Lockedbevel gears
Page: 123 > Showing page 1 of 3
06Vinson
2010/11/29 12:14:48 (permalink)
bevel gears
think i busted my bevels yesterday, got stuck in reverse heared a loud pop, but was still able to move in reverse while getting pulled out, then after a little while longer i was going threw another hole in low, and it poped again, this time making noise as if it was stuck between gears grinding, it makes the noise in all gears, 2wd or 4wd/ diff lock ect. it will still move but it will move like a foot then, feels like its locking up then move again and do the same thing. I was still able to pull it on and off the trailer under its on power. I know when the bevels go they usually go in reverse, hence why i think thats my problem. Wheres everyone getting there updated bevels at? When i look up the updated part numbers it says its a kit, what all will come with this "kit"? thanks
TIA guys
05 dmax dually 22.5s
[font="'courier new'"]
77 Replies Related Threads
    boosted again
    Re:bevel gears 2010/11/29 12:17:00 (permalink)
    ^^^sorry guys posted under my buddies screen name....
    --95 k2500 TD
    --08 Renegade
    bustedknuckles
    Re:bevel gears 2010/11/29 12:21:43 (permalink)
    Not sure what all comes with the kit, but the worst thing you can do when you think you busted your bevels is what you did. When you keep riding, or even spinning the output shafts by pulling the bike you take a very big chance of destroying your cases. Before you buy anything you should probly tear it down and check out your damage.
    Alan
    2008 TCAT
    2009 700H1 TRV
    dreggsta
    Re:bevel gears 2010/11/29 12:59:03 (permalink)
    i suspect that or diff failure. when my rear diff went i thot it was the bevels.
    If I say something that you don't like, that you assumed it to be how you interpreted it & you don't ask me to clarify what i meant then heck yeh, I meant it tripled how you took it.
    I don't see drama as a problem, I see it as an opportunity. You've been warned!
    fr.... your fail has been recognized.
    QUIK660
    Re:bevel gears 2010/11/29 13:22:27 (permalink)
    Locals bike did the same when it was the rear diff. but with you trying to back outta something in reverse and it popped.....imma et a wooden nickel on bevels. especially on a older model h1. hope it didnt get your cases too!!!!
    THE PRIDE
    No Ride
    Past bikes:
    09 Rzr
    08 Catvos Tcat
    08 SLC 650H1
    06 BFR 840 Brute
    05 Harwoods 660 Grizz
    SixOhh
    Re:bevel gears 2010/11/29 14:44:22 (permalink)
    yep, never keep riding when something feels that catastrophic....
    the way u can tell if its bevels or not is u can look down at the CVt case and u will see the motor torque up as u drive and roll over that broken bevel tooth.  the bike should start and idle just fine.
    if u think its diffs then simply jack the bike up and roll it over by hand.
    --2013 RZR 570--
    5" outkast, custom hydro dip
    32" Terms, S3 axles, SMD lighting,Strobage
    UTV INC switches,JL Audio /Memphis, PRP 5050 seats
    01' AC300
    crushed 29.5 OL2's by MyTater
    Strobes, snorks and a taste for water.
    --- Follow Me To Void Your Warranty ---
    H-Town Off-Road
    boosted again
    Re:bevel gears 2010/12/13 14:11:26 (permalink)
    finally got the ambition to take it apart and low and behold the bevels were busted, but it didnt eat up the case at all, all bearings look good, both gears are toast, the one on the case side is just chipped up, the bevel on the shaft is missing some teeth! so im glad i got lucky and didnt damage the cases at all.
    --95 k2500 TD
    --08 Renegade
    truponycar2
    Re:bevel gears 2010/12/13 16:08:09 (permalink)
    That's good news for you.  I am about to replace mine since they busted on my last ride.  Where are you getting the updated kit from?  How hard is it to split the cases?  What parts have to be removed from the motor?  I'm just trying to figure out what I'm about to get into!
    '12 Outty 1000 XT - Snorks, OL2's, /// and STM, HL 2" lift, HL springs, Xtreme LED bar, HL rad kit
    Past Bike: '07 AC 500 Auto
    Re:bevel gears 2010/12/13 20:18:32 (permalink)
    make sure you install all new bevel gear bearings when you update to the new style gears.
    gotta take the complete top end off both side covers and the complete right side of the motors, the crank does not have to come out just have to take the right case half off.
    08 650H1 L.E.
    Custom tie rods ;
    29.5" Laws on ITP type 7s
    1badkittykat
    Re:bevel gears 2010/12/13 20:21:31 (permalink)
    YEP^^^^^ DONT FORGET THE BEARING! I know some ppl that thought they're bearing was good, and the idiots didnt change it, and boom LOL
    2011 Rzr S 800
    07 H1
    Baytown Atv FTW
    06Vinson
    Re:bevel gears 2010/12/15 17:25:33 (permalink)
    is this thing fixed yet or what???
    boosted again
    Re:bevel gears 2010/12/16 18:38:31 (permalink)
    what bearings do i need? i know ill need the one that has the 2 retaining screws/plates which is p/n: 0832-015, 0832-015 is for my 06 model, should i order one from a newer model so i get an updated one? what other one will i need? the one that rides behind the bevel gear on the shaft? im also going to order 2 more bearing retainers and drill and tap for 2 more...
    post edited by boosted again - 2010/12/16 18:46:02
    --95 k2500 TD
    --08 Renegade
    boosted again
    Re:bevel gears 2010/12/16 20:34:03 (permalink)
    0830-116   Gasket, Clutch Cover
    0830-084   Gasket, Base
    0830-085   Gasket, Cylinder Head (0830-124)
    0412-338   Gasket, Exhaust Pipe
    0830-128   Gasket, Magneto Cover
    0826-100   Screw, Cap
    0822-010   Retainer, Bearing
    0830-043   Seal, Oil - Driven Shaft
    0832-016   Bearing, Driven Gear
    0832-077   Bearing (0832-015)
    so this is everything i should need to complete this minus the
    bevel gear kit Kit 0822-122 ??
    post edited by boosted again - 2010/12/16 20:38:38
    --95 k2500 TD
    --08 Renegade
    boosted again
    Re:bevel gears 2010/12/18 14:05:04 (permalink)
    --95 k2500 TD
    --08 Renegade
    Re:bevel gears 2010/12/18 16:24:44 (permalink)
    Looks like a good list to me..
    08 650H1 L.E.
    Custom tie rods ;
    truponycar2
    Re:bevel gears 2010/12/20 09:51:22 (permalink)
    Is there anything else that should be done while it's torn apart?  Are any special tools required??
    truponycar2
    Re:bevel gears 2010/12/30 13:00:07 (permalink)
    boosted, did you get the parts yet?
    Re:bevel gears 2010/12/30 14:32:39 (permalink)
    If it was me while it was down i would use a ball hone on the cylinder very very lightly and install a new set of rings, I would also install a 650H1 cam in it to boot since your taking the cam out anyway...
    I would also install new vavle guide seals if you have very many miles on it, cheap and easy to do while its apart.
    post edited by GWC - 2010/12/30 14:43:46
    08 650H1 L.E.
    Custom tie rods ;
    Whitebandit
    Re:bevel gears 2010/12/30 20:57:01 (permalink)
    Here is mine when I opened it up back in April
    This is after I replaced the bearing and gears
      Team Carnage
    If it's Cheap and Reliable, it's not Fast.....If it's Fast and Cheap, it's not Reliable.....If it's Reliable and Fast, it's not Cheap!!!
    if it ain't broke.. keep fixing on it!
    2012 Teryx 4. 30in monsters on black 14hd's
    If you voted for Obama to prove your not racist- Who are you going to vote for to prove your not an idiot?
    #19
    QUIK660
    Re:bevel gears 2010/12/30 21:23:30 (permalink)
    james did you drill and tap those other two tabs?? i'll take pics of doing mine nxt wknd.
    THE PRIDE
    No Ride
    Past bikes:
    09 Rzr
    08 Catvos Tcat
    08 SLC 650H1
    06 BFR 840 Brute
    #20
    Whitebandit
    Re:bevel gears 2010/12/31 11:05:26 (permalink)
    Yes. I drilled and tap the other two. Im going to do the same with Kathys. I also j/b welded the bearing in the case also
      Team Carnage
    #21
    taker
    Re:bevel gears 2010/12/31 12:31:01 (permalink)
    Has anyone ever tried to find a Thrust Bearing to replace the ball bearing thats in there???
    Xtreme  Missouri Boyz™
    Finding the holes and rooting them OUT
    2010 ARCTIC CAT 450
    SS212
    28 ZILLAS
    MAKING BIGGER BIKES LOOK NORMAL SINCE 2008
    #22
    QUIK660
    Re:bevel gears 2010/12/31 13:08:30 (permalink)
    You mean a needle type bearing? Confused on what you mean by "thrust" bearing. If you could find a way to put a double rolled bearing in there it'll last forever!
    THE PRIDE
    No Ride
    Past bikes:
    09 Rzr
    08 Catvos Tcat
    08 SLC 650H1
    06 BFR 840 Brute
    #23
    taker
    Re:bevel gears 2010/12/31 13:12:27 (permalink)
    A thrust bearing is a bearing that rolls on an angle to offset the force being applied directionally. That may not be best though because the shaft technically rolls both ways....hmmmmm
    2010 ARCTIC CAT 450
    SS212
    28 ZILLAS
    #24
    QUIK660
    Re:bevel gears 2010/12/31 13:45:16 (permalink)
    Oh......a tapered bearing. Was confused......it would work if you had a way to press it into the race. Isn't the fixed bevel shaft held from the back with some sort of nut?
    THE PRIDE
    No Ride
    Past bikes:
    09 Rzr
    08 Catvos Tcat
    08 SLC 650H1
    06 BFR 840 Brute
    #25
    truponycar2
    Re:bevel gears 2010/12/31 15:03:51 (permalink)
    Does the H1 cam make much of a difference? Is it worth $200?
    post edited by truponycar2 - 2010/12/31 15:05:49
    #26
    boosted again
    Re:bevel gears 2011/01/01 18:47:34 (permalink)
    james you remember the tap size off the top of your head? i also got 2 more bolts/retainers, for mine...
    --95 k2500 TD
    --08 Renegade
    #27
    Whitebandit
    Re:bevel gears 2011/01/01 23:24:47 (permalink)
    boosted again
    Man I dont remember. I have a whole set of the taps so I just size the bolt to the tap.
      Team Carnage
    #28
    boosted again
    Re:bevel gears 2011/01/06 15:22:30 (permalink)
    for anyone taping 2 more holes to hold the bearing in, the tap size is 6mmX1.00, use 5mm drill bit and remember to use lots of oil while taping it....
    --95 k2500 TD
    --08 Renegade
    #29
    truponycar2
    Re:bevel gears 2011/01/06 16:02:21 (permalink)
    Do you get much benefit from doing that?  Is it necessary?
    BTW, nice pic!  I like the black and yellow.  Looks good!!!
    post edited by truponycar2 - 2011/01/06 16:03:29
    #30
