Hot!Rancher 350 project
Page: < 12345.. > >> Showing page 5 of 18
4x4 big COON
Re: Rancher 350 project 2017/04/09 21:10:10 (permalink)
? Also I found a .060 over piston kit for my bike
2004 red Honda rancher 350 4x4 es
30x9-14 gorilla silverbacks on chrome msa ss wheels
Snorkeled
Waterproofed
3/4"X11"X11 5/8" oil cooler and 10" electric fan relocated on rack
24" led lightbar-$30
Rear brake drum delete
3" custom lift kit
2" wheel spacers for back
Sixity cv axles
Epi competition stall clutch kit
Dynojet kit
K&N air filter
New carburetor
Hmf performance pipe
2012 rancher 420 es
25" maxxis tires on 12" wheels
Strong made Front and rear baskets
Re: Rancher 350 project 2017/04/09 21:33:36 (permalink)
Idk man. I'd be afraid the cylinder sleeve would be thin and that causing the engine to have more heat and maybe crack the sleeve when hitting some cold water.
4x4 big COON
Re: Rancher 350 project 2017/04/10 10:46:26 (permalink)
Ok I understand
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
4x4 big COON
Re: Rancher 350 project 2017/04/13 18:25:10 (permalink)
Guys here's my options I can redo a complete stock to pend rebuild kit for $125 and install it myself since there will be no boring or honing or my other option is I could buy the highlifter 375 bbk for $185 and have it installed by my local mechanic for $150. What y'all think I should do?
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Re: Rancher 350 project 2017/04/13 19:07:11 (permalink)
I say it all depends on your pocket book.
4x4 big COON
Re: Rancher 350 project 2017/04/13 23:19:27 (permalink)
Ok well I need some help. The highlifter bbk comes with a new sleeve so what I'm asking is do I still have to bore my cylinder for the new sleeve or does it slide into the stock cylinder to replace the stock sleeve. If it does not have to be bored over I will go ahead and get the bbk and install it myself
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
doveman1
Re: Rancher 350 project 2017/04/14 06:38:12 (permalink)
That's just a general picture, does not come with sleeve has to be bored. I would not go 375 bbk, you will be asking for trouble.
You can get everything from Namura for less than $100 to do .20 over
Green 2015 Grizzly 700
2in HL lift
N2deep battery relocation
Wild boar radiator relocation
Re: Rancher 350 project 2017/04/14 08:20:01 (permalink)
I with Doveman!!! I run namura pistons and have never had a problem. LA Sleeve has some good stuff too but is a little more expensive but if you look you can find the deals.
4x4 big COON
Re: Rancher 350 project 2017/04/14 16:23:32 (permalink)
I can get a namura set for only 60$ or a complete new top end for 125$
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Re: Rancher 350 project 2017/04/14 17:01:59 (permalink)
Also look at a wiseco kit. That's what highlifter is selling anyway.
4x4 big COON
Re: Rancher 350 project 2017/04/15 01:28:58 (permalink)
Highlifter says it's a je piston
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Re: Rancher 350 project 2017/04/15 08:26:26 (permalink)
They changed then. Well then check wiseco highlifter once used them. I like wiseco stuff.
doveman1
Re: Rancher 350 project 2017/04/15 08:38:02 (permalink)
They been using Je for years NUTT!! Stick with the times man!!
2in HL lift
Re: Rancher 350 project 2017/04/15 08:45:30 (permalink)
Heck that should tell you how soon I found a cheaper way to find parts!!!!! Hahaha
4x4 big COON
Re: Rancher 350 project 2017/04/15 14:54:00 (permalink)
How many cc's is a .020 .040 .060 equivalent to?
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Re: Rancher 350 project 2017/04/15 15:33:24 (permalink)
78.50mm STDmm
329cc
79.00mm .50mm
333cc
79.50mm 1.00mm
338cc
This is off wiseco website so you can basically see where you end up. I still say for what you are fixing to spend to just get the GR and be done. I don't see huge gains in boring your bike. Keep it stock with a GR will make a very reliable motor.
4x4 big COON
Re: Rancher 350 project 2017/04/15 15:43:53 (permalink)
The top end has to be redone it's smokes like a train. So I can get 79mm wiseco for $105 or 79.96 or 80 mm namura for $60
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Re: Rancher 350 project 2017/04/15 15:58:14 (permalink)
I hear you but you need to pull the jug and look at the cylinder. If it's not bad just run a crazy 8 or hone through it and some new valve seals and be done.
4x4 big COON
Re: Rancher 350 project 2017/04/15 16:30:15 (permalink)
And just get new stock rings?
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Re: Rancher 350 project 2017/04/15 19:06:48 (permalink)
Yup
4x4 big COON
Re: Rancher 350 project 2017/04/18 02:17:31 (permalink)
Well guys I just got done pulling my motor well almost only thing I have left is the little reverse brake type cable that goes to the back of the motor. Tm I will take the top end apart and see what I'm dealing with
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Re: Rancher 350 project 2017/04/18 06:36:41 (permalink)
You know you can leave the motor in the bike to do the top end?
4x4 big COON
Re: Rancher 350 project 2017/04/18 09:49:56 (permalink)
Well I feel stupid
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Jeepwm69
Re: Rancher 350 project 2017/04/18 10:42:30 (permalink)
No, don't feel stupid.  350 motors are easy to pull, and you can do some other work while you have it out.
I would tear the whole motor down and clean the cases out.
New timing chain
New shifters seal, reverse seal, crank seal (under the pullstart) and front and rear output seals.
All that stuff is CHEAP, and if you put a new top end on a motor that has grit in the bottom it will go right back to smoking.
Tear it down, clean it out, and put new timing chain and seals in it.  Then do your top end and you KNOW what you have.
Anyone used those aftermarket 350 top ends?  I've got an extra 350 motor in the shop and I can buy a new Chinese top end cheaper than I can have my old cylinder bored.
http://www.ebay.com/itm/282200376854?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Jeepwm69
Re: Rancher 350 project 2017/04/18 11:01:58 (permalink)
Just reread the whole thread.
Yeah, if you got water in your motor, I'd split cases, clean it all out.  You can take that clutch kit back off on the bench (much easier).
Of course, that would be the time to do the gear reduction as well....
New seals, new timing chain, new top end, or at least hone yours with new rings.
That won't cost you much if you're doing the work, and then you know your motor is good and you won't have to worry about water seeping in through a seal, or grit from your bottom end ruining a new top end.
These 350's actually seem to be kind of a bargain these days.  Better rear end design than the 420's, and the 350 motors seem to last forever.  They do seem to have a lot of carb issues, but other than that I like them.
420 brakes will bolt right on at the ball joints if you want to covert to disc brakes.
I want to try a 400AT front end in one to make it selectable 4wd.
I just rebuilt one for my neighbor.  Did the engine work I suggested, put 420 brakes on the front.  He didn't want to spend money on the 400AT front end experiment I wanted to try, but I bet it would be easy to swap in.
I converted his to footshift too.  Just replaced that hex "emergency shifter" spindle with a splined spindle from a footshift 350, bolted a shifter on, and pulled the gears out from under the shift motor on the front cover.  Works fine, and no more electrical crap to mess up.  He wanted his left hand free to hold his beer.
Re: Rancher 350 project 2017/04/18 13:38:20 (permalink)
Sweet write up Jeepwm. I'm gonna keep all that info in my memory storage!!!!
4x4 big COON
Re: Rancher 350 project 2017/04/18 15:46:54 (permalink)
Thanks for that info man I'm wanting to do a .060 namura piston it's $60 and $40 for bore and hone at my local machine shop. I will try to replace timing chain and as many seals as possible why it's out
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
4x4 big COON
Re: Rancher 350 project 2017/04/18 18:42:55 (permalink)
What y'all think
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
doveman1
Re: Rancher 350 project 2017/04/18 19:15:47 (permalink)
Honestly I believe you are wasting time boring that big. If the cylinder walls and piston look good I'd clean the engine real good and slap a set of rings on it for $30. Take the jug to a shop and get it honed for a few dollars. If you do .60 start looking for a new jug. There isn't enough gains in these little motors. If you are going all the way down find you a cam to slap in it and a GR and be done.
2in HL lift
Re: Rancher 350 project 2017/04/18 19:30:11 (permalink)
AGREED ⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️⬆️
