LockedWinch won't free spool?
birdmanf250
2011/02/01 15:35:01 (permalink)
well winch won't free spool. Took apart, cleaned gears, lubed with grease. Plunges in/out but still won't free spool... It's a Polaris 3000 or 3500 idk which one.
Any advice or help!
Ghost RZR
FTM 6" Arched Lift
Gorilla Axles
Speed Werx/Hot Seat Performance Custom Clutching
UTV Inc. Intake/Donaldson Filtration
Burke Moto Pro HID's
Wet Sounds w/J Strong Top
6 Replies Related Threads
    la77chevy
    Re:Winch won't free spool? 2011/02/03 12:21:29 (permalink)
    Warn winch right? I've seen several do this, it's usually the gears behind the plastic lever on the side. Pop off the plastic piece and there will be a snap ring. Remove the snap ring and realign the gears. Really crappy design but not hard to fix
    moto92
    Re:Winch won't free spool? 2011/02/03 19:29:23 (permalink)
    my warn wont free spool either, guess ill have to try this
    ______________________________________________________
    2006 Rhino 660 SE
    RDC 2" lift
    12" ITP SS108's
    28" Zillas
    Viper 4000lb widespool
    Snorkles
    Radiator Relocated
    birdmanf250
    Re:Winch won't free spool? 2011/02/03 20:13:51 (permalink)
    I'll def look with ur advice!
    Ghost RZR
    FTM 6" Arched Lift
    Gorilla Axles
    la77chevy
    Re:Winch won't free spool? 2011/02/04 10:36:55 (permalink)
    You will need a real small pair of snap ring pliers
    switzomatic
    Re:Winch won't free spool? 2011/02/05 01:37:26 (permalink)
    Mine did the same thing. Easy fix as mentioned above. Guess I was  used to the old warn's that you had to give a good turn to go back and forth. The xt's take minimal effort.
    2014 Scrambler 1000-stealth clutch snorkels-QSC Clutch-Mega Mayhems on Dual Beadlocks
    2014 Sp 570 for Momma
    2010 Scrambler 500 HO
    08 Silverado 2500 Crew to haul 'em
    birdmanf250
    Re:Winch won't free spool? 2011/02/05 10:02:07 (permalink)
    The popo version, I think is different? I took it completely in half. Cleaned grease. The lever is actuating the rod and spring, and "throwing" full rotationbut won't go into free spool still!
    I may just be frustrated, but if anyone can elaborate, I'd appreciate it.
    Ghost RZR
    FTM 6" Arched Lift
    Gorilla Axles
