Lockedbolt pattern for honda rims
brandoncspinks2009
2009/07/20 23:51:11 (permalink)
will any other atv company rims bolt up i heard honda and yamaha will match up..
owner/operator of:farmboyz customs
Soggy bottom racing member #01
Thanks to our sponsers Cyclemsters of douglas, rage customs,tim mills racing, and papa slap clutching.
looking for sponsers
2004 honda foreman rubicon ( super trooper) sold
  2010 honda rancher 420 sra
mods: hmf performance series exhaust,k&n,
 29.5 skinnys on rubicon rims. diamond plate where warning stickers use to be. no cut 1.5 inch snorkel, rad relocated, epi competition clutch kit, bored.050 over,
04 f150 fx4 red with 32 inch bfgoodrich all-terrains chrome eagle alloy rims, toolbox, tinted windows.
9 Replies Related Threads
    Trent O
    Re:bolt pattern for honda rims 2009/07/20 23:54:57 (permalink)
    kawasaki brute
    brute force 750
    snorkeld
    31in laws 12s all way
    audio tube
    2in extreme lift
    ss wheels
    honda recon 250
    clutch kit
    snorkeled
    2500lb winch
    (comein 28in mudlights)
    TEAM: TO DEEP!!!
    brandoncspinks2009
    Re:bolt pattern for honda rims 2009/07/20 23:58:28 (permalink)
    oh yea and this is going on a 04 honda rubicon i got to put 7.5 inch rims on my front(same size as the rear)for my new laws to fit without scrubbing.
    Dawgriderdanny
    Re:bolt pattern for honda rims 2009/07/21 00:03:37 (permalink)
    yeah my friends yamaha wheels bolts up with my honda.
    *Outty 800 Max ltd*
    *30" skinny silverbacks*
    *Wild Boar Rad relocated*
    *Sweet set of snorkels*
    *Full body skid plate*
    brandoncspinks2009
    Re:bolt pattern for honda rims 2009/07/21 00:07:59 (permalink)
    thanks and what do yall think will be the "most bang for the buck" big red gears or a clutch kit.
    $martguy_700GRIZZ
    Re:bolt pattern for honda rims 2009/07/21 02:48:39 (permalink)
    Anything that is 4/110 (most common) lug pattern will fit your 4 wheeler.  Make sure you look for SRA (Straight Rear Axle) rear wheels tho.
    BORO
    BULLOCH OFF ROAD ORGANIZATION
    STATESBORO, GA
    *Why does that one hole always stink so bad???*
    japickar
    Re:bolt pattern for honda rims 2009/07/21 10:01:44 (permalink)
    Suzuki also uses the 4/110 bolt pattern. Either vinson or eiger rims will work on your bike. I personally like the factory Alcoa aluminum rims that came on the vinsons.
    You will have to go with the clutch kit because the big red gears will not work on a rubicon.
    98' Foreman 400
    450 shocks and front suspension
    HL lift springs
    Xtreme disc brake conversion
    28/10/12 and 28/12/12 Zillas
    SS112's
    HL leak shield
    14.5% gear reduction
     Warn 4-2-4
    HL bash plate
    brandoncspinks2009
    Re:bolt pattern for honda rims 2009/07/21 19:49:57 (permalink)
    got me some brute rims and tires is mounted and bolted on thanks for the help
    littlebigrancher
    Re:bolt pattern for honda rims 2009/07/21 20:36:06 (permalink)
    yeah the brgr is for the rincon not the rubicon. they dont make a redcution for the rubicon. you will have to settle for a clutch kit.
    '12 ranger 500 midsize:
    3" Custom Lift, Stateline Customs 2" forward A-Arms,14" MSA Elixirs on 31"skinny laws, custom aluminum roof, 6 6.5" mtx marine speakers in custom pods, EMP front bumper , Viper Max 5000lb winch, Half Winshield ' custom cage extension' 36" cree light bar
    PLANET ATV
    Diahrea Slingers ATV Club!
    my420
    Re:bolt pattern for honda rims 2009/07/30 13:51:36 (permalink)
    The 4/110 bolt pattern is shared by Honda, Yamaha, Suzuki, and IRS model Kawasakis, and with only a few exceptions they should all be interchangeable.  The key thing when swapping wheels is to be sure of your offset; IRS machines will swap out with IRS machines, and SRA with SRA without any need for spacer or other modifications.  The main exception to the rule here is the 08+ Brute Force.  New for 2008, Kawasaki added a small tab to the hub that doesn't allow other wheels to bolt up flush unless they are made for this particular machine.
