LockedWater pump bleeder valve on 99 silverado
little grasshopper
2007/04/19 17:58:17 (permalink)
Does anybody know if there is a bleeder valve on a 99 silverado. I had mine replaced a few weeks ago and now I realize I have no heat coming from heater. I heard that some systems there is a bleeder valve to go to the heater core but not sure or where it would be are what the heck it looks like. Someone with a service manual or the "know how" please help (I don't want to deal with this guy again).
09 red  850 XP with EPS,SLD mod,chrome HL XL2s ,26in Bighorns ,30in Zillas on SS 312s,San Angelo back rest with dual ammo cans,Warn winch,ODI Rogue grips,custom audiopipe ,RAM Otterbox mount
6 Replies Related Threads
    Bigmike750BF
    RE: Water pump bleeder valve on 99 silverado 2007/04/20 03:30:23 (permalink)
    These trucks do not have a bleeder in the coolant system anywhere as their not necessary since the cooling systems on these trucks are "self bleeding". Did you check the coolant level in the surge tank (mounted on the inner fenderwell)? If it's low on coolant the first thing it will affect is the heater output.
    06' 750BF Aluminum Products full skids, 25" Mud lites, ITP wheels, Penlocked,Dynojet jet kit, Autometer ultra lite temp gauge, Warn 2500lb winch
    little grasshopper
    RE: Water pump bleeder valve on 99 silverado 2007/04/20 10:55:28 (permalink)
    It was a little low the heater feels better but not like it was before. The heater vore seems to be getting hot water(feel the hose getting hot) someone told me the vacum line may not be good,where is it at? there is hot air coing out it just dusen't seem as hot as it did before.
    Croatan_Kid
    RE: Water pump bleeder valve on 99 silverado 2007/04/20 19:47:24 (permalink)
    is the truck running at the right temp? should be right below 210 on the gauge, if not the thermostat is bad and the heater will suck hardcore if it aint[:D]
    Green '04 Yamaha Big Bear
    26" ITP 589s
    1.5" Snorkel
    Warn 2.5ci Multi-Mount
    '86 Chevy M1008 CUCV
    CARC Camo
    6.2/TH400/208
    D60/14 Bolt w/ Detroit
    4.56s
    11.00R16 Michelin XZLs
    99 Chevy Silverado 1500 4x4
    Charcoal gray
    4.8 w/ 5spd manual
    A few extra goodies
    20+ MPG
    PhotoBucket!!!
    http://s158.photobucket.com/albums/t115/Croatan_Kid/
    ORIGINAL: JasonSC
    yeah, but I might look like a monkey riding a football
    Shadowmaker
    RE: Water pump bleeder valve on 99 silverado 2007/04/20 20:06:23 (permalink)
    ORIGINAL: Bigmike750BF
    Are you sure theres not one on the top of the thermostat housing?
    05 Grizzly- 27" Bi/Tri Claws on type 5 ITPs.warn bumper, K&N filter,Supertrapp muffler00 Kodiak 400-26" mudlites,3.0 Warn winch
    Grizzlytrap_
    RE: Water pump bleeder valve on 99 silverado 2007/04/20 20:47:45 (permalink)
    99 with the 5.3 or 5.7, that was the first year of the 5.3 change over (new body style). If all you did was the water pump, and now have no heat, check the rad and make sure its filled, make sure the temp gauge is reading 190 or higher. Feel both heater hoses, both should be hot after warmed up, if not, then most likey the ni p p le  co m m ing from the intake manifold is clogged with crap.
    little grasshopper
    RE: Water pump bleeder valve on 99 silverado 2007/04/20 23:30:02 (permalink)
    Its a 99 6.0 2500. It runs about 210. I checked the hoses today but I dont think it was warmed up enough. The hose coming from the therm to the heater core was hot but the other really wasnt. The heater core isn't leaking and the res is full of fluid.
