LockedRancher Angle Sensor replacement
1Bad450
2007/09/04 10:45:29 (permalink)
My Bro-in-laws rancher needs a new angle sensor.  He got the part today, but can't figure out where it goes and/or how to install it.  I have never had one go bad, so I don't know either.  It is a 2004 or 2005.
Any How-to's on how to replace this?  Or any pictures, instructions would be great.
Thanks,
Matt
Grizzly 700 EPS Camo - Rox 5" Risers - Fly CR Bend Bars - H&T Warmers - Warn 2500 - Powermadd Handguards - 14" Black ITP SS212's with 26" Bighorn 2.0's - UNI Air Filter - Airbox Screen Mod - Billet Exhaust Tip - Pod Mod (95) - Brush Guard - Camo Rack Bag
Sold:
Red Grizzly 700 EPS - Stuff
Yellow Outty 800XT - Stuff
Green RZR - Stuff
Black Rincon 650 - Stuff
7 Replies Related Threads
    swampedeiger
    RE: Rancher Angle Sensor replacement 2007/09/04 13:47:58 (permalink)
    not sure but a girl i know on a older rancher had promblems with hers and it was a warranty type deal so her dealership bought and put the peice on for free
    TEAM DO WORK
    14 Brute Force
    Hers 07 Brute Force
    1Bad450
    RE: Rancher Angle Sensor replacement 2007/09/04 13:57:49 (permalink)
    Yeah, this is out of warranty.  Even if it was under warranty, our honda dealer blames it all on you if you have mods.
    Sold:
    Green RZR - Stuff
    golfnlilj
    RE: Rancher Angle Sensor replacement 2007/09/04 14:03:10 (permalink)
    Its on the left side of the motor at the bottom. Just take two allen head screws out, unplug it, then preload the new sensor and put the bolts back in and plug it up.  Then use the manual to reset the computer.
    03 Honda Rincon
    29.5 outlaws
    itp type 7 chrome rims
    hl lift kit
    hl day light kit
    custom snorkel
    custom exhaust pipe with 3.5" exhaust snorkel.
    158 keihin main jet
    dynojet spring and needle on 1st notch
    axixtech lx4 LEDs blue/clear, red/clear
    gordo
    RE: Rancher Angle Sensor replacement 2007/09/04 14:17:37 (permalink)
    ORIGINAL: gol****lilj
    A buddy of mine is having probs with his,,,, what are you referring to when you say"preload the sensor"????
    '00 Fourtrax (Goober) Warn 424/ HL Disk Brake/Snork
    '97 Fourtrax (Prissy) Warn 424/ HL Disk Brake/Snork
    '96 Fourtrax (Cooter) HL Disk Brake/Warn 424 /Snork
    '94 Fourtrax (Ghost) HL Disk Brake/Warn 424 /Snork
    '94 Fourtrax (Maverick) HL Diskbrake/Snork/Warn 424
    '94 Fourtrax (Slider) Extreme Diskbrake/Warn 424/Snork
    '90 Fourtrax (Baby) Warn 424/Viper 2500 Winch/ HL Diskbrake
    1Bad450
    RE: Rancher Angle Sensor replacement 2007/09/04 14:37:18 (permalink)
    Thanks for the info.
    I think he means that there is a line on the sensor, and once it's on, your supposed to twist it to get the lines lined up and then bolt it back up.  Right?
    Sold:
    Green RZR - Stuff
    1Bad450
    RE: Rancher Angle Sensor replacement 2007/09/04 14:38:47 (permalink)
    Oh yeah, and how do you re-set the comp... I'm sure he doesn't have the owners manual or a repair manual anymore.
    Thanks again,
    Matt
    Sold:
    Green RZR - Stuff
    CajunRancher04
    RE: Rancher Angle Sensor replacement 2007/09/04 15:20:38 (permalink)
    The angle sensor is in the front of the motor towards the left side. I replaced my about two years ago and it is easier to get to if you remove the right front inner fender and go in from the right side. If you try to get to it from the left side, then the front drive shaft will be in your way.
    2004 Honda Rancher 350ES 4x4, 25" 589's, HL lift, HL clutch kit, Warn 2.5ci winch, Warn 424 select, Uni filter, Jet Kit
    98' Honda 300, 415cc, ported, polished, stroked, gear reduction, clutch kit, Warn 424, disc brakes, HMF, 28" Outlaws on SS108's
    07' Kazuma 110cc Falcon
    http://s231.photobucket.com/albums/ee165/Crhebert/
