LockedProblems with 09 grizzly 700
D Boy
2009/08/18 12:07:12 (permalink)
I have a new 09 700 grizzly with only 24 hrs and around 250 miles. Recently the bike is very hard to keep idoling, it always dies on me at idol or when going very slow and sometimes just die out when I floor it. Now if I can get it going and ride hard and fast it will stay running but start back firing when I slow down. Generally after ridding it for about an hour fighting with it, then everything goes away and it runs fine. I'm guessing something is wrong with the injectors. I have checked the plug, changed the gas, ran higher octane gas, cleaned the filter, and just recently replaced the filter with a k&n. If anything seems like its getting worse. Just looking for some quick advice before I bring it back to the shop. I'm sure it will sit in there shop awhile before they can even look at it.
Thanks again in advance.
09 Grizzly 700 (Special Edition)
14" S212
27" Mudlites
K&N
warn xt25
9 Replies Related Threads
    drew7693
    Re:Problems with 09 grizzly 700 2009/08/18 13:35:26 (permalink)
    i had the same problem with my 08, at about the same mileage and hour marks as you. I eneded up buying the dynatek ignition. it got rid of alot of this problem, it still happens on occasion, i think i'm gonna try and buy the coil and see if that helps even more.
    2008 yamaha Grizzly 700
    30x10x12 Silverbacks
    SS 108's
    2.5 warn XT
    DynaFS ignition
    Custom Radio "TUNES"
    HMF Utility
    HMF Optimizer
    K&N air filter
    Highlifter Lift springs
    Clutched!!
    XLCat
    Re:Problems with 09 grizzly 700 2009/08/18 14:24:46 (permalink)
    Check the throttle position sensor.  It'll make it do what you're describing.
    07 700 GRIZZLY---Outlaw MSTs: 28x9.5, 28x12; Warn 3000 w Amsteel, (4) CEC 1" spacers, UNI filter, 1.25" bar relocation, removed shifter lockout, exhaust tip, 9003 SilverStars
    01 Cherokee, Rusty's Long Arm setup, 4.5" coils, 3.5" leafs w 1.5" shackles, Rusty's HD trac bar and mount, Rusty's steering linkage and steering box brace, no sway bars, 8.8 rear w discs, HP Dana 30 front, 4.10s, hardcore front bumper---it'll flex just a tad!
    "Don't move, he'll do it!"
    D Boy
    Re:Problems with 09 grizzly 700 2009/08/18 14:52:21 (permalink)
    How and where do you check the throttle sensor?
    14" S212
    27" Mudlites
    K&N
    warn xt25
    XLCat
    Re:Problems with 09 grizzly 700 2009/08/18 15:46:55 (permalink)
    You can check it thru the pod in diagnostics mode.  I forget the key sequence.  But I do know the readout should be about 16 or 17 sitting at rest.  I'm not sure what it should be at WOT.  You can go thru the diagnostics mode, just pumping the throttle at each menu.  When you get to the right one, the numbers will be changing w the throttle movement.
    drew7693
    Re:Problems with 09 grizzly 700 2009/08/18 15:53:13 (permalink)
    i didn't know this. Thanks XL Cat, i'll be checking this tonight....
    SS 108's
    2.5 warn XT
    DynaFS ignition
    HMF Utility
    HMF Optimizer
    K&N air filter
    Clutched!!
    D Boy
    Re:Problems with 09 grizzly 700 2009/08/18 19:07:18 (permalink)
    Don't you have to have the pod mod to check that on the 09 model?
    14" S212
    27" Mudlites
    K&N
    warn xt25
    Mud lawdawg
    Re:Problems with 09 grizzly 700 2009/08/18 19:27:21 (permalink)
    D Boy
    since its brand new, I would take it back to the dealer and have them look at it..I wouldnt do anything to it..If you do then they prob will say you did something to cause it...
    before going back to dealer go back to the stock air filter..make sure its not the kn getting to much air....if that doesnt fix it call the dealer..You spend too much money on having something that isnt running right...I have the 08 and have not had this problem..atleast not this bad...it does die sometimes, but heck all bikes do.  JMO
    Mine
    08  700 DU,
    29.5, 12" lift, HMF, ///, pc3, snork'd
    Wife's
    07 700 SE
    29.5 ,snork's, 2" lift,HMF, TMHP "Girl Power" Rad relocate, Clutch kit, Led's, Custom Radio
    TMHP
    Green420
    Re:Problems with 09 grizzly 700 2009/08/18 20:25:42 (permalink)
    mines has that occasional die when you floor it thing going on, but not as bad as yours. I think all 700s do this. When you find out what it is please let us know.
    13 CARBON BLACK X COMMANDER
    TeamGriz318
    Re:Problems with 09 grizzly 700 2010/07/12 18:30:18 (permalink)
    I'm havin the same problem on my 09 griz 700.  Have just a little over 300 miles on it.  Didn't start doing it until i put an HMF pipe on it.  Put a new spark plug in it....didn't fix it....put a dynatek programmer in it......didn't fix it either.  What could it be.  Any suggestions would be greatly appreciated.  Thanx in advance
