Hot!Rancher 350 project
Page: << < ..1112131415.. > >> Showing page 11 of 17
Jeepwm69
Re: Rancher 350 project 2018/06/04 14:29:51 (permalink)
Ok ball joints are different between the two so it's a kinda sorta they will swap. A little tack in the hole and a little grinding they will. 420 ball joints are a hair bigger so the 350 ones will be a hair loose. Custom made brake lines is what I did. Companies online that make them pretty cheap in whatever coclor u want.
Negative.
420 brakes and knuckles are a direct fit on a 350 rancher.  Upper and lower ball joints are the same so you just swap everything out at the ball joints.
You will have to trim the factory plastic a-arm guard on the 350 to clear the caliper, but otherwise it's plug and play.
300's have the smaller upper ball joint so you have to grind out the upper A-arm ball joint hole to accept the upper 420 ball joint if swapping 420 discs onto a 300.
I've put 420 discs on a 300 (lots of grinding) and four 350 Ranchers (bolt right up).
4x4 big COON
Re: Rancher 350 project 2018/06/04 22:04:42 (permalink)
I think nutt was saying the 420 knuckles will work on the 350 but the 350 knuckles won’t work on a 420
2004 red Honda rancher 350 4x4 es
30x9-14 gorilla silverbacks on chrome msa ss wheels
Snorkeled
Waterproofed
3/4"X11"X11 5/8" oil cooler and 10" electric fan relocated on rack
24" led lightbar-$30
Rear brake drum delete
3" custom lift kit
2" wheel spacers for back
Sixity cv axles
Epi competition stall clutch kit
Dynojet kit
K&N air filter
New carburetor
Hmf performance pipe
2012 rancher 420 es
25" maxxis tires on 12" wheels
Strong made Front and rear baskets
4x4 big COON
Re: Rancher 350 project 2018/06/05 02:36:48 (permalink)
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
4x4 big COON
Re: Rancher 350 project 2018/06/05 02:38:07 (permalink)
Made me a chart of everything bigger than 30s that fits a 14” wheel
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Jeepwm69
Re: Rancher 350 project 2018/06/05 13:20:35 (permalink)
4x4hondas
Upper and lower ball joints are the same.  No reason it wouldn't go either way.
4x4 big COON
Re: Rancher 350 project 2018/06/05 14:09:51 (permalink)
Ok I did look up new ball joints for my bike and they say they fit the 350 and 420
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
4x4 big COON
Re: Rancher 350 project 2018/06/05 23:32:04 (permalink)
I got new ball joints on the way and all my heim joints Shafts are being done by my machinist. Wish I had some measurements for ball joint plates. Also my dad said I could swap our knuckles but just came to my mind his is a 2wd so ig that’s out for now lol.
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
4x4 big COON
Re: Rancher 350 project 2018/06/06 19:17:08 (permalink)
Heim joints came in now waiting on ball joints
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Re: Rancher 350 project 2018/06/07 06:54:16 (permalink)
If you have a machinist doing your work then just bring him your knuckle, ball joints and pipe. Let him take measurements and I'm sure if he's got all the tools he could cut you some ball joint plates in no time. There is a place in Lafayette that cuts plates but I can't remember the name. Let me see if I can find their name.
Re: Rancher 350 project 2018/06/07 08:48:19 (permalink)
Hey found the brake line place I used. It's cyclebrakes.com
4x4 big COON
Re: Rancher 350 project 2018/06/07 18:17:10 (permalink)
Golden bro appreciate that. Yea I talked to him about it. I think I have a problem btw
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Re: Rancher 350 project 2018/06/07 18:42:51 (permalink)
What's up?
4x4 big COON
Re: Rancher 350 project 2018/06/07 22:58:24 (permalink)
O yea when I pulled the swing arm bolts the bearings were shot and fell to pieces was wondering what brand to go with. Thinking all balls Bc that’s the kind of ball joints I bought and I’ve always got all my ball joints and wheel bearing from them for my bikes. But also they have boss bearing for the same price and chicken strips cycles for the same price which ones to go with?
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Re: Rancher 350 project 2018/06/07 23:31:12 (permalink)
Man it's a toss up. I have used all balls and never had an issue.
4x4 big COON
Re: Rancher 350 project 2018/06/08 00:13:38 (permalink)
I’ll stick with them then
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Jeepwm69
Re: Rancher 350 project 2018/06/08 10:57:56 (permalink)
I've gotten All Balls that were out of spec.
Boss has been good to go for me.  There is speculation that Boss and All Balls are the same company.
Whatever you end up using, pack them completely with good grease before install and they'll last a lot longer.
4x4 big COON
Re: Rancher 350 project 2018/06/08 12:59:24 (permalink)
Went with all balls again and got my ball joints and all 12 heims only thing I’m missing is a piece of 3” id pipe for the swing arm stretch
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
4x4 big COON
Re: Rancher 350 project 2018/06/09 13:55:50 (permalink)
Nutt just got off the phone with those cycle brakes guys they said $110 for the lines
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Re: Rancher 350 project 2018/06/09 14:41:54 (permalink)
Dang they went up!!! Last set I bought was like $45.
4x4 big COON
Re: Rancher 350 project 2018/06/09 22:43:04 (permalink)
Yea lol I’m gonna check with my local hydraulic line shop and see how much they will make em for
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
4x4 big COON
Re: Rancher 350 project 2018/06/09 23:03:36 (permalink)
Nutt grab me a set of 32.5 mamba blems and I’ll come get them from you
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Re: Rancher 350 project 2018/06/09 23:06:19 (permalink)
Let me check around and see what I can find!
4x4 big COON
Re: Rancher 350 project 2018/06/09 23:35:16 (permalink)
They got 3 sets on the blem list $628 a set will the 350 be able to turn those with the 39% gr
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Re: Rancher 350 project 2018/06/09 23:57:25 (permalink)
Man I'm not sure. That's a lot of meat.
4x4 big COON
Re: Rancher 350 project 2018/06/10 06:27:18 (permalink)
Yea I know lol I could 33” silverback mt2 and be lighter still. Thinking of trying the outback max or mudder inlaw in a 32”
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
4x4 big COON
Re: Rancher 350 project 2018/06/14 18:01:30 (permalink)
I’ve narrowed down to 2 tires to choose between 32” outback max or 32.5” outlaw 2. I ride a lot of mud but also a lot of trail. I love the outlaw and have always wanted a set but I think the outback max would be a way smoother tire for trails and hard pack plus they are 8 ply so more puncture resistance than the outlaws and they are 2 pounds a tire lighter. So what y’all think?
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
4x4 big COON
Re: Rancher 350 project 2018/06/17 09:34:22 (permalink)
Will that 02-03 rubicon 500 rear end fit my 350?
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Re: Rancher 350 project 2018/06/17 10:11:07 (permalink)
Man you would have to research the gear ratio between the two and also make sure it turns the proper direction.
4x4 big COON
Re: Rancher 350 project 2018/06/17 11:20:35 (permalink)
The reason I want it on my 350 is its 3” wider than the 350 rear end so gets a little closer with my spacers to the front width after the lift. O yea got my axles back too I’ll get some pics
Snorkeled
Waterproofed
3" custom lift kit
Sixity cv axles
Dynojet kit
K&N air filter
New carburetor
2012 rancher 420 es
Re: Rancher 350 project 2018/06/17 11:39:19 (permalink)
Man just have your guy turn you out some spacers for the back. Plenty of people do it just use some thick flat iron and some square tubing.
