Lockedartic cat 500 big bore kit
kittykat500
2008/04/08 03:27:56 (permalink)
ok have any of yall herd of the 581cc big bore kit from ****h.net? its under the suzuki vinson listings but i know its the same motor as a arctic cat. I was jus wanderin' if anyone on here has herd of this kit or has installed one on a 500. if so, how much quicker would it make it and powerwise, they have the kit that comes with the sleeve, piston, rings, and bushings for like $295, would it be worth it? would love to hang with my buddies' 700 grizzly, lol!!
04' kittykat 500m
2'' lift
28/12/12 mudlites
motosport climax wheels
jet kit
clutch kit
7 Replies Related Threads
    cat500mudder
    RE: artic cat 500 big bore kit 2008/04/08 06:30:41 (permalink)
    From what I have heard you get a 100% power increase if you have the big bore kit set up right with a better pipe, intake, jetting, and a performance cam. Also F S T has a BBk under the arctic cat section, even though they are the same motor.
    ~.Team Carnage.~
    (formally The Pride)
    Administrator
    RE: artic cat 500 big bore kit 2008/04/08 09:33:39 (permalink)
    I would not think you will get 100% increase maybe more around a added 10hp or so max, there are only a few people on here that have them maybe one of them will chime in and let you know how much more power they have now..
    08 650H1 L.E.
    Custom tie rods ;
    29.5" Laws on ITP type 7s
    P360onBugs
    RE: artic cat 500 big bore kit 2008/04/08 09:37:01 (permalink)
    what do you want the power for? do you want it for mud performance. cause if so. that money toward a gear reduction would be much better spent IMO.
    MUD BIKE=Blue 08' Big Bear 400i
    always broken POS. aparently its hard designing a rear end that works???
    TRAIL BIKE= GREEN 08 Brute Force 650i   bi/tris, rear lift, winch
    DBS
    Mud Slinger
    RE: artic cat 500 big bore kit 2008/04/08 09:47:03 (permalink)
    Me and my friend sunk mega money into my AC 400 4x4 and his AC 500 4x4, we did this cuz we were trying to run 28 and 29.5 laws, and turn them like the bigger bikes. We succeeded and actually whooped alot of the bigger bikes in the mud but still ended up selling them for bigger bikes to have the top speed and ability to mod for more power.It all depends on what your going for? if you just want to turn large tires in the mudd, do a gear reduction. If you want to be able to snatch the fron end up and run over 70 mph save your money (like we didnt) lol[:-] and go for a bigger bike, not saying yours isnt great, just have more power to start with on the big bike. But pm if you wish to mod that bike you got out, suz we have done it before and know alot of tips and advice for ya![;)]
    2008 Arcticat 650 H1
    28" silverbacks
    ITP wheels SS108s machined
    1.5" wheel spacers
    2" lift kit
    mud slinger exhaust
    carb. mod
    snorkled
    clutch kit in process
    gorilla axles
    Can Am 2008 Renegade
    Not for the mudd!!
    2006 Arcticat 400 4x4
    manual shift
    27" tires
    rear bumper
    snorkle kit
    1st Place 399cc & under
    1st place 499cc & under
    kittykat500
    RE: artic cat 500 big bore kit 2008/04/09 00:20:45 (permalink)
    thanks man, i really want a lil bit of spped as well as the torque in the mud, jeff at steel horses said it would give me about 30% est more power, and heay i might pm you every now and then, im tryin to make my old cat half **** keep up with the new ones, 70mph is well plenty for me anyways. jeff also said that he has a bore kit and will install and everything for about $1000, Idk about that!
    04' kittykat 500m
    2'' lift
    28/12/12 mudlites
    jet kit
    clutch kit
    Administrator
    RE: artic cat 500 big bore kit 2008/04/09 08:10:10 (permalink)
    If you want to keep it i would do the BBK head work cam and the 4.0 gears and a good mufler.. then they better look out..
    08 650H1 L.E.
    Custom tie rods ;
    kittykat500
    RE: artic cat 500 big bore kit 2008/04/09 21:50:18 (permalink)
    ok thanks man, i will do some diggin' and check on stuff.
    04' kittykat 500m
    2'' lift
    28/12/12 mudlites
    jet kit
    clutch kit
