Rancher 420 No Start
dmanMus
2019/05/07 12:14:46 (permalink)
Hey guys. Got my uncles 09 420. It’s the irs power steering model. Notbthat that would really make a difference. But anyways. It sat up in his garage for 6 years. Practically since it was new with a full tank of 87 with ethanol. Parked it cause his son moved away. Hooked a battery up to it. Turns over just fine. No start. Starts on starting fluid. Popped the fuel line off from the throttle body. No fuel coming out. Felt fuel pump not kicking on. Simple. Change fuel pump. Now it kicks on. Fuel comes out the line. Still no start. I figured it’s probably a clogged injector or the throttle body is gunked up. What’s the best way to clean that out or should I just buy a new injector?
2012 Honda Foreman 500 (SOLD)
2007 Honda Rancher 420 (SOLD)
2005 Honda Recon 250 (SOLD)
2 Replies Related Threads
    Re: Rancher 420 No Start 2019/05/07 20:11:41 (permalink)
    Pull the injector and try shooting some fuel injection cleaner through it. If it won't open up buy a new one. But I think if you can get some cleaner in it and let it soak it should blow out.
    Jeepwm69
    Re: Rancher 420 No Start 2019/05/15 15:06:55 (permalink)
    Safe to assume you drained the old fuel out and cleaned the tank before you tried to start it?
