Hot!Rancher 350 project
Page: << < ..678910.. > >> Showing page 6 of 18
Jeepwm69
Re: Rancher 350 project 2017/04/19 09:22:08 (permalink)
Agreed.  You will feel ZERO difference from simply boring and going .20, .40, .60 etc.  I have a 500 Foreman that is bored out .75 over and it has no more power than it did stock.   To feel power you have to actually go big bore.  Just hone it and put some rings in it, or take it to a machine shop and have them bore it where it needs to be bored.  No sense in going more sizes up than you need to, as there is no benefit from doing so, and it will mean in the future that you won't be able to bore that cylinder again and will have to buy a new one.
I know "It's bored .40 over" sounds cool, but on a single cylinder Honda 350 motor, you're gaining nothing power wise.
**** I put a 475CC top end on my wife's 420 Rancher and the difference wasn't all that great.
Honda motors are built to be reliable, not hot rodded.
On the seals, you need front and rear output, shifter seal, reverse seal, crank seal, and the seals behind the shift motor.  That's it.  Most are about $2-3 each.  Replace them all.  Easy to do with the motor out, PITA to do with it in the frame.
4x4 big COON
Re: Rancher 350 project 2017/04/19 22:30:37 (permalink)
Hey guys the only cam I can even find for a 350 is a web cam
2004 red Honda rancher 350 4x4 es
30x9-14 gorilla silverbacks on chrome msa ss wheels
Snorkeled
Waterproofed
3/4"X11"X11 5/8" oil cooler and 10" electric fan relocated on rack
24" led lightbar-$30
Rear brake drum delete
3" custom lift kit
2" wheel spacers for back
Sixity cv axles
Epi competition stall clutch kit
Dynojet kit
K&N air filter
New carburetor
Hmf performance pipe
2012 rancher 420 es
25" maxxis tires on 12" wheels
Strong made Front and rear baskets
4x4 big COON
Re: Rancher 350 project 2017/04/19 22:33:07 (permalink)
Thanks for all that info I can get a complete engine gaskets and seals kit for $35
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
4x4 big COON
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
4x4 big COON
Rancher 350 project 2017/04/22 12:57:05 (permalink)
https://www.ebay.com/itm/331374255422
Sent from my iPhone using Tapatalk
Re: Rancher 350 project 2017/04/22 13:17:44 (permalink)
134 available!!! Almost gone!!! Hahaha China!!!!
4x4 big COON
Rancher 350 project 2017/04/22 14:01:16 (permalink)
Do you think it's any good nutt?
4x4 big COON
Rancher 350 project 2017/04/22 14:02:22 (permalink)
Bc I have a broke off cooling fin
Re: Rancher 350 project 2017/04/22 14:11:16 (permalink)
A broke fin doesn't matter. I read the three reviews. One 5, 4 and 1. So I'd say your taking your chances.
doveman1
Re: Rancher 350 project 2017/04/22 19:22:35 (permalink)
71% off??? Heck of a deal! I'd be scared to open that box, probably just full of old hot wheels pieces...
Anyway have you even took the top end off to see what condition everything is in?
Green 2015 Grizzly 700
2in HL lift
N2deep battery relocation
Wild boar radiator relocation
4x4 big COON
Rancher 350 project 2017/04/22 19:25:24 (permalink)
Yes I have the cylinder sleeve is in perfect shape rings are done. Worn terribly. Bunch of blow by on top of piston and valve faces. Motor looks really really clean inside surprisingly
4x4 big COON
Rancher 350 project 2017/04/23 01:47:12 (permalink)
Guys my intake valve looks perfect but the outer face of my exhaust valve is worn badat the edges like the metal is are away. Should I throw newvalves in it ?
umbromel
Re: Rancher 350 project 2017/04/23 16:03:28 (permalink)
i do not really know
____________________
post edited by umbromel - 2017/04/24 10:11:56
Re: Rancher 350 project 2017/04/23 16:47:33 (permalink)
Come on umbro shorts!!!! Put new valves in!!! They cheap!!!! Seat the valves yourself and go on!!!!!!
4x4 big COON
Rancher 350 project 2017/04/23 23:44:20 (permalink)
Ok so I need cam info. I can't find but one can for a 350 and it's not cheap. Is it worth it. Will it make a noticeable power difference or not.
Re: Rancher 350 project 2017/04/24 00:00:39 (permalink)
BUY GEAR REDUCTION!!!!!!! WE CANT SAY IT ENOUGH. IF YOU UP GRADE CAM YOU HAVE TO GET THE ROCKER ARMS HARD WELDED ALSO!!!!!!
4x4 big COON
Rancher 350 project 2017/04/24 06:40:13 (permalink)
Ok I'll just get a gr instead of both but y'all were the ones telling me to put a cam in if I had the money lol
Re: Rancher 350 project 2017/04/24 06:49:46 (permalink)
Not me homie!!!! I been GR from the beginning!!!!
doveman1
Re: Rancher 350 project 2017/04/24 07:42:34 (permalink)
I said cam because the way you've been talking you're about to build a budget power house of a Honda!
But from the beginning it has always been GR. That is going to be the only thing that will make you happy with those tires in the mud.
2in HL lift
4x4 big COON
Rancher 350 project 2017/04/24 09:02:32 (permalink)
Ok guys good deal thanks
4x4 big COON
Rancher 350 project 2017/04/24 11:16:57 (permalink)
Everything is otw I ordered namura rings. Honda valves. Honda timing chain. Namura complete motor gaskets and seals kit.
Re: Rancher 350 project 2017/04/24 11:23:56 (permalink)
Woohoo!!!!
fonforet
Re: Rancher 350 project 2017/04/27 04:05:07 (permalink)
What has just happen?
Re: Rancher 350 project 2017/04/27 06:45:17 (permalink)
You made a post⬆️⬆️⬆️⬆️⬆️!!!! Now your a big boy!!!
doveman1
Re: Rancher 350 project 2017/04/27 10:42:04 (permalink)
You'll be a man in no time!
2in HL lift
Re: Rancher 350 project 2017/04/27 10:58:29 (permalink)
We gonna have to get him some big girl undies!!!!
doveman1
Re: Rancher 350 project 2017/04/27 11:48:52 (permalink)
To walmart!!!
2in HL lift
Re: Rancher 350 project 2017/04/27 13:12:40 (permalink)
Good will!!!!
4x4 big COON
Rancher 350 project 2017/04/28 00:06:05 (permalink)
All parts have came in except for timing chain so looks like tm night the motor will be getting finished and going back in the bike (hopefully no longer smoking like a freight train) lol
doveman1
Re: Rancher 350 project 2017/04/28 06:29:51 (permalink)
Did you hone the cylinder?
2in HL lift
