Hot!Rancher 350 project
Page: << < ..1112131415.. > >> Showing page 15 of 18
4x4 big COON
Re: Rancher 350 project 2018/09/25 11:51:03 (permalink)
They said drc6 fits I got them on the way. Also bought a new jug and wiseco piston Still trying to figure out my acle situation lol
2004 red Honda rancher 350 4x4 es
30x9-14 gorilla silverbacks on chrome msa ss wheels
Snorkeled
Waterproofed
3/4"X11"X11 5/8" oil cooler and 10" electric fan relocated on rack
24" led lightbar-$30
Rear brake drum delete
3" custom lift kit
2" wheel spacers for back
Sixity cv axles
Epi competition stall clutch kit
Dynojet kit
K&N air filter
New carburetor
Hmf performance pipe
2012 rancher 420 es
25" maxxis tires on 12" wheels
Strong made Front and rear baskets
Re: Rancher 350 project 2018/09/25 11:55:41 (permalink)
Hey I need a few part too if you buying, hahahaha.
4x4 big COON
Re: Rancher 350 project 2018/09/27 23:48:29 (permalink)
Lol I got my jug piston and clutch kit I m bouta go ahead and grab brake lines and 400 diff next along with my custom spacers and more plastic pieces. What you need nutt I got you bro. Jk I’m broke. O yea what seals the rear crankcase at the plate that grabs the pool cord assembly?
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Re: Rancher 350 project 2018/09/28 12:08:06 (permalink)
Hahahaha. Are you talking about the pull cord cover itself?
4x4 big COON
Re: Rancher 350 project 2018/09/30 00:49:28 (permalink)
No lol but I got it covered my seal in there had a chunk out of it but luckily my buddy has a 350 parts bike and it’s was good so I swapped it on there. My friction plates are installed and my new jug and wiseco piston are installed and hopefully my serious leak is fixed.
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Re: Rancher 350 project 2018/09/30 08:37:50 (permalink)
Dude you making some serious progress!!! When you think it's gonna be rolling?
4x4 big COON
Re: Rancher 350 project 2018/10/01 11:34:56 (permalink)
It’s been done for a couple of days ride it yesterday a lot it feels way more powerful I also ordered a 400 at diff and driveshaft bothe with wiring for $100 now I have a question will an 07 500 throttle and 4wd select switch work? The connector looks the same
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Jeepwm69
Re: Rancher 350 project 2018/10/01 13:05:29 (permalink)
4x4hondas
Yes.  The swtich will work fine, but you're not using the connector.
You have to splice wires to get it to work.
12V goes into handlebar switch (I tapped into pink wire on ignition switch), and then you hook the other wire coming off the handlebar switch to the orange and white wire going to the diff actuator (green plug on the front diff).  Ground the other wire on that harness coming off of the green plug.   That's it.
You can cut the wires off the speed sensors on the diff or tie them up out of the way.  Sensors have to stay in place to keep diff sealed up.
If you want a 4wd indicator light I drilled a hole in the gauge bezel right above and to the left of the key switch, used a 300 dash bulb and socket, and ordered a new lens from an 07 420 Footshift (that shows 4wd locked in) and use it.  Wired it into the same power lead going to the diff actuator so it comes on when the wheeler is in 4wd.
Just make sure you don't hit the switch while your rear wheels are spinning faster than your front wheels (for example, if you're stuck in 2wd, don't hit the switch while on the throttle).
The factory front selectable diffs use the computer to keep the 4wd from engaging until the front and rear speed sensors read the same speed.  Your 350 Rancher ECU has no such programming, so you're hardwiring that actuator, so if you hit the switch, it will lock in right then.  That means if you're WOT with rear wheels spinning a 30 MPH while your front tires are not turning, and you hit that switch, some spectacular transmission carnage will occur.
4x4 big COON
Re: Rancher 350 project 2018/10/01 15:00:23 (permalink)
Awesome man thanks for that info gonna get that switch otw and everything says it will be here by Friday so I’ll try to have it done to test out in my buddy’s pond sat
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Jeepwm69
Re: Rancher 350 project 2018/10/01 15:30:52 (permalink)
Just remember you have to slightly notch out the frame crossmember where that longer actuator sticks off the back of the diff.  You'll be able to see where I'm talking about.  Don't have to notch it much for the diff to drop right in place, and it doesn't hurt anything at all when you do it.
Other than that it's bolt in, hook to switch and 12V, and run it.
4x4 big COON
Re: Rancher 350 project 2018/10/01 18:39:43 (permalink)
Yea I think I got it covered appreciate the help
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Re: Rancher 350 project 2018/10/01 20:30:27 (permalink)
Man I help as much as I can.
4x4 big COON
Re: Rancher 350 project 2018/10/02 08:59:11 (permalink)
Thinking about irs The 680 rib con rear diff is the only one that will work huh?
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Re: Rancher 350 project 2018/10/02 09:23:08 (permalink)
Man I believe 650 and 680 honda and the artic cat 250 or 300 (the one with irs)
toms99tj
Mud Slinger
Re: Rancher 350 project 2018/10/02 10:07:24 (permalink)
I did the IRS on Foreman 450 and it was the best thing I ever did.
Attached Image(s)
1998 Foreman 450
30 inch Zillas on MSA M12
2 inch Highlifter Lift
Highlifter springs
Highlifter disc brakes
14% Gear Reduction
Snorkle
Stereo
__________________________
2000 Foreman 400
30" Zillas on 14" MSA Elixers
Viper 3000lb winch
DG muffler
Highlifter Disc Brakes
14% Gear Reduction
450 rear shocks with spacer lift
Foreman 400 rear adjustable shocks and 450 a arms
Warn 424
Home made snorkel
6" Audio Tube
ES Floorboards
Re: Rancher 350 project 2018/10/02 10:11:42 (permalink)
Rides like a dream huh? Man it looks really good!!!
Re: Rancher 350 project 2018/10/02 10:12:44 (permalink)
Also I don't think you have to flip the artic cat diff either.
toms99tj
Mud Slinger
Re: Rancher 350 project 2018/10/02 10:15:38 (permalink)
It rides so much better than the solid axle. Doesnt shake up all the beer in your stomach when riding either. Lol.
1998 Foreman 450
Highlifter springs
14% Gear Reduction
Snorkle
Stereo
2000 Foreman 400
Viper 3000lb winch
DG muffler
14% Gear Reduction
Warn 424
Home made snorkel
6" Audio Tube
ES Floorboards
Re: Rancher 350 project 2018/10/02 10:45:49 (permalink)
Good one Tom hahahaha
toms99tj
Mud Slinger
Re: Rancher 350 project 2018/10/02 12:22:52 (permalink)
The only thing i need to do is put the swaybar on. Its a little scary without it. Lol
1998 Foreman 450
Highlifter springs
14% Gear Reduction
Snorkle
Stereo
2000 Foreman 400
Viper 3000lb winch
DG muffler
14% Gear Reduction
Warn 424
Home made snorkel
6" Audio Tube
ES Floorboards
Re: Rancher 350 project 2018/10/02 12:24:29 (permalink)
Like the sissy bar on a Harley!!!!
toms99tj
Mud Slinger
Re: Rancher 350 project 2018/10/02 12:30:10 (permalink)
**** i need one of those too. It will go perfect with the harley muffler thats on it. Lol
1998 Foreman 450
Highlifter springs
14% Gear Reduction
Snorkle
Stereo
2000 Foreman 400
Viper 3000lb winch
DG muffler
14% Gear Reduction
Warn 424
Home made snorkel
6" Audio Tube
ES Floorboards
Re: Rancher 350 project 2018/10/02 12:45:49 (permalink)
Hahahahahahahahaha
toms99tj
Mud Slinger
Re: Rancher 350 project 2018/10/02 12:47:08 (permalink)
I also need to get a spot to hook up my polaris/can am tow strap.
1998 Foreman 450
Highlifter springs
14% Gear Reduction
Snorkle
Stereo
2000 Foreman 400
Viper 3000lb winch
DG muffler
14% Gear Reduction
Warn 424
Home made snorkel
6" Audio Tube
ES Floorboards
Re: Rancher 350 project 2018/10/02 14:08:08 (permalink)
With all the money they spend on the popo and canned hams they probably can put you one of those tiger tails on. For a quick pull and even quicker get away!!!
toms99tj
Mud Slinger
Re: Rancher 350 project 2018/10/02 14:36:35 (permalink)
Those things are pretty cool
1998 Foreman 450
Highlifter springs
14% Gear Reduction
Snorkle
Stereo
2000 Foreman 400
Viper 3000lb winch
DG muffler
14% Gear Reduction
Warn 424
Home made snorkel
6" Audio Tube
ES Floorboards
Re: Rancher 350 project 2018/10/02 14:39:50 (permalink)
I agree I just need someone to buy me one hehehehe
toms99tj
Mud Slinger
Re: Rancher 350 project 2018/10/02 17:56:29 (permalink)
You would think a canned ham owner would so you can help them out of the hole quicker
1998 Foreman 450
Highlifter springs
14% Gear Reduction
Snorkle
Stereo
2000 Foreman 400
Viper 3000lb winch
DG muffler
14% Gear Reduction
Warn 424
Home made snorkel
6" Audio Tube
ES Floorboards
4x4 big COON
Re: Rancher 350 project 2018/10/02 23:36:21 (permalink)
That is a solid job well done Tom
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
toms99tj
Mud Slinger
Re: Rancher 350 project 2018/10/03 06:35:31 (permalink)
Thank you. I think the irs would finish the rancher nicely and you wouldnt need the wheel spacers. Just have to make the a arms and axles like you did for the front.
post edited by toms99tj - 2018/10/03 08:04:44
1998 Foreman 450
Highlifter springs
14% Gear Reduction
Snorkle
Stereo
2000 Foreman 400
Viper 3000lb winch
DG muffler
14% Gear Reduction
Warn 424
Home made snorkel
6" Audio Tube
ES Floorboards
