Hot!Rancher 350 project
Page: << < ..161718 Showing page 18 of 18
4x4 big COON
Re: Rancher 350 project 2019/08/10 20:04:23 (permalink)
I know I always look at interco blem list but I really want to run the bkts or motohavok 2 of my favorite tires out there. I could always throw my 33 bkt off the 350 on it and see how it does. Would love to run 35s on the ol 300 but scared it will be too much. Also been wanting to try out a set of the 34.5 ol2s but they heavy heavy
2004 red Honda rancher 350 4x4 es
30x9-14 gorilla silverbacks on chrome msa ss wheels
Snorkeled
Waterproofed
3/4"X11"X11 5/8" oil cooler and 10" electric fan relocated on rack
24" led lightbar-$30
Rear brake drum delete
3" custom lift kit
2" wheel spacers for back
Sixity cv axles
Epi competition stall clutch kit
Dynojet kit
K&N air filter
New carburetor
Hmf performance pipe
2012 rancher 420 es
25" maxxis tires on 12" wheels
Strong made Front and rear baskets
Re: Rancher 350 project 2019/08/10 20:35:32 (permalink)
Man Chris Clark has some secret GR he's made. Said it can turn just about anything you want. But yes you would either have to have good thumb control or beef up a few parts!!!
4x4 big COON
Re: Rancher 350 project 2019/08/11 02:50:02 (permalink)
O boy sounds like a blast. I already have trouble with my 350. The cobras don’t give any trouble at all but I’ve alrea ruined a couple diffs and the worst thing is my rear driveshaft. Every other ride it either shears in half or strips the splines. Probably gonna let turner make me one and see how that holds up. Also just got done doing a complete rear end rebuild on my 300. New wheel bearings and swingarm bearings. Brake drum delete. And did a complete differential rebuild. New bearings and seals new ring and pinion new nuts vent and o rings and washer everything but the casing lol it’s nice and tight also drilled and tapped the center axle housing and put a grease fitting in there to keep that packed with grease.
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Re: Rancher 350 project 2019/08/11 16:03:31 (permalink)
Man look for the 350D rear axle for the 300. They are bullet proof. Sleeved from hub to hub. Also I'll do some checking on a guy by baton rouge that made mine. He cuts the factory shaft and presses them into drag truck shafts. So an 1"1/2 solid steel he drills into. Tig welds it all up then heat treats it for like 12 hours. My drive shaft is a beast.
4x4 big COON
Re: Rancher 350 project 2019/08/11 19:57:15 (permalink)
I know about the 350d we’ve done a couple of my buddies at my shop but I can’t ever find them anymore and if I do the ppl always want like $350 lol. And yes I need him to make me one. How much did he charge you?
post edited by 4x4hondas - 2019/08/12 19:16:40
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Re: Rancher 350 project 2019/08/11 22:21:51 (permalink)
Man I think it was like $125. If I see a 350d I'll try to get it on the cheap for you.
4x4 big COON
Re: Rancher 350 project 2019/08/12 06:19:29 (permalink)
Sweet I would definitely pay that if he’s willing
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
4x4 big COON
Re: Rancher 350 project 2019/08/12 06:20:42 (permalink)
And yes my buddy is looking for a 350d for his 300 rn too so if you come across any holler at me please
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
4x4 big COON
Re: Rancher 350 project 2019/08/13 21:55:30 (permalink)
So my 300 is done and I love it it runs great plastics and tank are in great shape and it’s got a brand new Honda seat but..... it’s 2wd. I have a 4wd frame with front diff. Con. arms knuckles etc. and engine with trans. Case and driveshaft. One problem 4wd parts bike is 91 and my bike is 99 so the upper part of frame is different meaning I can’t use my tank and seat right? I’m wondering how hard it would be to just weld in the diff mounts. That’s the only thing I see I’m missing to bolt everything up. Everything else seems to be the same. Or could I cut and swap out the upper front frame section and weld in. Idk
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Re: Rancher 350 project 2019/08/13 22:02:45 (permalink)
Oh that's the bike frame that the intake is the frame. I believe the seat may fit. It just hooks under that plate. The tank I have to check but I thought there was something about some bushings. I have an 88 frame so I'll do some checking and see. Give me a couple days.
4x4 big COON
Re: Rancher 350 project 2019/08/14 03:23:54 (permalink)
Ok bro sounds good. The seats look the same but they have a 88-92 seat and a 93-up seat so I figured it wouldn’t. My seat is brand spanking new. Love having a 300 again tho this thing is beast. I put a 300ex carb and cable and int. Man. Boot on it and some 5” flush mount led pods fro replace the old heads
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Re: Rancher 350 project 2019/08/14 10:17:39 (permalink)
Man sounds good. Hey check your PM's and hit this guy up for the driveshaft.
4x4 big COON
Re: Rancher 350 project 2019/08/15 22:09:08 (permalink)
I did thanks so much
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
4x4 big COON
Re: Rancher 350 project 2019/08/16 15:57:53 (permalink)
Hey nutt you had a chance to look at your 300s yet for me
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Re: Rancher 350 project 2019/08/17 18:05:46 (permalink)
Man my apologies. I got busy with some different things and forgot. I'm gonna go look tomorrow.
4x4 big COON
Re: Rancher 350 project 2019/08/18 01:29:21 (permalink)
No rush my friend was just curious
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
4x4 big COON
Re: Rancher 350 project 2019/08/18 01:36:13 (permalink)
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Re: Rancher 350 project 2019/08/18 09:00:21 (permalink)
Man looks good!!!
4x4 big COON
Re: Rancher 350 project 2019/08/18 20:45:41 (permalink)
Thanks. Since when did they start making an 88% gr for a 300. Wonder what size tire I could turn with that
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Re: Rancher 350 project 2019/08/18 21:05:33 (permalink)
Man still haven't checked the tank. We been getting flooded on all day. Man that Chris Clark been experimenting and I talked to Whitney and he said he seen it too. It hasn't been made for long but it's out there. Dude I think the limiting factor would be drive train but with good thumb control for sure some 36's no problem.
4x4 big COON
Re: Rancher 350 project 2019/08/19 01:08:06 (permalink)
What would I have to do to run a set of 44x9.5-24 outlaw 3s on a Honda lol.
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
4x4 big COON
Re: Rancher 350 project 2019/08/19 01:16:41 (permalink)
Can’t decide if I want to build the little 300 or the 14 footshift irs eps rancher 500. Another question footshift rancher 500 with 69% gr what size tires could I run. And is there any bigger gr than the 69% for that bike
post edited by 4x4hondas - 2019/08/19 01:19:45
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Re: Rancher 350 project 2019/08/19 14:43:36 (permalink)
Man probably like a 33" to 35" BKT and also depending on mud type. The rancher has a different style tranny to the 300. Me personally I love my 300's but keep thinking about selling them and getting an irs bike. Not cause it can get more place but for comfort. Man I have to do some checking if there's bigger reductions.
4x4 big COON
Re: Rancher 350 project 2019/08/20 03:05:26 (permalink)
My little 350 rancher only has 39% GR and it pulls the 33 bkt pretty good. My 14 rancher with 500 top end and 69% should be a good be stronger I figured. Was hoping to run like a 37 on it lol but 35s would do me
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
