Lockedbriggs motor on 3 wheeler
all_atv
2005/01/30 01:45:35 (permalink)
i have an older junk suzuki 3 wheeler sittin, and i was thinkin about uses for it. I'm thinking of putting a 5hp briggs and stratton with centrifical clutch and put smaller tires on it (maybe dirt bike tires if i can figure that out) so that it can turn them easier than the wide tires. as far as i can tell the brakes work and a motor is about $200 new. Sound like a plan just for a sodid ground cruising trike?
20 Replies Related Threads
    MRMARIO2U
    Re: briggs motor on 3 wheeler 2005/01/30 08:04:33 (permalink)
    why not a 10hp techumpse star motor it'll turn what ever tire you put on it
    thehickfarmer
    Re: briggs motor on 3 wheeler 2005/01/30 11:13:23 (permalink)
    or one of them small diesel lol
    ccrane
    Re: briggs motor on 3 wheeler 2005/01/30 12:32:13 (permalink)
    i've got an extra ryobi weed eater sittin out there if yer lookin for some REAL POWER....ROFL
    all_atv
    Re: briggs motor on 3 wheeler 2005/01/30 14:10:30 (permalink)
    well im poor and i want to use a cheap motor. and i was also thinking using for mud runs with tallest narrowest motorcycle tires i can get on the rear, but i think i would be limited on front tire size
    ccrane
    Re: briggs motor on 3 wheeler 2005/01/30 14:17:27 (permalink)
    a 5hp briggs is an ok engine but your tire size is going to be very restricted.... anything over a 16 inch diameter drive wheel coupled to a 5hp briggs isn't gonna have alot of gumption... regardless of width. i would strongly reccommend not going any lower than a 10... with a 10hp you could probably turn the stockers... it wouldn't be any speed demon but at least it would get you there and have a little bit of power.
    all_atv
    Re: briggs motor on 3 wheeler 2005/01/30 16:55:14 (permalink)
    without a transmission i would use a centrifical clutch, which sucks the power. theres no other way to hook it up is there? unless put the sprocket right on the crank shaft like a go cart i had. lol had to start it with the tires off ground then kick them down and take off in a burnout every time
    maybee ill look for a larger motor because i want skinny tires on it
    sdime
    Re: briggs motor on 3 wheeler 2005/01/30 17:15:05 (permalink)
    you could put a torque converter on there....
    all_atv
    Re: briggs motor on 3 wheeler 2005/01/30 17:46:44 (permalink)
    ya i could but they are about $300 last time i got one, for the smallest and that would add more complications, ill go with the centrifical since i want simple build. and dont need much speed or power out of this. i found an older 8 hp briggs that runs i think ill use
    MRMARIO2U
    Re: briggs motor on 3 wheeler 2005/01/30 18:16:00 (permalink)
    there is actualy alot more parts available for the 5hp briggs we've gotton close to 40hp out of them on the dyno for our raceing carts
    mudder160
    Re: briggs motor on 3 wheeler 2005/01/31 15:11:09 (permalink)
    how the heck do you get 40hp out of a briggs 5hp??????????
    Rancher_Boss
    Re: briggs motor on 3 wheeler 2005/01/31 15:41:01 (permalink)
    yeah . . . start puting a 5 hp briggs in a rancher.
    DirtKurt
    Re: briggs motor on 3 wheeler 2005/01/31 15:45:55 (permalink)
    Get a new drag racing block, head, crank, cam, intake,carb, exhaust, ignition, piston, rod and valves.
    MRMARIO2U
    Re: briggs motor on 3 wheeler 2005/01/31 17:41:14 (permalink)
    YOU ADD A MAKUNNI CARB A .500+LIFT CAM(the modified classes run a bigger cam yet) A SET OF LARGER VALVES AND DO SOME PORTEING WORK AD AN ARC HEAD AND A STROKER KIT HAVE IT ALL BALLANCED AND WALA YOU HAVE YOUR SELF A 5HP BRIGGS TURNING AROUND 8000rpm AND CRANKING OUT ALMOST 40hp,,, OF COURSE YOU HAVE TO WELD THE LIFTER VALLEY AND THEN HAVE NEW GUIDES INSTALLED AND IF YOU REALY WANT TO CRANK OUT SOME HORSE FROM A 5hp BRIGGS JUMP INTO A BLOCKZILLA BLOCK FOR YOUR FOUNDATION THEN GO AS WILD AS YOUR POCKET BOOK WILL LET YOU..
    ccrane
    Re: briggs motor on 3 wheeler 2005/02/01 12:37:53 (permalink)
    and i thought i had a bad *** go cart... i think i'll go home and throw rocks at it now.
    sdime
    Re: briggs motor on 3 wheeler 2005/02/01 19:56:02 (permalink)
    LOL. ccrane, how about you give me that phantom, and we'll call it a day
    MRMARIO2U
    Re: briggs motor on 3 wheeler 2005/02/01 22:11:21 (permalink)
    THOSE ARE DESCENT CARTS
    MY LAST ONE WAS AN OLDER STRAIGHT FRAME MARGAY I RAN IT IN THE TWO CYCLE OPEN CLASS IT WAS A WILD RIDE WOULD COME OUT OF TURNS 2 & 4 OF A 1/5th MILE TRACK AND CARRY THE LEFT FRT FOR ABOUT 15 FEET AND ON THE BACK STRETCH BETWEEN 2 & 3 THE TRACK WAS FUNNY AND IT WOULD GET 9 KINDS OF SQUIRLEY AND HIT TURN 3 AT ABOUT 79mph THATS WHEN I COULDNT LOOK AT THE SPEEDO ANY MORE.IT WAS TO RICH FOR MY BLOOD HAD TO QUITE
    SquirrelNutz
    Mud Slinger
    Re: briggs motor on 3 wheeler 2009/08/14 00:31:31 (permalink)
    when i was running jrII i was running a 16sec quarter mile on a high bank dirt oval that was with a restrictor plate.... ah the good ole days
    07 Grizzly 450
    2500lb Warn Winch CI
    Start and Shift Lockout Mods
    26X10 Executioners Front and Rear On ITP Deltas
    Rear Sway Bar Removed
    84 Honda ATC 125M
    Rebuilding Now
    01 Ford F250SD 4X4 OFFROAD
    LT235 85R16E Liberator ATs
    ExCab Short Bed
    7.3L V8 Turbo Diesel IH T444E
    "BLACK SMOKE DON'T MEAN IT'S BROKE!"
    mudweiserz71
    Mud Slinger
    Re: briggs motor on 3 wheeler 2009/08/14 18:48:40 (permalink)
    i had the same idea with a 1996 polaris sportsman 400 4x4.
    the engine is toast.. the tranny and running gear is all complete...
    thought about trying to stuff a brigs in there somewhere.. the hole running gear operates on chain drive...
    2008 POLARIS RZR 800;;GEN 2; 2 INCH RD LIFT;28x12x12 Maxxis `ZILLA tires on rear and 28x10x12 Maxxis `ZILLA tires on front;ITP TYPE 4 ALUMINUM OFFSET RIMS;GIBSON FULL SS EXHAUST;DFR/CYCLONE AIR FILTER SYSTEM;F2 FUEL CONTROLLER; NGK IRIDIUM SPARK PLUGS;CLUTCH SPACER REMOVED;3500LB GORILLA WINCH;POLARIS FRONT BRUSH GUARD WITH FOG LITES;POLARIS BIKIMI TOP; HALF WINDSHIELD;GOODYEAR GATERBACK SPORT BELT;CUSTOM SNORKELS;CUSTOM CNC CUT WHEEL SPACERS;;FRONT SWAYBAR REMOVED.
    #19
    skinny
    Re: briggs motor on 3 wheeler 2009/08/18 09:50:56 (permalink)
    i actually have a 3wheeler that came from the factory kinda like what you are wanting to do.  It's an Avenger BigFoot that came with a 8hp tecumseh with a torque converter setup.  reminds me...i need to get that thing running again!
    --'08 Kawasaki Teryx
    30x10 MudLite XXLs on MSA Torks
    Dyna CDI
    Prototype Dayco/Highlifter belt
    EPI Mudder clutch kit
    DirtLights HID headlights
    mp3 stereo setup
    Viper winch
    #20
    08rancher
    Re: briggs motor on 3 wheeler 2009/08/18 09:58:29 (permalink)
    you can make  the 5hp briggs fast i had a go cart with a crappy little clutch and it woud hit 45
                                   For Sale
      01 kx 125        wiesco piston, full fmf exhaust
     all new engine internals, new tires, new brakes, new fork seals, its a super clean bike
    #21
