LockedSteering Stem Diameter
toms99tj
Mud Slinger
2018/07/05 08:23:08 (permalink)
Does anyone know the diameter of the steering stem where the upper bushing sits? My friend an I have an idea of replacing the bushing with a bearing and see if that helps with the stiff steering these things have. Any help is appreciated. Thank you
1998 Foreman 450
30 inch Zillas on MSA M12
2 inch Highlifter Lift
Highlifter springs
Highlifter disc brakes
14% Gear Reduction
Snorkle
Stereo
__________________________
2000 Foreman 400
30" Zillas on 14" MSA Elixers
Viper 3000lb winch
DG muffler
Highlifter Disc Brakes
14% Gear Reduction
450 rear shocks with spacer lift
Foreman 400 rear adjustable shocks and 450 a arms
Warn 424
Home made snorkel
6" Audio Tube
ES Floorboards
3 Replies Related Threads
    Re: Steering Stem Diameter 2018/07/05 08:53:39 (permalink)
    Man bushing is cheap cheap. $10 bucks and it's split. Loosen the bracket and pop it in and done. Oh and put a little grease on it.
    toms99tj
    Mud Slinger
    Re: Steering Stem Diameter 2018/07/05 09:03:15 (permalink)
    I know that, but were thinking a bearing might be a little better than the rubber bushing.
    1998 Foreman 450
    Highlifter springs
    14% Gear Reduction
    Snorkle
    Stereo
    2000 Foreman 400
    Viper 3000lb winch
    DG muffler
    14% Gear Reduction
    Warn 424
    Home made snorkel
    6" Audio Tube
    ES Floorboards
    Re: Steering Stem Diameter 2018/07/05 09:23:01 (permalink)
    Still a lot of work for not much rewards. You would also have to grind of the bushing stop and depending on the bearing if it's tight that's a long ways to push it up.
