LockedShim mod for grizzly 700
GumboGrizzly
Dirt Monster
2009/04/06 18:40:22 (permalink)
 Ive been looking at the shim mod and i was wondering if anyone else is running it on there 700? Does anyone have problems with it? would it be enough alone without a clutch kit for 30's?
Grizzly 700 eps                          08 Grizzly 350           09 RZR
30" silverbacks                          26" laws                sunset red
14" ss112 wheels                     epi clutch kit               winch
2" lift                                         2" xtreme lift
Hmf exhaust and programer     Tranny Snorkels
dynatec ignition                        Power tip
Warn bumper                            Jet Kit
Snorkel,                                     2mm shim mod
Gorilla axles   HL clutch kit
Audiopipe
15 Replies Related Threads
    heith83
    Re:Shim mod for grizzly 700 2009/04/07 10:14:53 (permalink)
    i would get 8 kodiak 450 weights along with the shim and it should do fine. i done the shim mod along with the extreme clutch kit and it was a big improvement over just the extreme clutch kit
      700 Grizzly 2 inch lift, custom cluthed, shim mod 32'S, ss312, Dyna Ignition HMF Exhaust,PC3, Trinity 734 big bore kit, trinity pro ported head with big valves , mudbuster cam , fully snorkeled , monkey axles, 3000 pound gorilla winch XTR      more to come this is a money pit
    idneverownahonda
    Re:Shim mod for grizzly 700 2009/04/07 10:24:09 (permalink)
    i run it with my epi kit. Im thinking about taking it out though. It seemed to me like my bike is reved up to high around 35 or 36mph.
    2009 Black 700 Grizzly FI
    14" Vision Buckshot Wheels
    30'' Backs
    2'' HL Lift
    1.5'' Spacers
    E.P.I. Mudder Clutch
    Custom Snorkles
    HMF Swamp Series
    PCV
    Dynatek CDI
    H.I.D. Conversion Lights
    2500lb Warn Winch
    http://photobucket.com/Mats_Pics
    grizzly guidry
    Re:Shim mod for grizzly 700 2009/04/07 10:51:59 (permalink)
    it will give you higher reves when at a speed of 35 or so.. its because the belt is ridding lower in the sheve.. so you will loss some top speed but gain on the bottom end..
    2010 CATVOS Big Bear !!!!!
    TEAM N.I.O.N
    " Nail It Or Nothing "
         I'll Show you how deep the water is !!!!!!
    hls
    Re:Shim mod for grizzly 700 2009/08/07 15:30:17 (permalink)
    so can u just run the shim mod?
    2015 XMR 800
    BONE STOCK!
    07 outty 800 SOLD!
    hmf utility
    optomizer
    uni air filter
    29.5's on ss108's skinny/wide combo
    audio system
    performance atv snorkels
    pipe lift
    03 kodiak 488 BROKEN AND SOLD!
    overfenders
    27" mudzillas
    hmf utility
    snorkels
    clutch kit
    jet kit
    1.5inch wheel spacers on all 4
    Muddin_dude05
    Re:Shim mod for grizzly 700 2009/08/07 15:48:39 (permalink)
    Ya you can do just the shim but for 30"+ tires you need atleast 4 kodiak weights, white EPI spring and then 2mm of shim.
    '07 Green Grizzly 700EFI
    Snorkeled
    Clutched Greaseless
    Glasspack'd
    All Gorilla'd
    BA Tie rods
    Sittin' on 31" Outlaws
    Split-Tube tunes
    hls
    Re:Shim mod for grizzly 700 2009/08/07 16:20:18 (permalink)
    aw man all i wanted was just a lil more bottom end pick up runnin like 26's...lol so do the kodiak weights lower the gear ratio so to speak just like the shims do or what?
    2015 XMR 800
    BONE STOCK!
    07 outty 800 SOLD!
    hmf utility
    optomizer
    uni air filter
    audio system
    pipe lift
    overfenders
    27" mudzillas
    hmf utility
    snorkels
    clutch kit
    jet kit
    Muddin_dude05
    Re:Shim mod for grizzly 700 2009/08/07 17:01:27 (permalink)
    weights change the width of the primary sheaves with RPM, the lighter weights you have the higher it revs to get the same amout of travel as with heavier weights.
    secondary clutch holds the belt tighter and a little higher in the secondary, and requires more force to spread the sheaves apart, so it stays in lower gear longer with stiffer springs.
    the shim increases the width in the primary which allows the belt to ride lower in the primary, which reduces gearing some.
    Snorkeled
    Clutched Greaseless
    Glasspack'd
    All Gorilla'd
    BA Tie rods
    Split-Tube tunes
    newgrizzlylooking
    Re:Shim mod for grizzly 700 2009/08/07 17:36:22 (permalink)
    I have a 550 with 30" backs.  The shim didn't make that much of an improvement over the clutch kit IMO.  I can tell it's there but glad it wasn't more than $8.  You will need the white secondary and at least 4 kodiak weights to get it to run good.  When you put those heavy beast on (mine tip a little over 60 w/ wheel each) you are going to lose alot of power.
    2012 Renegade 1000
    30" backs
    HD3's
    Snorkeled by Performance ATV Parts
    2" High Lifter lift
    Tuned by TWISTED SOUNDS
    2008 KQ450
    Power mods
    clutch mods
    Administrator
    Re:Shim mod for grizzly 700 2009/08/07 17:49:11 (permalink)
    Is there anyone machining the primarys for the Grizz..?  this is the best way to go IMO, you get more lowend and dont lose any top end on them at all.
    I had 3.2mm cut out of mine which is a pretty big drop in gearing. I know theres alot of KQ700 guys that have had this done as well.
    08 650H1 L.E.
    Custom tie rods ;
    29.5" Laws on ITP type 7s
    XLCat
    Re:Shim mod for grizzly 700 2009/08/07 18:33:28 (permalink)
    The shim helped mine out quite a bit.  Lower gearing throughout the powerband.  My grizz won't hit the rev limiter w the stockers or 28s so I lost no speed anyways.  I'd run a shim even on a bone stock unit.  Really, the larger tires make up for the lost ratio in the CVT in most cases.  But, GWC is right, re-angling the primary would be ideal.
    07 700 GRIZZLY---Outlaw MSTs: 28x9.5, 28x12; Warn 3000 w Amsteel, (4) CEC 1" spacers, UNI filter, 1.25" bar relocation, removed shifter lockout, exhaust tip, 9003 SilverStars
    01 Cherokee, Rusty's Long Arm setup, 4.5" coils, 3.5" leafs w 1.5" shackles, Rusty's HD trac bar and mount, Rusty's steering linkage and steering box brace, no sway bars, 8.8 rear w discs, HP Dana 30 front, 4.10s, hardcore front bumper---it'll flex just a tad!
    "Don't move, he'll do it!"
    stroker101
    Re:Shim mod for grizzly 700 2009/08/07 21:14:39 (permalink)
    i was looking at my primary sheave today while installing the white secondary spring and from what i saw, i don't think i would install any shims. the belt is riding low already and if a shim was added, the belt would ride way too low and bottom out on the shaft. possibly start slipping.
    2007 Grizzly 700 (blue) 31" laws (wides) SOLD - mistake
    2007 Grizzly 700 (red) 29.5" laws (skinnies),Wild boar rad. relocate, Rox Riser's, ProTaper bar,
    2009 YZ450F, WorksConnection, Renthal, Bridestone, Shoei, Alpinestar
    2009 HD Soft-tail Fat Boy, V&H Big Radius pipes, Fat Boy Lo bars
    2010 Polaris Ranger Crew 800 29.5" laws (s/w),#4500 lb winch w/syn line, aux lites, restrictor MIA,2" foward A-Arms, aux. LED's (wanting 6" lift and 31's)
    2011 YZ450F, Factory Connection suspension, Works Connection Rad braces, Renthal, Thor, TwinAir, Alpinestar, Shoei, DrD engine relocation kit,
    jbrinkley0826
    Re:Shim mod for grizzly 700 2009/08/07 23:12:41 (permalink)
    I have tried a few different setups on my grizz.  here's what I tried and the results.
    first- changed to 4 kodiak weights and 4 stock weights.  increased bottom end a little, helped with 28" swamplites.  (terrible tires but thats another conversation)
    second- added 1.5 shim.  small increase in bottom end...  not enough to tell any difference really.  (running 28" zillas)
    third- removed 1.5 shim and added the epi white spring to the 4 kodiak weights.....  happiness..  torque monster now.  Done with clutch work.  :-)
    2008 Yamaha Grizzly 700 ---SOLD
    2009 RZR S
    opiegriz450
    Re:Shim mod for grizzly 700 2009/08/07 23:22:03 (permalink)
    i done the same thing, and its a beast in low gear, high gear not so much, but it will run, just seems wierd when it  gets there,
      I set mine up for looks and the fish LOVE IT !!!!
    "TEAM DO WORK"
    Emanuel Co. Chapter
    SDC Supporter
    07grizzlymud
    Re:Shim mod for grizzly 700 2009/08/08 01:24:12 (permalink)
    I'm thinking of doing mine. Just looking for a spare one to send away and get done. Didn't have any luck finding someone to do it up here in Canada.
    07 7** Grizzly 2' lift, Snorkels, 29.5 Laws, Airdam//, Barkers Duals, Dyntek, PC5, Wide
    09 800 RenegadeRT, snorkels, Full STM clutches, Gorilla rad/bumper.
    XLCat
    Re:Shim mod for grizzly 700 2009/08/08 07:20:53 (permalink)
    Haven't had a problem w slippage, but I did run 8x 660 weights for awhile.  The machine revved out too much and didn't accelerate quickly enough for me.  Too much noise as well.  I took them back out and put the stockers in.
