Lockedchanging rear output shaft seal on foreman
jrrtt09
2010/12/03 17:21:17 (permalink)
how do i change the seal on the rear output shaft of my foreman?
01/99 Recon 250 - stock 24s off of foreman
 97 Foreman 400-sold
 06 Brute Force 650-sold
88 Toyota pickup 4x4 - 2" lift, 4.88s, 33" LTBs
TEAM GOT BEER
7 Replies Related Threads
    Jake450s
    Re:changing rear output shaft seal on foreman 2010/12/04 09:45:31 (permalink)
    Remove the swingarm (search this forum...), and it's RIGHT there...  Do not replace it however until you have verified that there is no deflection (bend) in the output shaft.  I see you've got a 4-2-4, you can start the engine and choose a low gear to check for this.  If it's bent, your new seal is gunna leak too.
    jrrtt09
    Re:changing rear output shaft seal on foreman 2010/12/05 00:11:40 (permalink)
    i brought it to a shop(good price and no certified mechanics) and they changed my output shaft not long ago. im guessing that they didnt change the seal.
    i took the swingarm off but couldnt figure out how to get the seal out.
     97 Foreman 400-sold
    TEAM GOT BEER
    gotmuddy
    Re:changing rear output shaft seal on foreman 2010/12/05 01:40:10 (permalink)
    drive a small screwdriver between the outside of the seal and the engine case.  Once in a small amount pry and it will come right out.
    Heftysmurf
    jrrtt09
    Re:changing rear output shaft seal on foreman 2010/12/05 11:05:47 (permalink)
    thanks man, i was thinking that but i didnt want to break anything
     97 Foreman 400-sold
    TEAM GOT BEER
    Mr.Bojanguls
    Re:changing rear output shaft seal on foreman 2010/12/05 22:11:59 (permalink)
    there is a snap ring between the seal and the rim of the case ,you will see the gap in the ring just pry it up and pop it out. http://www.bikebandit.com/houseofmotorcycles/1997-honda-motorcycle-trx400fw-fourtrax-foreman-4x4/o/m2672#sch96225
    2013 Yamaha Rhino 700
    > 26" Skinny/Wide Vampires
    > In Dash Amp/Stereo Speakers
    > 4000lb Viper winch
    > Rear Diff Brace
    > 1.75mm Sheave Shim
    Mr.Bojanguls
    Re:changing rear output shaft seal on foreman 2010/12/05 22:13:06 (permalink)
    > 4000lb Viper winch
    > Rear Diff Brace
    > 1.75mm Sheave Shim
    jrrtt09
    Re:changing rear output shaft seal on foreman 2010/12/07 12:09:50 (permalink)
    well i just broke a piece of my casing off.
    now that i see the snap ring ill try it again, thanks bojanguls
     97 Foreman 400-sold
    TEAM GOT BEER
