LockedValve adjustment procedure for Rubicon
Guest
  • Status: online
2008/03/16 19:16:02 (permalink)
08 brute 650
28 swamplites on rattlesnakes
highliter springs
2in lift
dynatek cdi
almond secondary
6 Replies Related Threads
    Silverback
    RE: Valve adjustment procedure for Rubicon 2008/03/16 19:19:03 (permalink)
    Good post ATVtech [;)]
    rubicon_joey
    RE: Valve adjustment procedure for Rubicon 2008/03/18 21:49:14 (permalink)
    Glad you posted this, my service manual only gives me the clearances and no instructions (maybe I'm looking in the wrong spot). I adjusted mine tonight just guessing that it should be on tdc of the compression stroke, but now that you posted this I know I done it right.
    sold..(In the market for a new one now)...
    04 Red Honda Rubicon.....28X10 & 28X12 Maxxis Zilla's....Mud Buster Cam...2'' lift......EPI Clutch Kit...MSA Tork Wheels...HMF Utility series...Dyno Jet Kit...K&N Air Filter...Warn: 3.0 ci, bumper and 424 select...Detriot Gearless Locker...H/L Disc Brakes
    Badforeman475
    RE: Valve adjustment procedure for Rubicon 2008/03/18 21:51:48 (permalink)
    hey will this be the same for a 500 foreman cause I need the set big06 valves
    Silver 98 Foreman 450 DGL 14% Gear Reduction 475 BBK,Delta Custom Snorkel, Start-in-gear mod, DGL, Lift Springs, Jetted, Uni filter, cherry bomb exhaust Snorkel, Custom relocated fan/oil cooler, Manual fan switch, 28" Silverbacks on SS112's
    Delta Custom ATV's
    PM For motor work or custom parts
    http://phcustoms.activeboard.com/
    Pic of my bike http://www.myspace.com/blueforeman450
    Badforeman475
    RE: Valve adjustment procedure for Rubicon 2008/03/18 21:57:55 (permalink)
    lol never mind I saw the other post Dynamo is da man
    Delta Custom ATV's
    rubicon_joey
    RE: Valve adjustment procedure for Rubicon 2008/05/15 11:39:48 (permalink)
    Heres a little tip to save you a lot of trouble. The manual will tell you to remove the whole front fender, but theres a way around it.
    Remove the left and right side tank plastics (the black ones)and the black plastic on top of the tank.
    Remove the two bolts at the front of the tank under the handle bars. It's a little difficult to get to, but can be done.
    Remove snorkel pipe. This will require some effort and patience, but it can be done.
    Now remove the gear shift lever, there are two bolts on the frame and two screws holding the knob/lever on. Then remove the pin holding the linkage on and store the assembly out of the way.
    Now remove the two rubber straps on the tank and it will slide back out of the way. You will have to push up on the fender a little on the left side, but it will come out fairly easy. DON'T FORGET TO TURN THE GAS OFF, the hose will come off and leak gas every where.
    Now all you have to do it remove the two rivets holding the tank shield on and bingo your looking at the valve covers.
    Mnhonda05
    Dirt Monster
    RE: Valve adjustment procedure for Rubicon 2008/05/16 09:25:19 (permalink)
    where can i get those kinda instructions for a 02 foreman 450s?
