LockedSuzuki Vinson lift camber problem
Ddawson10
2018/04/20 06:02:09 (permalink)
I just installed a highlifter 2” lift on my 03 Suzuki Vinson 500, along with some 28s. Now it seems to have too much camber as the tires tilt out. Is there a way to fix this?
post edited by Ddawson10 - 2018/04/20 07:09:31
2 Replies Related Threads
    Re: Suzuki Vinson lift camber problem 2018/04/20 22:42:05 (permalink)
    Even when putting your weight on the bike and riding it around so the suspension settles down?
    doveman1
    Re: Suzuki Vinson lift camber problem 2018/04/21 09:19:57 (permalink)
    I know when I did lifts on trucks they always recommended leaving loose, setting weight on the ground and then tightening up. Might try that.
    I never did, too much of a pain with the tires in the way. Always let the alignment shop take care of that.
    Green 2015 Grizzly 700
    2in HL lift
    N2deep battery relocation
    Wild boar radiator relocation
