LockedRear Differential Seal for Honda 420
Page: < 12 Showing page 2 of 2
doveman1
Re: Rear Differential Seal for Honda 420 2017/12/17 16:53:35 (permalink)
Grease has worked fine on trailer wheel bearings it’ll be fine in a rear diff. Use a good quality marine grease. I wouldn’t run to tractor supply and get their over priced junk. Lucas has a Marine grease that would work good.
As far as getting it in there cleanest way is to drill and tap the fill plug on the rear diff and screw a grease fitting in.
Green 2015 Grizzly 700
2in HL lift
N2deep battery relocation
Wild boar radiator relocation
#31
Re: Rear Differential Seal for Honda 420 2017/12/17 18:41:10 (permalink)
Ok take the filler cap and drill and tap it for a grease zert. I always put some 90 weight oil in then pump it then ride it them pump it and ride till the grease has pretty well filled all the viods. The 90 weight helps the grease sling a little better and in my opinion helps lube the upper pinion bearing.
#32
Jeepwm69
Re: Rear Differential Seal for Honda 420 2017/12/18 10:25:13 (permalink)
Grease supposedly works fine at lower speeds, but if you do anything over 30MPH on a regular basis your diff will definitely get hot.  Adding a little fluid with the grease would probably help.
I would look at swapping in a different diff.  I have read that the 2012-2013 tubed type Foreman rear end will bolt in.  That was from a reliable source, but I haven't done it myself.
The 420 rear end is a POS.  It's just like the 300 and will not keep out water.  Best to replace it than to keep putting bandaids on a crap design over and over again.
I've picked up 4 300's in the last couple of months.  All of them will be getting 350D/250A/250ES rear ends rather than mess with the crap stock 300 diffs.  Luckily I've been picking up those tubed style rear ends over the years and now I finally have machines to put them on.
#33
