LockedSNORKELING A KODIAK WRITE UP
STUMP KNOCKIN 450
2008/09/18 20:57:41 (permalink)
well there has been a ton of questions about how to snorkel a kodiak/grizzly 450.  so here it goes:
tranny intake:
-remove the factory intake snorkel by loosening the allen head clamp on the rubber coupling on the intake side of the tranny.
-pull the top of the snorkel down and it should slide out of the hole in the plastics and slide right out.
-nest remove the front rack and the black plastic "hood".
-once the hood is removed you should see a square "bowl" with a circle in the middle where the stock snorkel came up.  cut this bowl out using a dremel tool.
-now you can attatch a 45* elbow to the rubber coupling on the intake side of the tranny and point it up.
-insert a 10 inch or so piece of pipe into the elbow and attatch another 45* elbow to the top of this pipe and point it forward.  now take some flex hose and run it forward so that it is under where the "bowl" used to be.
-attatch a 45* elbow to the end of this hose and position it so that the snorkel can come out of it.
tranny exhaust:
-remove the stock exhaust snorkel snorkel.  it should be held on by 4 (i believe) plastic rivets just in front of the tail light and a rubber coupling that is tightened by an allen head hose clamp.
-after you remove this bou can insert a 90* elbow into the rubber coupling and tighten it down.  it is a snug fit to get the elbow in, but it does fit.  turn it so that the open end is pointing to the left side of the bike.
-nest take a short (maybe 5 inch) piece of pipe and insert it into the 90* elbow.
-then put another 90* elbow on pointing the open end forward.
-next take off the left floor board by removing the 6 allen headed bolts and the 2 bolts on the foot peg.
-now use white flex spa hose to run up the left side of the engine.  between the transmission and the frame.
-once in front of the engine take a 45 degree elbow and attatch it to the spa hose with the open end pointing up and a little to the right side of the bike.
-now run flex hose up beside where your intake snorkel is ran to.
-to get the hose to run to the front you will need to put in a 45* elbow along the way.
-now once you get the hose up to the front put a 90* elbow so that the snorkel can attatch here.
-now put the hood on and cut out so that 2, 1.5 inch pipes can fit through it.
-attatch the 2 pipes and cut to the height that you want them.
-now put any type fitting that you like on the top.  i personally made a 180* turn by using 2 90* elbows.
airbox:
-remove the airbox lid and cut off the part that goes "up".  i dont really know a great way to describe this, but basically cut off the "hill" on the top of the lid.
-now cut a piece of plexiglass that will fit over the hole.
-glue this plexi glass to the top of the lid.
  -for the glue i used 3M 5200 marine sealent.  it makes a almost inpenetrable permant bond.
-now cut a hole that will allow a male 1.5 inch coupling to fit through in the plexiglass.
-insert the male coupling through the bottom of the lid.  glue in this fitting.
-attatch a 90* elbow to this fitting. and then attatch another 90* elbow to that elbow and make them right next to each other.
- make this 180* fitting that you built turn to the right.  side of the bike.
-now attatch a 45* elbow to the 90* elbow and make it point to the front of the bike.
-attatch a pipe to the 45* elbow that will reach up almost to the shock mount.
-now attatch a 90* elbow to the end of this pipe and point the open end to the left side of the bike.
-next run a piece of flex hose to the left side of where your tranny exhaust came out.  put a 90* elbow on the end of this hose and point the open end up.
-now the end of the pipe should be under the left side of the hood.
-cut a hole in the hood where the vents are so that the snorkel can come out there.
-run a piece of pipe through the hood and connect it to the 90* elbow.
-now make a piece to put on the top.
now you can re install the hood for good and put the rack back on.  and reinstall the left floor board.
make shure that you glue all the fittings well.  i used pvc cement personally.
paint your snorkel stacks black, or whatever color you want them and you shoud be done with you snorkels.
now you need to extend all the vent lines. and plug the carb drain.  there should be 4 or 5 vent lines to extend.  i cant remember right now.  the only thing left to do is di-electric grease all your electrical connections and your bike should be good and water-proof.
as for underwater idling...you can get a HMF pipe and adjust your idle up.
to adjust up the idle get on the bike and put it in gear.  then adjust the idle screw (located on the left side of the carb, its a thumb adjustable screw with a rubber hose attatched to the back of it. up until the bike starts to move and then back it down just a little.  this will keep it low enough to safely shift while allowing you to easily idle under water.
if i have left anything out, or you have any questions or need pics then PM me and i will be glad to help.
06 Yamaha Kodiak 450 Outdoorsman Edition
Custom Full Snorkles
Custom Bumper
Custom Audiopipe
Strobes
2 inch HL lift
2.5ci WARN winch w/ amsteel blue-front
WARN A2000-rear(coming soon)
HMF pipe
DynoJet Kit
Twin Air filter
EBC severe duty brakes
28x10 EDLs-front
28x12.5 Laws-rear
1.5 inch wheel spacers
HL outlaw clutch kit
1979 CJ5-work in progress(should be done soon)
2002 Chevy Avalanche Z71-a few goodies
38 Replies Related Threads
    zillaman450
    RE: SNORKELING A KODIAK WRITE UP 2008/09/23 11:47:44 (permalink)
    did u have 2 rejet ur bike? bc i jus done a kodiak snorkel job and it misses at high speeds and i used 1.5 pvc and spa hose?
    Boudreaux Customz
    09 Camo RZR
    Oem s suspension
    Turner lift brackets
    Custom tunes & snorks
    Looney tuned duals
    PCV-Custom Map
    HIDs
    30’’mudlites on black ss108s
    lightmud
    RE: SNORKELING A KODIAK WRITE UP 2008/09/26 15:50:48 (permalink)
    You will have to re jet and I notice in his sig that he has a dynojet kit.
    2008 Teryx
    VFORCE JOHN Stage 3 Clutch
    Dynatek CDI and Coils
    Full Muzzy Standards
    Carbs Jetted
    Aluminum Roof
    Tunes
    27" Black Diamond XTR's
    STUMP KNOCKIN 450
    RE: SNORKELING A KODIAK WRITE UP 2008/09/26 16:01:27 (permalink)
    yes i did re jet it.  as stated above i used the dyno jet kit.
    Custom Bumper
    Custom Audiopipe
    Strobes
    2 inch HL lift
    HMF pipe
    DynoJet Kit
    Twin Air filter
    28x10 EDLs-front
    28x12.5 Laws-rear
    littlegrizz
    RE: SNORKELING A KODIAK WRITE UP 2008/10/12 19:35:56 (permalink)
    can i see some pictures please?
    2007 Honda 500 foreman S
    Under the knife
    2004 Honda 450 ForeMAN S
    31" Laws
    SS 212s
    4" Custom Lift
    Highlifter Lift Springs
    Dyno Jet kit
    Gear Reduction
    EPI Clutch Kit
    Triangle ATV Snorkel
    HMF
    2001 Honda Foreman 400
    SNorkels
    Lift kit
    30 " Mudzillas
    2008 Polaris RZR 800
    30" S-backs SS rims
    3" lift
    2008 Suzuki Vinson
    27 inch mudlight XTRs
    1994 dodge 2500 4x4 12 valve
    Lots and lots of goodys under the hood
    780hp going to a set of 35 inch nitto mud grapplers
    18" ballistic jesters
    Swamper350
    RE: SNORKELING A KODIAK WRITE UP 2008/10/12 20:01:29 (permalink)
    some pictures would be nice [;)]
    07 Grizzly 350 4x4 IRS:
    27'' Swamplites
    SS 108's
    HMF Utility Series
    DynoJet Kit
    Dual Snorkels
    3000 Pound Winch
    Mad Dog Seat
    "Go deep or stay home!"
    STUMP KNOCKIN 450
    RE: SNORKELING A KODIAK WRITE UP 2008/10/12 21:35:48 (permalink)
    ill try to take some pictures soon.  but deer season is here so it might take me a while.
    Custom Bumper
    Custom Audiopipe
    Strobes
    2 inch HL lift
    HMF pipe
    DynoJet Kit
    Twin Air filter
    28x10 EDLs-front
    28x12.5 Laws-rear
    soundguy1990
    RE: SNORKELING A KODIAK WRITE UP 2008/10/15 15:50:33 (permalink)
    will this work on the 400 kodiak
    06kodiak4x4
    RE: SNORKELING A KODIAK WRITE UP 2008/10/15 19:23:55 (permalink)
    I have the same 06 Kodiak, Special Edition Colors, i would appreciate pics of the airbox, i have been agonizing over how to do this
    06 yamah kodiak 450
    27" mudbugs
    2" high lifter lift
    k & n air filter
    hmf pipe
    dyno jet
    epi clutch kit
    1 1/2" spacers
    2,500 # warn winch
    stick stoppers
    danderson
    RE: SNORKELING A KODIAK WRITE UP 2008/10/16 09:26:51 (permalink)
    mine ran fine before i jetted it?
    jtwthird
    Dirt Monster
    RE: SNORKELING A KODIAK WRITE UP 2008/10/21 09:50:51 (permalink)
    easy way to keep from having to rejet is to put a ball valve somewere on the snorkel pipe, this allows you to adjust you air flow. Mine ran bad until I did  this.
    2001 Kodiak 400 rebuilt
    3000lb Wireless Remote winch
    27" mudlite XL
    front and rear fog lights
    mp3 player with Amp
    Radiator on front rack
    Belt drive snorkels
    Intake snorkel
    Wife
    2008 Grizzly 350
    belt drive snorkel
    3000 lb winch
    mp3 player with amp
    rear fog lights
    Team Poke-N-Wheeler's
    STUMP KNOCKIN 450
    RE: SNORKELING A KODIAK WRITE UP 2008/10/21 17:27:08 (permalink)
    ORIGINAL: jtwthird
    this is true.  however you are giving up power that you could potentiolly gain.  by rejetting you are getting more air and fuel to the motor which gives you MORE POWER!!!!!
    Custom Bumper
    Custom Audiopipe
    Strobes
    2 inch HL lift
    HMF pipe
    DynoJet Kit
    Twin Air filter
    28x10 EDLs-front
    28x12.5 Laws-rear
    biggblu601
    RE: SNORKELING A KODIAK WRITE UP 2008/10/21 22:52:48 (permalink)
    pics would be kool. i have a 06 Kodiak 450 4wd blue and all and am fixing to snorkel it and all. It was a good write up to thanks
    big_stroker
    RE: SNORKELING A KODIAK WRITE UP 2008/10/22 07:07:34 (permalink)
    I also would love to see some pics...
    2000 Kodiak 400 4x4
    2500lbs Warn Winch
    K&N Air Filter
    26" Kenda Executioner Mud Tires
    jason228
    RE: SNORKELING A KODIAK WRITE UP 2009/02/22 14:06:11 (permalink)
    tt
    2008 500 Foreman ES 4x4
    28" Laws
    ITP SS108 rims
    Snorkeled
    2" lift
    HMF
    2008 Honda Foreman 500 4x4 ES
    27in silverbacks
    212 ITPs (black)
    Snorkeled
    HMF Swamp series
    MasterMudder
    RE: SNORKELING A KODIAK WRITE UP 2009/02/22 14:48:50 (permalink)
    How long does Snorkelling actually take?
    Yamaha Bruin 350 4x4
    Under Construction
    Honda 300 4x2
    Kenda Scorpions
    grizz450
    RE: SNORKELING A KODIAK WRITE UP 2009/02/22 18:19:42 (permalink)
    it would help if there were pics
    trail:07 siver grizzly 450
    warn 2.5 winch
    hmf utility
    k&n
    outer wears pre filter
    hmf jet kit
    tag xd handlebars
    coming soon:
    wheels and tires
    LOTS MORE ON THE WAY!!
    96 yamaha timber wolf 4x4
    2005 polaris trailblazer AKA:wheelie monster
    I lift up my eye onto the hills,
    Where does my help come from?
    My help comes from the lord,
    The maker of heaven and earth.
    psalms:121
    bushhog750
    RE: SNORKELING A KODIAK WRITE UP 2009/02/22 18:34:54 (permalink)
    pictures say 1000 words. worthless w/o pics.
    08 outlander 800 XT red- 6'' CATVOS lift - MaD Cannon tuned- bushs center snorkles- clutch work- itp ss212's black- 29.5" outlaws- power commander- hmf pipe- uni filter- pipe lift- gorilla radiator relocate- ricochet skid plates- coolanol- crankcase vent mod- amsoil fluids- spider grips- sponsored by VISA and 60 hours a week.
    I_PullHondasOut
    RE: SNORKELING A KODIAK WRITE UP 2009/02/22 22:13:33 (permalink)
    OG BamaBoggers
    2013 Camo Crew
    Forward Arched A Arms
    BI/Tri combo
    Full Tilt Windshield
    2" Hard Pipe Snorkel
    Super ATV Front bumper with 5k viper
    Waiting on Custom Roof with
    Plash Lights
    #19
    gpinjason
    Re: RE: SNORKELING A KODIAK WRITE UP 2010/01/09 14:48:43 (permalink)
    Just wondering if anyone ended up getting pictures of this?  working on my 400 and need some ideas...
    Jason
    His:
    09' Brute Force 650i
    - 28" Skinny Backs - HL 3GX Belt - Pink Primary - Lime Green Secondary - MIMB Snorkels - Moose Module - 2" lift - 1.5" Spacers on rear
    01' Jeep Wrangler
    - 7" lift - 36" Iroks - 4.88 gears & lockers front/rear
    - Pavement is optional...
    Hers:
    02' Kodiak 400
    - 27" Executioners - Custom snorkels - More to come...
    #20
    chrisb76
    Re: RE: SNORKELING A KODIAK WRITE UP 2010/01/09 20:13:41 (permalink)
    ok guys i'll get some pics of the bike i did so everyone will have the idea since this guy didn't seem to want to add them.my snorkel never involved all the work of this write up either.also i ran 1 1/2 pvc all the way from the airbox out,and it runs fine with the addition of a k&n filter.i'll get some pics in the morn. i gotta go to the shop for a few things anyway.
    old school kodiak
    6''lift,brute diffs.,gorilla's
    big ol' piston
    lots of balls
    TEAM ALL JACKED UP
    #21
    gpinjason
    Re: RE: SNORKELING A KODIAK WRITE UP 2010/01/11 10:02:56 (permalink)
    I'm working on my snorkel right now, and I will put up pics as well as a list of all fittings and stuff used when I'm finished...
    Jason
    His:
    01' Jeep Wrangler
    Hers:
    02' Kodiak 400
    #22
    SBmudhog
    Re: RE: SNORKELING A KODIAK WRITE UP 2010/01/11 19:49:22 (permalink)
    Thats how I did mine. I have a few pic
    Here is the exhaust for the belt case
    another of the exhaust vent near the front
    Here is one of the intake vent
    another of the intake vent
    For my air intake
    Not fancy but it works.
    Finished:
    Hope this helps you out!!
    05 Kodiak 450
    Maxxis Zilla's
    -28x10x12 front
    -28x12x12 rear
    Custom snorkels
    HMF Penland Pro
    K&N
    Dyno-Jet
    Machined Primary Sheave
    2500lb warn
    Ricochet A-arm guards
    #23
    gpinjason
    Re: RE: SNORKELING A KODIAK WRITE UP 2010/01/18 14:43:49 (permalink)
    on the belt exhaust, I see you came straight  up in front of the motor.  I couldn't figure out how to get it up there without the little arm that the tie rods connect to the steering shaft hitting it while turning..  maybe the 450 has a little more room than my 02 400?  is it possible to get some closer pics of that part?
    Jason
    His:
    01' Jeep Wrangler
    Hers:
    02' Kodiak 400
    #24
    chrisb76
    Re: RE: SNORKELING A KODIAK WRITE UP 2010/01/18 18:22:39 (permalink)
    here ya'll go
    old school kodiak
    big ol' piston
    lots of balls
    TEAM ALL JACKED UP
    #25
    chrisb76
    Re: RE: SNORKELING A KODIAK WRITE UP 2010/01/18 18:24:15 (permalink)
    old school kodiak
    big ol' piston
    lots of balls
    TEAM ALL JACKED UP
    #26
    chrisb76
    Re: RE: SNORKELING A KODIAK WRITE UP 2010/01/18 18:25:49 (permalink)
    as you can see theres no nutbuster here.
    old school kodiak
    big ol' piston
    lots of balls
    TEAM ALL JACKED UP
    #27
    FreddyB.
    Re: RE: SNORKELING A KODIAK WRITE UP 2010/01/19 22:38:43 (permalink)
    On my Ex 06 Kodi 450
    I Drilled holes on each side of the air box I put 2 90deg 1 1/4"  elbows one on each side (these were threaded in with a conduit nut on the inside and sealed with JB water weld). Ran the 1 1/4 " inch flex hose right along the frame rail on each side (extra Heat rap on the exhaust side through to the front and up to the rack. Very awesome with 2 - 1/14 in hose and a Dynojet 128 and Hmf pipe.
    Sorry I don't have any pics but it can be done you just gotta be creative.
    08 SP 800 HO
    RAD RELOCATED
    SNORKLED
    LIFTED
    LAWED
    TUNES
    HID'S (8000K)
    2000 Blue Wolvy 350
    DEEPTOUR
    NO WORMS ATV
    #28
    gpinjason
    Re: RE: SNORKELING A KODIAK WRITE UP 2010/01/19 22:50:00 (permalink)
    Chrisb76, where is the 3rd snorkel?
    Jason
    His:
    01' Jeep Wrangler
    Hers:
    02' Kodiak 400
    #29
    chrisb76
    Re: RE: SNORKELING A KODIAK WRITE UP 2010/01/20 22:21:32 (permalink)
    like i stated before there is no need for a 3rd snorkel.the tranny,and belt snorkel meet right at the hood,and go into one.i was gonna use a dummy pipe just for looks,but its a womans bike she will never need the snorkels anyway,but in case she makes a mistake they're there.
    old school kodiak
    big ol' piston
    lots of balls
    TEAM ALL JACKED UP
    #30
