LockedSYMPTOMS OF VALVES OUT OF ADJUSTMENT?
KAWASAKI2374
2007/01/02 13:09:45 (permalink)
I was wondering what are the symptoms of valves being out of adjustment
I have a 2005 brute 750 2400 miles never adjusted the valves
21 Replies Related Threads
    shife
    RE: SYMPTOMS OF VALVES OUT OF ADJUSTMENT? 2007/01/02 13:25:17 (permalink)
    One thing off the top is difficulty starting.
    2007 Rhino 450 Trailer Queen
    aaroncs
    RE: SYMPTOMS OF VALVES OUT OF ADJUSTMENT? 2007/01/02 14:48:43 (permalink)
    Lack of power , tapping noise in the top end of the motor , but don't confuse this with piston slop or a cam chain slapping .
    TBC RACE TEAM
    FCP BUILT MOTOR
    SPONSORED BY-WEB CAMS/WISECO/INTERCO TIRES/FLYNTS PERFORMANCE/AMSOIL/SIMPLE GREEN/FULMER HELMETS/PB.BLASTER/ G - AXLE/YASKY ATV/KLIM USA/DAYCO BELTS /POWER MADD/SPIDER GRIPS/PWR PERFORMANCE
    CUSTOM TUNING AT MaD MOTORSPORTS
    Face book - look up Aaron Sporna
    http://mudanddirt.com/
    teamgreen700
    RE: SYMPTOMS OF VALVES OUT OF ADJUSTMENT? 2007/01/02 14:54:34 (permalink)
    i have problems with my prairie starting if it is the slightest coldit will not start but just a little temp change and it will start do you think the valves may be out of adjust on mine also it has a light tapping noise on the top end and if i rev it up after it warms up i get a sort of pingin noise
    mine 2005 prairie 700 team green 27" mud b@tches hand guards, custom front bumper
    mine we'll see what fills this spot
    dads 2005 brute force 750 camo 27" vampires highlifter module
    brothers 2007 grizzly 660 blue, 28" mudbugs,winch
    1978 F-150 351m auto 12" lift 38'' boggers
    1978 f-150 built 351, 4 spd 4" lift and 38" swampers
    WWW.WFOMUDSLINGERS.COM
    GSXR
    RE: SYMPTOMS OF VALVES OUT OF ADJUSTMENT? 2007/01/02 16:47:48 (permalink)
    Hard to start due to loss of compression exhaust valves tightening up will hold vavlves open to long. Intake seem to get loose an make a tapping sound. This is what happen in my case.
    '07 Brute Force Full Muzzy Exhaust, clutch mod with red primary spring & dynatek cdi., Wiseco pistons, head work, cam shafts. 71 rwhp.on 25 inch tires. Nitrous Express kit
    BFR Performance
    www.myspace.com/bruteforcerandy
    aaroncs
    RE: SYMPTOMS OF VALVES OUT OF ADJUSTMENT? 2007/01/02 16:59:43 (permalink)
    ORIGINAL: teamgreen700
    How many miles are on yoru bike ? Have they ever been adjusted ?
    As far as not cranking Every bike with carbs acts differently to the change in weather temps . Mine is cold natured it don't like to crank cold either .
    Have you ever put new plugs in it ? The Pinging noise what grade of fuel are you running in it ? Are you sure its Pinging or is it pistion slop ?
    TBC RACE TEAM
    FCP BUILT MOTOR
    teamgreen700
    RE: SYMPTOMS OF VALVES OUT OF ADJUSTMENT? 2007/01/02 17:05:56 (permalink)
    1700 miles original plugs getting new ones just waitin for em never had valves adjusted i dont know wat fuel watevers cheapest
    aaroncs
    RE: SYMPTOMS OF VALVES OUT OF ADJUSTMENT? 2007/01/02 17:10:27 (permalink)
    stay with the cheap stuff on fuel . change the plugs there cheap and can make a big difference if there need .
    1700 miles and never adjusted , I think I would check them . Get a service manual and make sure ......
    YOU FOLLOW THE DIRECTIONS !!!!!!!  Making them too tight or too loose can cause big motor problems !!!!!!!
    TBC RACE TEAM
    FCP BUILT MOTOR
    SSTOGI
    RE: SYMPTOMS OF VALVES OUT OF ADJUSTMENT? 2007/01/02 17:36:13 (permalink)
    I can't count how many times I've heard someone say "Yes I checked them and they are not loose"   You are right aaroncs, tight valves are more a problem then loose ones. A little loose is always better. Always adjust to the high side of the specs. As long as they are not so loose the tap they'll make more power on the loose side. Also, Long duration cams will by their nature have a slap to them .
    BF750 BUILT FOR BUSINESS
    Stock is for pansies
    teamgreen700
    RE: SYMPTOMS OF VALVES OUT OF ADJUSTMENT? 2007/01/02 18:57:11 (permalink)
    a guy i know is gonna check it for me he works at a kawi dealer
    Joedirtrider360
    RE: SYMPTOMS OF VALVES OUT OF ADJUSTMENT? 2007/01/02 19:06:49 (permalink)
    if you piped it with out the rite jets its probley needs it this happend to me
    is the plug black or white or blows black smoke every once in a while (if the motor doesnt breath rite its def time for an adj )
    aaroncs
    RE: SYMPTOMS OF VALVES OUT OF ADJUSTMENT? 2007/01/02 21:17:28 (permalink)
     yes this is true .. but looking at his sig he has no mods ??? TeamGreen700 ..am i right on this ???
    TBC RACE TEAM
    FCP BUILT MOTOR
    mudracer80
    RE: SYMPTOMS OF VALVES OUT OF ADJUSTMENT? 2007/01/03 12:26:21 (permalink)
    Where can I get a manual that shows how to adjust the valves?
    06 650H1 prowler xt
    Grizzly 660 5.5 lift
    gixxer1000
    RE: SYMPTOMS OF VALVES OUT OF ADJUSTMENT? 2007/01/03 15:33:35 (permalink)
    mine taps like a bit*h, but has no loss of power or difficulty starting. It doesnt smoke or anything else, just taps
    07 black 650i, very slow
    aaroncs
    RE: SYMPTOMS OF VALVES OUT OF ADJUSTMENT? 2007/01/03 16:16:57 (permalink)
    ORIGINAL: mudracer80
    you owners manual has allot of the info you need to do regular maintenance
    on your bike . or your local ATV shop ! there not cheap though .
    TBC RACE TEAM
    FCP BUILT MOTOR
    aaroncs
    RE: SYMPTOMS OF VALVES OUT OF ADJUSTMENT? 2007/01/03 16:19:46 (permalink)
    ORIGINAL: gixxer1000
    Just because it don't smoke don't mean its not piston slap , or cam chains . Some tapping is norm . there not roller motors .
    ....................well the can-ams are . [:o]
    TBC RACE TEAM
    FCP BUILT MOTOR
    teamgreen700
    RE: SYMPTOMS OF VALVES OUT OF ADJUSTMENT? 2007/01/03 17:18:21 (permalink)
    the only mods i have are a k&n filter should i rejet with that cause my dads brute has the highlifter chip and the K7n and the dealer told us to put the stock one in cause it wont run as good with the k&n
    gixxer1000
    RE: SYMPTOMS OF VALVES OUT OF ADJUSTMENT? 2007/01/03 17:19:55 (permalink)
    ORIGINAL: aaroncs
    how do i check for piston slap or cam chains. after a ride this weekend I am planning on finding that tap, it is driving me crazy. Even if it takes a new motor.
    SSTOGI
    RE: SYMPTOMS OF VALVES OUT OF ADJUSTMENT? 2007/01/03 17:35:00 (permalink)
    Click on the Link in my sig then save the site to your favorites list on your computer. It has all the info you need to do anything  on the Brute 750
    #19
    SSTOGI
    RE: SYMPTOMS OF VALVES OUT OF ADJUSTMENT? 2007/01/03 17:38:43 (permalink)
    ORIGINAL: SSTOGI
    Wait........My bad ! You ain't got a Brute.  Well anyway, Kawasaki12374 there it is if you need it.
    post edited by SSTOGI - 2007/01/03 17:40:25
    #20
    88rxn/a
    Re: RE: SYMPTOMS OF VALVES OUT OF ADJUSTMENT? 2009/06/07 17:39:11 (permalink)
    lets say i take mine to a local mechanic (not a dealer) how long does it usually take to adjust the valves??
    lets ride!!
    08 BF 750 EFI
    27X9 front
    27X11 rear
    ZILLA'S
    #21
    Bruteman1989
    Re: RE: SYMPTOMS OF VALVES OUT OF ADJUSTMENT? 2009/06/07 18:25:17 (permalink)
    What are the valve specs?
    06 Brute Force 4x4i
    2" HL Lift
    HL Lift Springs
    29.5" Outlaws
    Bayou Snorkles
    Power Commander III
    Supertrapp Exhaust
    and more to come...
    #22
