Hot!Recoil housing
Babayagga
2020/03/12 22:29:54 (permalink)
Recoil housing
I have a 2008 king quad 750 with a secondary recoil starter. Does anyone have any ideas on sealing the recoil housing but still being able to use the pull rope ICE???
1 Reply Related Threads
    Re: Recoil housing 2020/03/13 16:17:00 (permalink)
    Man there's no real way to get the housing sealed and still be able to use the pull rope. The rope itself will wick water into the housing. So all you can do is make sure your pull handle is not cracked and not sitting tight over the housing. The other thing to do is drill a 1/4 inch hole on the bottom side of the cover to allow the water that gets in to drain out.
