LockedWinch problem, Warn contactor
Sloth
2006/07/25 08:15:31 (permalink)
I have a Warn 2.5 that came with my 06 Sportsman.  My contactor quit on me the other day.  All it does is click when I hit the winch switch.
From my research, it doesn't seem uncommon for this part to go out.  What is the primary cause of contact failure and what can I do to prevent it from happening again???  The winch doesn't do me any good if it doesn't work when needed.   Also, is it a Warn specific part or is it a Polaris specific part.
Thanks.
2009 Polaris Sportsman 850 XP- Green
-28" Zillas on SS212
-Warn XT30
-Ricochet A-Arm Guards
-QSC Clutch
past rides...
1999 Honda Foreman S
1995 Kawisaki Prarie 4x4
8 Replies Related Threads
    elkbow
    RE: Winch problem, Warn contactor 2006/07/25 08:19:21 (permalink)
    If it is clicking, its probably not the contactor.  Check your connections, positive connection at the battery and the connections at the contractor...that is usually the problem...take them off, clean then and retighten them down
    Dave
    '10 Polaris 850 XP EPS
    muddymud
    RE: Winch problem, Warn contactor 2006/07/25 08:29:15 (permalink)
    elkbow is correct, check the connections first. Then put a meter on it to see what the deal is. It is a warn part. I have replaced one on my old honda. I think water got to it over the years. It's an easy fix if it's bad. Before I put the new one on, I siliconed it very well all over it. It has been good to go since.
    08 6" Polaris RZR  - For Sale
    Sloth
    RE: Winch problem, Warn contactor 2006/07/25 08:53:20 (permalink)
    Thanks guys.  I was able to get it to winch out for a few minutes before it gave up again.
    -Warn XT30
    -QSC Clutch
    past rides...
    elkbow
    RE: Winch problem, Warn contactor 2006/07/25 10:03:50 (permalink)
    the connection at the battery is usually the problem, pull it off, clean it well, make sure that the lugs are flat against each other and tighten good....
    Dave
    Saw Doctor
    RE: Winch problem, Warn contactor 2006/07/25 19:40:23 (permalink)
    Same thing happened to me.Ended up pulling the motor off,it was full of swamp water and rust.Cleaned it up filled it with syn grease 100%.Do the same every year now.
    TJ400
    RE: Winch problem, Warn contactor 2006/07/26 10:08:35 (permalink)
    as noted by Saw Doctor, swamp water/ swamp crap is likely isolating the winch motor brushes from the cummutator....  Removal and cleaning is in order...
    02/400SP. 26" OutLaw MST's/ Front brush-guard/ 2000 Warn winch (home-made upgrade to mini rocker and remote)/ Rear cargo rack & seat/ tail lite defeat/ brake lite defeat/ hidden ignition kill/ Mossy Oak (break-up) fender, tank & pod covers, grip & thumb warmers
    honda/polaris
    RE: Winch problem, Warn contactor 2006/07/26 10:23:33 (permalink)
    my dads had that prob. it ended being the contactor. it got water in it so all you would here was a clicking noise. when he got a new one he siliconed around the seal so no water would get in.
    2008 Polaris Sportsman 800 EFI - Polaris LE wheels, 2500# Polaris winch, front Polaris rack extender, Polaris hand guards, reverse override
    Pics/Vids
    Sloth
    RE: Winch problem, Warn contactor 2006/07/30 13:10:12 (permalink)
    Picked the quad up yesterday from the dealership.  They ended up replacing the contactor as the original one had cracked near the wire attachment points allowing water into the unit.  It was replaced under warranty.
    -Warn XT30
    -QSC Clutch
    past rides...
