LockedValve adjustment procedures for all Honda ATV's
Guest
  • Status: online
2008/03/16 19:36:16 (permalink)
Some of the most commonly asked questions in the Honda section are about valve clearances and how to adjust them. So I’ve compiled this guide that shows how to adjust the valves on the most popular Honda ATV’s, both current and non-current.
To all the Honda section regulars, if someone asks how to adjust the valves on a particular Honda ATV, please link them to this thread so they can quickly choose their model and follow the valve adjustment procedure. I have also circled the valve clearance specs within each model’s valve adjusment precedure, so if someone only wants to know the clearance spec, please link them to this thread.
Valve adjustment procedure for Recon (all years)
Valve adjustment procedure for TRX300 (all years)
Valve adjustment procedure for Foreman 350 (all years)
Valve adjustment procedure for Rancher 350 (all years)
Valve adjustment procedure for Rancher AT (all years)
Valve adjustment procedure for Rancher 420 (all years)
Valve adjustment procedure for Rancher 420AT (all years)
Valve adjustment procedure for Foreman 400 & 450 (all years)
Valve adjustment procedure for Foreman 500 (all years)
Valve adjustment procedure for Rubicon (all years)
Valve adjustment procedure for Rincon 650 & 680 (all years)
Valve adjustment procedure for Big Red
post edited by MuddnMason - 2009/05/06 22:50:36
08 brute 650
28 swamplites on rattlesnakes
highliter springs
2in lift
dynatek cdi
almond secondary
28 Replies Related Threads
    Guest
    • Status: online
    RE: Valve adjustment procedures for all Honda ATV's 2008/03/17 18:11:18 (permalink)
    Bump for all the Honda regulars.  Use this thread people.
    08 brute 650
    highliter springs
    2in lift
    dynatek cdi
    almond secondary
    Biker Scout
    RE: Valve adjustment procedures for all Honda ATV's 2008/03/17 22:18:07 (permalink)
    This is a really great thread Dynamo. Thanks.
    Do you really need to remoave the recoil starter housing on the Rancher 350 to do the adjustment?
    Guest
    • Status: online
    RE: Valve adjustment procedures for all Honda ATV's 2008/03/18 11:08:21 (permalink)
    ORIGINAL: Biker Scout
    No.  What they mean is the recoil starter cover.  This is the small plastic piece that is removed to access the recoil starter handle.  See below.
    08 brute 650
    highliter springs
    2in lift
    dynatek cdi
    almond secondary
    ragtagranchers
    RE: Valve adjustment procedures for all Honda ATV's 2008/03/18 12:10:53 (permalink)
    now only if the printer would work[&o]
    1990 fourtrax 300 4x4
    its blue.
    Guest
    • Status: online
    RE: Valve adjustment procedures for all Honda ATV's 2008/03/18 17:29:37 (permalink)
    ORIGINAL: ragtagranchers
    Save it to your hard drive and print it later.
    08 brute 650
    highliter springs
    2in lift
    dynatek cdi
    almond secondary
    rubicon_joey
    RE: Valve adjustment procedures for all Honda ATV's 2008/03/18 21:50:41 (permalink)
    This should be a sticky...please mods...[:)]
    sold..(In the market for a new one now)...
    04 Red Honda Rubicon.....28X10 & 28X12 Maxxis Zilla's....Mud Buster Cam...2'' lift......EPI Clutch Kit...MSA Tork Wheels...HMF Utility series...Dyno Jet Kit...K&N Air Filter...Warn: 3.0 ci, bumper and 424 select...Detriot Gearless Locker...H/L Disc Brakes
    Guest
    • Status: online
    RE: Valve adjustment procedures for all Honda ATV's 2008/03/18 21:55:39 (permalink)
    It has already been stickied to the top of the Honda section.  If you encounter someone asking about valve clearance specs/procedures, link them to this thread and they can choose from the list.
    Here is the helpful links sticky.
    http://www.highlifter.com/forum/Important_Links_for_Honda_Owners!/m_2249597/tm.htm
    post edited by Dynamo - 2008/03/18 21:59:31
    08 brute 650
    highliter springs
    2in lift
    dynatek cdi
    almond secondary
    Guest
    • Status: online
    RE: Valve adjustment procedures for all Honda ATV's 2008/03/23 13:31:07 (permalink)
    Come on guys, I see lots of valve clearance questions being asked but I don't see the HL regulars linking people to this thread.
    I spent a lot of time putting all this information together for HL members, let's make an effort and put it to good use.
    08 brute 650
    highliter springs
    2in lift
    dynatek cdi
    almond secondary
    Chimera Kennels
    RE: Valve adjustment procedures for all Honda ATV's 2009/02/04 22:04:05 (permalink)
    Generally speaking, for us "non-tech guys," how often does this need to be done and how do we identify if there is a "valve timing problem."
    03 Rincon - HMF exhaust, Uni air filter, 52 Keihin pilot jet, 158 Keihin main jet, dynajet needle on 2nd notch, dynajet spring, 27" ITP Mudlite XTPs on 14" ITP type 7s.
    02 Rancher ES 350 w/ Swamplites on aluminum Rubicon rims for the wife.
    06 Rancher 350 manual shift for 11 yr old daughter.
    Chimera Kennels - Producing performance by selecting for it!
    nichocha33
    RE: Valve adjustment procedures for all Honda ATV's 2009/02/04 22:15:29 (permalink)
    On the 420 valve adjustment it states check engine idle speed; is there a way to adjust this?
    2008 RZR
    SATV 6-8"
    33" Terms on 15" MSA Enduros
    Snorks
    Tunes
    HIDs
    a lil somethin', somethin' in the motor
    Dicks Powersports
    Papa Slap Clutching
    Highlifter
    Tibal Whips
    gmcz71
    RE: Valve adjustment procedures for all Honda ATV's 2009/02/04 22:26:34 (permalink)
    if your valves are out of adjustment you will hear a slight tapping coming from the top of the motor.  my BB does it pretty bad.
    nichocha33
    RE: Valve adjustment procedures for all Honda ATV's 2009/02/04 22:36:43 (permalink)
    im just wondering if i can speed my idle seems low to me ? idk
    2008 RZR
    SATV 6-8"
    Snorks
    Tunes
    HIDs
    Dicks Powersports
    Papa Slap Clutching
    Highlifter
    Tibal Whips
    Steve07
    RE: Valve adjustment procedures for all Honda ATV's 2009/02/04 23:32:01 (permalink)
    The idle on a 420 is non-adjustable.
    '87 TRX70
    '03 TRX350FM
    '08 TRX420FM
    kodiak660
    RE: Valve adjustment procedures for all Honda ATV's 2009/02/04 23:43:52 (permalink)
    ORIGINAL: gmcz71
    Only if they are loose.
    Most of the time they tighten up.
    Videos
    07 Honda 420 Rancher ES 4x4
    06 Outlander 800 XT 2,900 miles (sold)
    03 Grizz 5,000 miles (sold)
    01 Rancher 5,800 miles (sold)
    00 Kodiak 7,500 miles (sold)
    94 Warrior 6,500 miles (sold)
    towneblacksmith
    Re: RE: Valve adjustment procedures for all Honda ATV's 2009/04/04 10:04:42 (permalink)
    ok I can't get the links to work.....is it just me or are they bad?
    I get a 404 error
    post edited by towneblacksmith - 2009/04/04 10:05:51
    07 rancher 420
    25" bighorns on sti xm40's
    reverse mod
    2500lbs gorilla winch syn cable
    custom front bumper
    Billet 4x4 shifter
    HMF Penland eco series
    05 rancher 350
    3000lbs. venom winch
    reverse mod
    warn 424
    2 1985 trx125's
    lovnmud
    Re: RE: Valve adjustment procedures for all Honda ATV's 2009/04/04 10:26:40 (permalink)
    towneblacksmith
    I get a 404 error
    yea i get the same thing
    _________________MUDAHOLICS_____________
    2008 Rancher 420 es 4x4 camo
    Highlifter 2 inch lift kit
    Highlifter 2 inch wheel spacers
    Highlifter lift springs
    highlifter/EPI clutch kit
    2 inch spring spacer(rear only)
    10000k H.I.D kit
    29.5 outlaws(skinny/wide)
    Highlifter xl2 alum. wheels
    Power commander III
    HMF pipe
    snorkle
    uni filter
    audiopipe
    radiator relocation
    custom cooler rack
    other goodies......:)
    ______________"There is no cure"____________
    towneblacksmith
    Re: RE: Valve adjustment procedures for all Honda ATV's 2009/04/04 10:39:49 (permalink)
    does anyone know of another link to the 350 valve adjustment?
    07 rancher 420
    reverse mod
    custom front bumper
    Billet 4x4 shifter
    05 rancher 350
    reverse mod
    warn 424
    2 1985 trx125's
    kodiak660
    Re: RE: Valve adjustment procedures for all Honda ATV's 2009/04/04 12:37:03 (permalink)
    Here is the Rancher 350 link
    Rancher 350 valve adjust all years
    Videos
    #19
    kodiak660
    Re: RE: Valve adjustment procedures for all Honda ATV's 2009/04/04 12:40:19 (permalink)
    Here is the link for the 420.
    Rancher 420 valve adjust link all years
    Videos
    #20
    towneblacksmith
    Re: RE: Valve adjustment procedures for all Honda ATV's 2009/04/04 14:20:57 (permalink)
    thanks for the help.........someday I will figure out how to get them to work....lol
    07 rancher 420
    reverse mod
    custom front bumper
    Billet 4x4 shifter
    05 rancher 350
    reverse mod
    warn 424
    2 1985 trx125's
    #21
    kodiak660
    Re: RE: Valve adjustment procedures for all Honda ATV's 2009/04/04 14:30:06 (permalink)
    I just quoted the 1st post in this topic, copy the post # of the link that didnt work, then paste it in place of the post # on a good link.
    Videos
    #22
    kodiak660
    Re: RE: Valve adjustment procedures for all Honda ATV's 2009/04/04 15:57:06 (permalink)
    Wilster123
    i need one for the 300
    Here.
    300 valve adjustment
    Videos
    #23
    towneblacksmith
    Re: RE: Valve adjustment procedures for all Honda ATV's 2009/04/05 08:43:29 (permalink)
    kodiak660
    Thanks .....that makes sense
    07 rancher 420
    reverse mod
    custom front bumper
    Billet 4x4 shifter
    05 rancher 350
    reverse mod
    warn 424
    2 1985 trx125's
    #24
    strykr
    Re:Valve adjustment procedures for all Honda ATV's 2009/05/01 18:40:53 (permalink)
    Dynamo
    #25
    mab69us
    Re:Valve adjustment procedures for all Honda ATV's 2009/05/01 20:51:10 (permalink)
    not my post i just fixed all the links
    Dynamo
    speling is noot my stong suite
    09 HONDA RANCHER AT 420 (WHT)
    08 HONDA RANCHER 420 (BLK)
    07 HONDA RANCHER 420 (CAMO)
    05 HONDA RANCHER 375 (RED)
    04 HONDA RANCHER 329 (YELLOW)
    99 YAMAHA KODAIK 400 (GREEN)
    #26
    redneckcl
    Dirt Monster
    Re:Valve adjustment procedures for all Honda ATV's 2009/06/26 23:21:40 (permalink)
    ok would it matter on my honda rincon 650 with the 715 bbk would the clearence be differnt or what
    CHARLES
    2003 honda rincon
    27" High Lifter Outlaw MSTs
    High Lifter Chrome Plated Aluminum XL2 Wheels
    High Lifter Pro Series Tire Sealant
    High Lifter Lift Springs - Front & Rear
    High Lifter Front Disk Brake Kit
    Sealed Gel Battery
    High Lifter Temp Gauge
    Fan Override Switch
    MBRP Stainless Exhaust
    High Lifter 715 cc Big Bore Kit with forged piston
    Dynojet Jet Kit
    K&N Air Filter
    New Oil Pump
    Advanced Timing Key
    Web Cam
    #27
    JPs300
    Re:Valve adjustment procedures for all Honda ATV's 2009/07/04 10:05:57 (permalink)
    redneckclok would it matter on my honda rincon 650 with the 715 bbk would the clearence be differnt or what
    Valve clearance stays the same. The only time it may change is if you have an aftermarket cam and the cam manufacturer calls for a different spec(I don't know of anyone doing so in the ATV realm).
    "In2Deep - our drinking crew has a mudding problem"
    '11 Max Limited -
    JPs Customs 4" lift, rad relocate, snorks, & audio tubes, 29.5 law2s on Pilots
    '08 Teryx -
    new build coming...
    http://s455.photobucket.com/user/JPShawgo/library/riding%20pics
    #28
    redneckcl
    Dirt Monster
    Re:Valve adjustment procedures for all Honda ATV's 2009/07/08 02:27:33 (permalink)
    heck i dont want to mess it up anymore than it allready is i bought the darn thing at mud nats from highlifter and it messed up on me the 3rd day of easy riding  i tried tinkerin with it but to no avail im just going to take it to my local shop thanks
    CHARLES
    2003 honda rincon
    Sealed Gel Battery
    Fan Override Switch
    Dynojet Jet Kit
    K&N Air Filter
    New Oil Pump
    Advanced Timing Key
    Web Cam
    #29
