LockedRanger 800 SNORKEL
Ole Nasty
2014/02/05 09:51:01 (permalink)
Ranger 800 SNORKEL
1.  Is it possible to do with out cutting the bed or the frame?
2.  I see some of the kits use flexible hose, does it being squeezed up between the bed and seats effect how it runs?
3.  I know on my Sportsman 500HO I had to remove the primary and seal up behind it, are the 800 Rangers the same way?
On the last 2 ATV/UTVs I sold, I'm pretty sure I lost a few sales because they were snorkeled, also this is still under warranty.
2011 Grizzly 700 EPS
29.5" Highlifter Outlaws
2mm Shim Mod
EPI White Spring
Snorkeled
Wild Boar Radiator Re-locate
2" Highlifter Lift
Yamaha HD front bumper
2014 Polaris Ranger XP 800
All Stock
Gone
2005 Yamaha Rhino 660
2009 Polaris Sportsman 500HO
   http://www.youtube.com/OleNasty79
8 Replies Related Threads
    Coreyflipp
    Re:Ranger 800 SNORKEL 2014/02/05 10:52:24 (permalink)
    There's a snorkel kit that runs up the front bar of the rollcage on the passenger side that hooks to your factory intake, looks kind of like what you see on the jeeps.
    You could probably get away with some sort of rubber hose on the belt intake/exhaust, don't know how it would work on the engine intake, just my opinion.
    CRSBear400
    Re:Ranger 800 SNORKEL 2014/02/05 12:16:00 (permalink)
    You could kick them out and run them out each side of the bed and secure them to the roll cage.  But, this isn't the best design especially if you're squeezing between trees on tight trails.
    ~ Cale Sanders
    '11 RZR 900XP LE White Lightning
    HL 5" lift, 28" OL2's & MSA Crushers, EMP 2" receiver hitch, EMP half windshield, OSS loaded roof, GORILLA/DHT AXLES, LTE full system, Dobeck Gen III, 5" cage chop, Polaris OEM doors, CRS snorkels
    SOLD!!!
    '14 Kawasaki Teryx 4 800
    CATVOS 3" Lift w/+2" F&R stretch, 31x9.5 Outlaws, MSA Beadlocks, 5" cage chop, flush steel roof, 2" bed lift, half windshield, Wetsounds 10 Sound bar, CRS LED Snorkels, LED underglow, 30" Rigid l
    450SP
    Re:Ranger 800 SNORKEL 2014/02/06 20:06:55 (permalink)
    Just recived my snorkel fit for my ranger 800 today. It's a snorkel my atv kit. By looking at the direction you take out the factory stuff behind the seat an cut a square in the flap on the bed.
    Ole Nasty
    Re:Ranger 800 SNORKEL 2014/02/06 20:23:11 (permalink)
    Take pics if you don't mind or PM them to me.   I figured the air baffle behind the seat would have to come out, I was messing round with some flex pvc earlier tonight.   I guess because I'm not looking at it right now but I can't think of what the flap on the bed is...
    2mm Shim Mod
    EPI White Spring
    Snorkeled
    2" Highlifter Lift
    All Stock
    Gone
    LovinTheRide
    Re:Ranger 800 SNORKEL 2014/02/07 21:38:54 (permalink)
    Here is a write up of the snorkelyouratv kit I did for my Ranger 800.
    http://www.prcforum.com/f...s-complete-w-pics.html
    It doesn't pinch the hose. Over 300 hour with it and still going strong!. Yes you do remove the clutch intake box behind the seat. This is the best list for not cutting the bed. Very easy to remove and reinstall.read all the write up to get the most info. I have lots of pics. I sold that ranger to a buddy and he rides deeper more often than I ever did!
    I will say this.... cutting the bed IS a better way to snorkel. There is nothing wrong with cutting the bed.... and you only have to cut a little. Some will say 11/2 hose is to small but after years of running it on my 800 there has yet to be a single issue with the kit. Plus it is very affordable and very easy to install!
    2012 Ranger XP LE Pearl White --- Sold!
    2014 Ranger 900 EPS LE White Lightning
    BackWoodsArmour Arched Front & Rear Aarms (Red and White)
    BackWoodsArmour 4" Adjustable Lift
    31" Outlaw Skinny Wides on White NoLimit Venons
    BackWoodsArmour Front Extreme Bumper
    5000# Viper Max Winch
     Triangle ATV Snorkels
    Polaris Nerf Bars
    ONE BAD**** Radio Top and Lighting System From Loud Noises Audio
    Rhino axles
    Ole Nasty
    Re:Ranger 800 SNORKEL 2014/02/07 21:53:41 (permalink)
    EXACTLY what I was looking for!  Thanks!
    2mm Shim Mod
    EPI White Spring
    Snorkeled
    2" Highlifter Lift
    All Stock
    Gone
    Team Quad Green4x4
    Re:Ranger 800 SNORKEL 2014/02/08 15:22:00 (permalink)
    or spend the extra money and buy the All Jackd up kit.
    2013 Walker Evans LE RZR XP 900
    powered by
    OUTKAST FABWORX
    All Jacked Up ATV/UTV
    Ole Nasty
    Re:Ranger 800 SNORKEL 2014/02/08 20:42:06 (permalink)
    2mm Shim Mod
    EPI White Spring
    Snorkeled
    2" Highlifter Lift
    All Stock
    Gone
