LockedOil Filter for Grizzly 700
LaGrizzly
2008/05/05 12:26:00 (permalink)
What oil filter will work for 07 Grizzly 700?
21 Replies Related Threads
    dt5150
    RE: Oil Filter for Grizzly 700 2008/05/05 12:52:16 (permalink)
    i just get em at the stealership.
    -07 Grizzly 700 FI
    -27" XTR's
    -1" Spacers
    -Warn 2.5ci
    -2R Racing Front/Rear
    Winch Mount
    -2R Racing Billet Exhaust Tip
    -Dalton Clutch Kit
    Ball
    Administrator
    RE: Oil Filter for Grizzly 700 2008/05/05 14:08:21 (permalink)
    PH6017a is the fram #. It is the same filter that all of the Yamaha quads that use an external filter, use.
    2014 RZR XP1K
    LaGrizzly
    RE: Oil Filter for Grizzly 700 2008/05/05 21:15:22 (permalink)
    thanks
    brutescoot
    RE: Oil Filter for Grizzly 700 2008/05/05 22:08:52 (permalink)
    i woulnt run a fram there junk use the yamaha filter or cross it over to a wix or napa you will be better off
    Buzsaw
    RE: Oil Filter for Grizzly 700 2008/05/05 22:58:20 (permalink)
    any filter for an 94 Mazda MX-3 or RX-7
    Grizzified
    RE: Oil Filter for Grizzly 700 2008/05/05 23:24:58 (permalink)
    I can't take credit for the list, but here it is:
             Yamaha: 5GH-13440-00-00
    ·        Fram: PH6017A
    ·        NAPA: 1358
    ·        WIX: 51358
    ·        AC: 2057
    ·        Mobil M1-110
    ·        Super Tech st7317/st6607(a little shorter)
    ·        AC Delco PF2135
    ·        AMSOil SMF103
    ·        Carquest 85358
    ·        FRAM PH6017A
    ·        Honda 15410-MCJ-000
    ·        K&N KN-204, about $13. Metric nut on end for easy removal.
    ·        NAPA Gold 1358
    ·        Purolator ML16817. Imported, not made by Purolator.
    ·        STP SMO 17
    ·        WIX 51358
    ** Purolator pure one PL14610  -   this is my preference.
    2007 Yamaha Grizzly 700
    Rox risers/Protaper Contour bars
    HL 1.5" rear spacers
    26" Mud Bugs on black Type 4s
    Radiator Relocated
    Snorkeled
    ORIGINAL: Riggss does that void the warranty?
    CamoMan700
    RE: Oil Filter for Grizzly 700 2008/05/06 10:43:13 (permalink)
    I understand the Purolator is the best filter out there if you can find it. I have been using the Mobile M1-110 on both my 450 and 700. You can find them at any auto parts store. I have heard to many bad stories about Fram filters and there paper inside.
    2007 Grizzly 700FI
    ITP Type 7 14" wheels
    ITP 27" XTR's
    PIAA 510 lights on a Yamaha Brush Guard
    Camo Seat cover-Front Rack Extension
    Warn 2.5 Winch
    Yamaha OverFenders
    Plano Rear Cargo Box
    R2 Power tip- Uni Filter
    Sylvania SivlerStar H4 Blubs
    PowerMadd Handguards
    lagrizz700
    RE: Oil Filter for Grizzly 700 2008/05/06 10:57:19 (permalink)
    from my understanding the mobil 1 filter is the highest rated and the pure one filter is a close second (also alot cheaper) both are very good i prefer the pure one....seems like you are kinda paying for the mobil one name to me. either way i would stay away from the fram filters, i have heard alot of bad things about them as well.
    Jonathan
    LaGrizzly
    RE: Oil Filter for Grizzly 700 2008/05/06 11:42:48 (permalink)
    Thanks for all of your help.
    LaGrizzly
    RE: Oil Filter for Grizzly 700 2008/05/06 11:47:57 (permalink)
    how many quarts of oil does the 700 use with filter?
    CamoMan700
    RE: Oil Filter for Grizzly 700 2008/05/06 12:27:20 (permalink)
    The Mobile 1 filter and a few others are longer than stock so they hold a little more oil. I always get 3 quarts and it will take almost all of it. I push it to the top of the dipstick for sure and even a little over want hurt anything. It's safe to say with the bigger filters it will take between 2.5 to 2 3/4 of a quart. That will leave a little in the bottle in case it use's any before I change it again. So far I have never had to add any oil once I got it filled up to where I want it. I also recommend using Synthetic oil like Amsoil or Mobile 1. Just make sure its' made for a ATV or motorcycle for it's wet clutch.
    2007 Grizzly 700FI
    ITP 27" XTR's
    Warn 2.5 Winch
    Yamaha OverFenders
    LaGrizzly
    RE: Oil Filter for Grizzly 700 2008/05/06 23:34:01 (permalink)
    Hey, Camo thanks you have been helpful. And all the other people, thanks for your help.
    JUSTADDMUD420
    Re: RE: Oil Filter for Grizzly 700 2012/08/17 06:00:54 (permalink)
    H
    post edited by JUSTADDMUD420 - 2012/08/17 06:02:21
    08 GRIZZLY 700 SE BLACK
    31 outlaws
    2" lift
    Dynojet pc3
    HMF
    EPI white spring & 2mm shim
    Snorkles
    K&N
    09 HONDA 420 WHITE
    28 OUTLAWS ON SS108
    2" HL LIFT
    HL SPRINGS (POWDER COATED WHITE)
    DYNOJET PCV (DYNO TUNED)
    HMF
    EPI CLUTCH KIT (COMP STALL)
    CUSTOM SNORKEL 2"
    K&N INTAKE
    SPOOL LOCKER
    JSTRONG RADIO BOX W/ UPGRADED FUSION SPEAKERS 600WATTS
    Soon to come: 14.5% primary gr
    duddor
    Re: RE: Oil Filter for Grizzly 700 2012/08/17 06:40:21 (permalink)
    I use the Purolater L14610, they're $3.50 from wal-mart. I use them on the rhino, grizzly, bruin, kodiak's, etc.
    Grizzly 700... It's got stuff.
    bcom
    Re: RE: Oil Filter for Grizzly 700 2012/08/17 07:23:33 (permalink)
    Even Fram motorcycle filters have paper end caps!! Fram = junk
    current ride--a derelict shopping cart
    Happy terrapin with koozies!!
    duddor
    Re: RE: Oil Filter for Grizzly 700 2012/08/17 07:58:17 (permalink)
    Agree'd, I don't use Fram anything!! They're made of cardboard and hot glue.
    bcom
    Re: RE: Oil Filter for Grizzly 700 2012/08/17 08:04:49 (permalink)
    The only Fram i would consider using is their "XG(Xtended Guard" line of filters.I have cut them open.They have a solid synthetic media and good metal end caps.All other Fram filters have paper end caps.I have put Fram filters on vehicles and then took them off with 5 miles on them and cut them open to find that the filter media inside was falling apart and not glued correctly.Purolator filters are the best bang for your buck.Purolator uses metal end caps in all their filters and their entire line is reasonably priced and easy to find.
    589Wolvy
    Re: RE: Oil Filter for Grizzly 700 2012/08/17 08:04:54 (permalink)
    I also use the purolater's on my grizz.
    08' Rancher 475
    #19
    AC500iM
    Re: RE: Oil Filter for Grizzly 700 2012/08/17 23:21:32 (permalink)
    Bosch D3323 Distance Plus High Performance Oil Filter
    2011 Grizz 700
    "Big Blue"
    2011 550XP (Sold)
    Great ride...not built to last :(
    06 500ES (Sold..g'bye my friend)
    w/some stuff......
    #20
    Ole Nasty
    Re: RE: Oil Filter for Grizzly 700 2012/08/18 08:59:48 (permalink)
    I always have a problem with the yamaha ones no wanting to thread on very good, anybody else have that problem?  I usually use the purolator ones from walmart.
    2011 Grizzly 700 EPS
    29.5" Highlifter Outlaws
    2mm Shim Mod
    EPI White Spring
    Snorkeled
    Wild Boar Radiator Re-locate
    2" Highlifter Lift
    Yamaha HD front bumper
    2014 Polaris Ranger XP 800
    All Stock
    Gone
    2005 Yamaha Rhino 660
    2009 Polaris Sportsman 500HO
       http://www.youtube.com/OleNasty79
    #21
    dreamweaver
    Re: RE: Oil Filter for Grizzly 700 2012/08/19 22:02:01 (permalink)
    If using a Purolater get the ones from the Auto parts store that say Pure One.
    The walmart line purolater isnt recomended for an ATV.
    #22
