:15 (permalink)
    2004 rubicon every thing is loose excpet the axle are stil in the diff and ive tried to pull but the barely move
    retaining clip? never heard of it. where is it?
    HoNdaNaStYrAnCheR08
    Re:front diff removal 2011/03/05 14:25:11 (permalink)
    yank on that bad boy an if u get a lil space between the cup an the diff put a pry bar in there an thatll help it alil
    Black 07 brute Clutch full big gun Jet snorkled hids
    29.5laws msa nukes....
    GOLD 05 brute clutch hmf jet 14in mas nukes on 26in mtc motos full skids
    RED 06 brute 840bbk 31s ****zload done to it
    southern86
    Re:front diff removal 2011/03/05 14:28:54 (permalink)
    should be like any other but im not 100% there is a spring clip on the splines in the diff they are kinda hard to get to unclip. on the cars i work on sometime you have to tap it pretty good with something solid not sure if you can get to it good maybe hope someone else will chime in for more info for you
    2007 420 Rancher 4X4
    Snorkel by LOUISIANA PERFORMANCE LLC.
    Hmf Utility Series
    PCIII
    Comp Clutch kit
    28" ZILLAS
    14" ITP SS 312
    OUTLAW CLUTCH KIT REMOVED FROM MY 420 AND  FOR SALE $50
    Eagle_On
    Re:front diff removal 2011/03/05 14:36:22 (permalink)
    does it matter what i side i do first
    texashorn21
    Re:front diff removal 2011/03/05 14:38:36 (permalink)
    you have to put some muscle into it. its a pita to get out but you just got to pull that beach out
    07 honda 420
    28 laws
    2" lift
    1" spacers
    stealth/ submarine snorkle
    hmf
    custom back rest
    Eagle_On
    Re:front diff removal 2011/03/05 15:11:41 (permalink)
    will i tear the cv boot if i put a screwdriver or pry between it
    has anybpdy tried the rbc method with ratched straps, lol either them sucks are in there or im doing something completely wrong
    austin82
    Re:front diff removal 2011/03/05 16:03:25 (permalink)
    I had this problem till i pushed the axle in the differential and then yanked on it as hard as i could and it come out. and now all i do is push then pull and it comes off real easy, but i have to push mine in first or it won't come out
    Fix it all week just to ride all weekend.
    Honda 300 4x4
    Too much and adding more
    INTOODEEP
    Re:front diff removal 2011/03/05 16:13:02 (permalink)
    X2. Push in and yank out quick.
    13 renegade
    14 mav XXC
    DixieMudderGrizz05
    Re:front diff removal 2011/03/05 16:20:06 (permalink)
    yeah most are supposed to just yank out.. sometimes they dont. if you are going to try and pry do not pry hard or you may crack the diff. housing. just put a little pressure on it while you yank...
    if you can manage to get one of them out usually you can put something inside the hole you got out and tap the other one out.
    if there is any sort of lip on the inner cup a slide hammer works great!
    [><]Dixie Mudders[><]
    2008 Can-Am Outlander 800
    1.5'' pipe lift on rear
    2" pipe lift on front with bracket lift
    Snorkeled
    Radiator Relocated
    HMF Penland Pro
    PCIII
    1.5" wheel spacers on the rear
    14" itp ss 212's machined
    30" Maxxis zillas
    Front and Rear Bumpers
    07' Yamaha Grizzly 700 Black / modded out  (SOLD)
    05' Yamaha Grizzly 660 Camo / modded out (SOLD)
    INTOODEEP
    Re:front diff removal 2011/03/05 16:35:20 (permalink)
    Pushing in and pulling out gives a slide hammer affect. It might take 2-3 tries but it's never failed me on any model or brand that I've done. I've never been able to just pull one out unless the snap ring was crushed.
    13 renegade
    14 mav XXC
    Eagle_On
    Re:front diff removal 2011/03/05 19:27:31 (permalink)
    I got it thanks but the key is get the axle horizontal to the diff. Nobody tolde that
    Eagle_On
    Re:front diff removal 2011/03/05 19:29:31 (permalink)
    Now the next part getting front driveshaft out. Any tips tricks brine is a little different. Because I have warn 424 so it's a split shaft with a spring loaded coupler of that helps
    DixieMudderGrizz05
    Re:front diff removal 2011/03/06 23:31:47 (permalink)
    INTOODEEP
    i know it gives the effect but does not supply the same force. it has failed me before.. when i yanked the shaft out of the cup this way. so i HAD to resort to the slide hammer to get the cup out.
    forgot to mention holding the axle as straight as possible.. thought that was a given.
    Snorkeled
    Radiator Relocated
    HMF Penland Pro
    PCIII
    30" Maxxis zillas
    INTOODEEP
    Re:front diff removal 2011/03/06 23:45:36 (permalink)
    X2 on the given part. Removing a 424 is the same as a regular driveshaft except you unbolt the brace that attaches it to frame. Unbolt diff and slide all the way forward and grab the coupler closest to motor and push forward HARD. It helps to grunt. You do realize that the axles could have stayed in if all your doin is wanting to remove front driveshaft.
    13 renegade
    14 mav XXC
    biglilrancher
    Re:front diff removal 2011/03/07 06:59:38 (permalink)
    but i know for doing most of anything involving the diff, it is pretty much way easier to remove the a arms as an assembly instead of taking each thing apart. Its about as quick as removing 1 a arm lol
    08 Can am Renegade 800 X
    29.5 OL 2s with some smexy Kores, LTE slip on, RDC gen 1 lift, Rear Rack
    (SOLD) 07 Black 420 Rancher 30" backs turnin all 4
