ibrokeit
Total Posts
2678
Reward points
Why a by run?
Monday, February 22, 2010 6:51 PM
( #1 )
Why would there be a 3 wide heat, a few 2 wide heats, then a by run? would it not make more sence to pull a bike off the 3 wide and pair with the guy that was getting a by run?
OPS #27 SPORTSMAN 800 SPORTSMAN 9() RANGER 700 kawi 700 2nd OPEN madison fla HLPS 3rd STOCK madison fla HLPS 2nd OPEN stop #3 SMRS 3rd open creekbottom firecracker bash
offroadpowersports
Total Posts
1125
Reward points
Re:Why a by run?
Monday, February 22, 2010 6:56 PM
( #2 )
Every heat is computer generated. If I were guessing, that situation would only occur in the event someone dropped out after the brackets had been built. I know that the reason they go two wide on some and three on others is to prevent by-runs.
polarisofgeorgia #1 on Google www.creekbottomtrailrides.com TEAM OFFROAD POWERSPORTS RACING #45 OPS Sportsman XP 850 OPS Polaris RZR QUAD SHOP CUSTOMS, HSP, AMR MOREMUDD, CATVOS, HIGHLIFTER OPS BIG BORE, SPONSOR http://www.polarisofgeorgia.com/ Proud to Support Team Creek Bottom
ibrokeit
Total Posts
2678
Reward points
Re:Why a by run?
Monday, February 22, 2010 7:02 PM
( #3 )
thats what i THOUGHT Jay, but we run a 3 wide first heat , two -2 wide heats, then a by run in the open class, same thing in madison. just wondering was there a specific reason for it, or just the way it pans out
offroadpowersports
Total Posts
1125
Reward points
Re:Why a by run?
Monday, February 22, 2010 7:54 PM
( #4 )
Its the computers way of trying to have a 3 wide final. 3 wide=2losers 2 wide=1 loser by=0 losers So if the computer is trying to build a 3 wide final and you have 6 racers it might set up the brackets like this: 1st heat: Racer 1, Racer 2, Racer 3 2nd Heat: Racer 4, Racer 5 3rd Heat: Racer 6 gets a by You end up with a 3 wide final and Im pretty sure that is how it is programed on most of the classes. If you put Racer 6 in the 2nd heat, you end up with 4 people racing for 3rd and that would add 3 more heats to the class. This is also why you only get 1 by run in the series. Hope that makes sense and it is purely an example.
ibrokeit
Total Posts
2678
Reward points
Re:Why a by run?
Monday, February 22, 2010 7:58 PM
( #5 )
gotcha.
ATVSGONEWILD
Total Posts
401
Reward points
Re:Why a by run?
Monday, February 22, 2010 8:48 PM
( #6 )
As if we didn't already know, Jay is a smart man. I saw the same thing at Mud Nats and was totally confused until I started working with the software. It's all about generating a 3-wide final. The only times you will see a "3rd place race" is when there weren't even enough racers to generate a 3 wide final (like when there are 5), which should almost never happen. To put it simply, in order to generate the 3-wide final, you need a certain number of first round heats (which then translate to a certain number of second round seats, and finally a 3-wide final) and sometimes the only way to get that is to have byes in there. Whenever you see more than 1, its because someone dropped out after the fact, and unfortunately the other racer in that heat cannot just be pulled up into the other bye because that would eliminate one of those "need to have" first round heats. In order to basically eliminate this going forward, I'm going to confirm everyone participating in each heat during the driver's meeting by calling out the names. If someone has been incorrectly placed for whatever reason, or maybe somehow broke their bike since they signed-up, I'm going to remove them on the computer a re-generate the brackets for that class (should take less than 5 minutes) before we stage. I know this may still be confusing for some folks, and if it is, just please trust us on this....its a necessity and the same format the PSR is following.
rvfd506
Total Posts
409
Reward points
Re:Why a by run?
Monday, February 22, 2010 8:53 PM
( #7 )
I was also wondering, but now it makes sense.. I was just thinking for some reason someone didnt show up to run....(but to maintain the structure it was run the way the heats were lined up) either way I had a blast, look forward to trying it again...next time maybe I can get a by ;-)(lol)
2007 Honda Foreman 500 4x4 Black 27" Outlaws 2" Wheel Spacers 12" ITP SS112 Alloy Wheel Custom Snorkel To come: HMF Exhaust (or custom exhaust) Clutch Kit Air Filter
ibrokeit
Total Posts
2678
Reward points
Re:Why a by run?
Monday, February 22, 2010 8:57 PM
( #8 )
I understand the reasoning now.
thequeenquad
Total Posts
114
Reward points
Re:Why a by run?
Monday, February 22, 2010 9:17 PM
( #9 )
Thanks for explaining...I was the one questioning it.
YAMAFORD
Total Posts
2540
Reward points
Re:Why a by run?
Tuesday, February 23, 2010 5:19 AM
( #10 )
Great explanation. Question # 2 on bi's I know the rules state that you don't have to runif you get a bi but if by chance I do get one, can I anyway? My reason for asking is I would like the same chance at getting a feel for the bottom of the pit as the guys i'd be running against in the second heat.
JC 750
Total Posts
562
Reward points
Re:Why a by run?
Thursday, February 25, 2010 9:52 AM
( #11 )
I think they are going to make everyone make a pass through the pit when they get a by anyway...I know it says in the rules that they wouldnt have to, but I think they are saying now it's not fair to the other racers that have already raced a heat to race a fresh bike in heat two or three so everyone has to at least make it through the pit...
Seminole Mud Racing #3 www.seminoleatvpark.com Tomberlin USA Augusta, GA Seminole Atv Park Atvs Gone Wild Daytona Atv
E.C.DirtyBoys Slick
Total Posts
1040
Reward points
Re:Why a by run?
Thursday, February 25, 2010 2:08 PM
( #12 )
I will check and let everyone know on this one.
Team GORILLA Red Steve Hittle #6 Spaceport Cycles, VP, J&J Performance, GotWake Eng. 08 Outty 09 Rene X 09 RZR-s Trail Stud 08 Rene 800
10polaris800
Total Posts
354
Reward points
Re:Why a by run?
Thursday, February 25, 2010 9:09 PM
( #13 )
i will agree with josh on this one everyone should have to make a pass threw the pit bye run or not.
Team Greene Machine Custom Atv Parts #37 Jarod Wilson Racing engines Capitol Cycle For all you atv,ruv,motorcycle and bicycle,Parts and sales.Macon,Ga (478)-475-5711 Wilson machine<Macon GA Byron Tire Company>Byron,Ga Honda Kawasaki Seadoo of Americus Blue Pond ATv Park. Greene Machine Manufacturing co. Special thanks to Randy Miller racing. Can-am 800 Can-am ??? Can-am 400 Polaris 200 polaris90 R&R Performance. MICHAEL MAYO #37
rvfd506
Total Posts
409
Reward points
Re:Why a by run?
Friday, February 26, 2010 9:20 AM
( #14 )
yea you can never tell.. his/her bike may develop problems running,so they should get the same chance as others to possible eliminate themselves? I am by far NOT hopeing some one or wishing any misfortune upon any racer....(cause if I was, i know karma would come and get me next time)
