LockedYamaha rhino Fuel Problems!
dmbuhan
Dirt Monster
2009/12/02 15:31:15 (permalink)
Hi, guys
    I just bought a 06 yamaha rhino 660. Bought it used with 60 miles on it. My problem is the rhino is popping through the Carb. When running it has a rough idle and when i slighly hit the gas is stalls out or it pops thorugh the carb.. I dont think I'm getting enough fuel, I was looking for a fuel mixture screw and i didnt see one. Is there one? When i remove the choke plunger looking thing is stops popping but it idles rough.. Any Ideas?
thanks!
post edited by dmbuhan - 2009/12/02 16:01:57
MY YOUTUBE Channel Name: DMB3002
2006 Yamaha Rhino 660 Green
ITP Delta Rims + Carlise Act Tire
White Bros Exhaust E2...
Black Rhino CDI
6000k HID lights
Some other fun stuff
2006 Kawasaki Brute Force.. (My New Machine)
ITP TerraCross R/T XD On ITP Delta Wheels (Black)
HMF EXhaust (way too loud)
EPI Clutch kit
K&N Air filter with precharger
Dynatek CDI
Yamaha Kodiak 400 4x4
ITP 26" 589's
2 Inch lift
2006 Yamaha Rhino 660 Camo
Stock For Now
5 Replies Related Threads
    AlaskaGrizz
    Re:Yamaha rhino Fuel Problems! 2009/12/02 16:42:18 (permalink)
    only 60 miles sweeet! Probably got some of the same gas from 2006 in it :) The gas tank and carb both have to be removed and cleaned. Those little yellow flakes you'll find in the carb are varnish. Additives won't work, clean it up and enjoy.
    09 Polar Bear HO 700
    modded out
    2005 660 Grizz
    HMF
    Dynojet
    Warn 2500
    Setxatv snorkles
    Steel skidplates and A-arms
    HL Super Duty Clutch kit
    HL Triple Flow Rad/ stock position
    lil420camo
    Re:Yamaha rhino Fuel Problems! 2009/12/02 18:45:14 (permalink)
    x2
    07 420 custom.sold
    07 recon built to hang with the big boys.
    05 718 rhino with /// and 31s.3" of lift
    06 650 h1  being built for new mud bike
    dmbuhan
    Dirt Monster
    Re:Yamaha rhino Fuel Problems! 2009/12/02 20:16:16 (permalink)
    guess i should have put that i cleaned it very well. soaked the carb over night and changed the fuel filter... do you know if there is a fuel mixture screw?
    Black Rhino CDI
    6000k HID lights
    EPI Clutch kit
    Dynatek CDI
    ITP 26" 589's
    2 Inch lift
    Stock For Now
    AlaskaGrizz
    Re:Yamaha rhino Fuel Problems! 2009/12/02 20:42:22 (permalink)
    They have a fuel/air mixture screw. Ain't no way that is your problem with 60 miles since the factory. Soaking the carb does nothing for these Mikunis either. The jets have to be removed and blown clean. There is another good thread on here you should read.
    Ya read this one: http://forum.highlifter.com/Unfixable-Rhino-m3815541.aspx
    post edited by AlaskaGrizz - 2009/12/02 20:46:50
    modded out
    2005 660 Grizz
    HMF
    Dynojet
    Warn 2500
    Setxatv snorkles
    dmbuhan
    Dirt Monster
    Re:Yamaha rhino Fuel Problems! 2009/12/02 21:25:05 (permalink)
    I took the whole carb apart from jets to floats and needle jet. i took the air compressor to it all.. why is it when i remove the choke plunger thing it runs a bit better
    Black Rhino CDI
    6000k HID lights
    EPI Clutch kit
    Dynatek CDI
    ITP 26" 589's
    2 Inch lift
    Stock For Now
